I did this ________ for $100 OR LESS! - Page 105 - JeepForum.com
 21Likes
post #1561 of 2241 Old 08-05-2013, 03:27 PM
bgi3
1983 CJ7
Put a driver side floor board in for around 35 bucks. Had to borrow a buddy's welder. I know it looks like crap but hey first time welding and first time doing any body work........
24 hours in a day. 24 beers in a case ... coincidence?
When in doubt? GAS IT!!!!!
Parachute For Sale! Only used once. Never opened. Small stain.....
1984 CJ7, 4.0 FI, 31" BFG A/T,
bgi3 is offline
post #1562 of 2241 Old 08-05-2013, 09:39 PM
Jrdchiropractic
2009 JK Wrangler
Master flow MF450 $60, synergy mounting plate $39. Just made it under $100. I think I still have some wire loom in the shed.
(0|||||||0)
09 JK w/ a winch and duratracs
Just enough to get through most of the time,
get stuck sometimes, and still get home
Jrdchiropractic is offline
post #1563 of 2241 Old 08-06-2013, 09:47 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
for the old timers using leaf springs, its only a matter of time until a leaf breaks, and thats usually on the trail. I made up 6 of these nifty clamps to save the day when needed. Broke a main leaf (double military wrap helped) and got me home. Easy, cheap and when needed...priceless.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #1564 of 2241 Old 08-06-2013, 10:40 AM
kjg26
kjg26's Avatar
How thick is the cross plate?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #1565 of 2241 Old 08-06-2013, 12:58 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
IIRC, just some scrap 1/4 plate i had laying around. trace out the bars, drill holes then cut out with a band saw, deburr and paint. Done.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #1566 of 2241 Old 08-06-2013, 05:44 PM
zephyr80
What does iirc stand for?
Sent from your back seat!!!
zephyr80 is offline
post #1567 of 2241 Old 08-06-2013, 05:46 PM
Winners97TJ
Go Big Or Go Home
Winners97TJ's Avatar
If I recall correctly......
Gun Control Means Using Both Hands
1997 Jeep TJ - Truly BUILT not BOUGHT! Purchased from original owner stock... obviously THAT didn't last long!
Winners97TJ is offline
post #1568 of 2241 Old 08-06-2013, 06:16 PM
zephyr80
Oic... thanks
zephyr80 is offline
post #1569 of 2241 Old 08-06-2013, 08:35 PM
686keydragon
This is hardly exciting but I figured I would post it anyway since I like seeing free solutions... I got tired of my cb coax just being run over the tub and decided I wanted to install a rubber grommet for it to run through. While I was having my tires rotated the other day I saw some old valve stems that had been chopped off in the parking lot, they looked like they would work so I decided to give it a whirl as a grommet. Drilled out the center large enough for the cable to fit through and drilled a hole in the jeep large enough to get the valve stem through. Works pretty well actually and looks much better.
2002 TJ, 2.5L, 4" lift, 33" dunlop mud rovers, xrc8 winch, aussie locked d30, a-z fabrication ww2ww sliders, mounted mv-50 compressor, SirGcal sub box
686keydragon is offline
post #1570 of 2241 Old 08-06-2013, 09:15 PM
Jrdchiropractic
2009 JK Wrangler
I like it. Ingenuity at its finest.
(0|||||||0)
post #1571 of 2241 Old 08-06-2013, 09:35 PM
holliewood61
1981 CJ7
Good idea. I like seeing I did this for 100 or less rather than I bought this for 100 or less
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #1572 of 2241 Old 08-07-2013, 06:36 PM
tuhmayo
Cut up my rear bumper with my friend cost - $10 Bedliner and sheet metal
tuhmayo is offline
post #1573 of 2241 Old 08-07-2013, 08:16 PM
ashland82391
Looks good but dang your Jeep looks low
ashland82391 is offline
post #1574 of 2241 Old 08-07-2013, 08:24 PM
JeepComanche89
1989 MJ Comanche
That looks terrible. Why would someone do that and post it to a forum. Id be embarrassed to show that to anyone.
JeepComanche89 is offline
post #1575 of 2241 Old 08-07-2013, 08:27 PM
ashland82391
Jeez man, his welds weren't pretty but he cleaned them all up in the last pic...
cheap , cj
