I did this ________ for $100 OR LESS! - Page 103 - JeepForum.com
 16Likes
post #1531 of 2232 Old 07-01-2013, 08:23 PM
cr4zyfkr
I did this.....
I scored some gear. Feast your eyes...
Since this is the "What did you do to your WK today?" thread, I will start with the most directly related thing: I got a roof rack for it. It originally came off a 4 Runner so I will need to make some adjustments to it to make it fit my crossbars. First on the list is to remove the rails that came on the bottom of the basket so I can U bolt it directly to my crossbars. Second on the list will be to either coat it with bedliner or some Rustoleum matte black.
Test fitting to see where things land.
(Yes I know it's off center. )
Pretty sure it's this rack:
http://www.amazon.com/Surco-S4560-Sa.../dp/B00029KBGW
I also scored some other gear.
http://www.dickssportinggoods.com/pr...ductId=3998052
A $450 TENT!!
USMC sea bags anyone?
2D Maglite
Let's have a picnic!
Heatsurge propane infrared tabletop BBQ
Total cost for everything: $20.
Everything except the roofrack, tents and a fishing pole not shown were pulled from storage units at work. People abandon them and sometimes I get to rummage through and see if there's anything I want to keep when we empty them out and throw stuff away.
The roofrack, tents and a fishing pole / camping pots and pans were $20 from craigslist today. Now all we need are some pads or an air mattress. So excited about the finds.
cr4zyfkr is offline
post #1532 of 2232 Old 07-01-2013, 08:51 PM
95YJMountie
95YJMountie's Avatar
It fits perfect. No rattles, vibrations, nothing. And it drops good, no issues with it at all. Definitely money well spent, and was still a nice cheap mod. Makes what used to be a useless swing out tailgate have some use to it. Im definitely happy with it.
95YJMountie is offline
post #1533 of 2232 Old 07-02-2013, 04:13 AM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
nice sea bag
SEMPER FI
LifeProof is offline
post #1534 of 2232 Old 07-02-2013, 05:54 PM
JeepComanche89
1989 MJ Comanche
Originally Posted by cr4zyfkr
I did this.....
Hmmm im a little jealous right now. I spent 20 dollars today too and dont have anything like that to show for it lol
JeepComanche89 is offline
post #1535 of 2232 Old 07-02-2013, 06:06 PM
sjones26573
That tent is an awesome find. Most of it is, but I like the Eureka in particular
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #1536 of 2232 Old 07-02-2013, 11:23 PM
cr4zyfkr
Thanks! It was a surprise from the folks I bought the rack from. We had spoke about other stuff they were dumping since they were moving and asked if there was anything in particular I was looking for. I mentioned fishing and camping stuff. When I got there this stuff was strapped to the rack. They said they weren't sure if everything was with the eureka but the Coleman was good to go. Sure enough, everything was there.
cr4zyfkr is offline
post #1537 of 2232 Old 07-04-2013, 01:48 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
fuel pump and sending unit access panel. cost? free with materials on hand. Beer, plasma cutter and a countersink drill bit. No more dropping tank for fuel issues. Should have done this along time ago...
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #1538 of 2232 Old 07-04-2013, 02:08 AM
ashland82391
Nice
ashland82391 is offline
post #1539 of 2232 Old 07-04-2013, 10:26 AM
underpowered
Bouncin' on a Budget
underpowered's Avatar
one of the best things i ever did to my ZJ was the fuel pump access panel.
and i made this for much less than $100, but did use machinery not everyone has access to and cost many thousands of dollars lol.
i made both the shift knob and the 4wd shift knob in the background
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #1540 of 2232 Old 07-06-2013, 12:13 PM
GilNewJeeper
2008 KK Liberty
Originally Posted by NOC Bulldog View Post
I wanted a lot more room in my TJ for my wife and I to have some stuff, and to be able to keep it locked up, along with keeping it dry. I removed the rear seat, along with the rear seat belts. I took some measurements, along with using a cardboard template, and made this....
Here is a shot from the side
Here is a shot from behind the front seat
I used one sheet of 3/4" plywood (already had it), and I bought a 4' x 9' sheet of rubber matting in a diamond plate style ($81.00 I think), 8 carriage bolts with nuts, small screws (to help hold it down along with 3M adhesive), and some black silicone to fill in the small gaps to make it weather tight. I also have yet to install 4 pocket tie downs to hold the top on while it's down, or as a tie down point for bigger items.
So I have less than $100 bucks into it now...... will be building a subframe underneath for a sliding drawer so I don't have to reach in. The only way to get into this will be through the locking tailgate. I also have a compressor that I will be mounting into the top, I need to cut out an area for the air pressure gauge, along with the locking sleeve.
Very nice, i want to do the same thing but want to use aluminum diamond plate over the plywood instead of the rubber
Did you Hug your Jeep today?
2008 Jeep Liberty
1994 Wrangler Sahara
GilNewJeeper is offline
post #1541 of 2232 Old 07-06-2013, 12:30 PM
Rican142
What would have cost me 60 bucks to call a locksmith to unlock my comanche ended up costing nothing cause I remembered the hole in my passenger side floor pan, so I just stuck my arm in an rolled down the window...for once, rust HELPED
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #1542 of 2232 Old 07-06-2013, 01:53 PM
b_a_mech
Funny....wrong....but funny!
BUILT NOT BOUGHT #602 / ZOMBIE RESPONSE TEAM #40 / USN HULL #196
b_a_mech is offline
post #1543 of 2232 Old 07-08-2013, 07:18 PM
loch_carron
Replacement Soft Top padding
The foam padding on my soft top was pretty well shot, so I headed down to my local big box DIY store and bought a length of 7/8" inside diameter pipe insulation- the kind with the adhesive tape attached. Cut off the old padding and used it to get the length I needed, cut two to length and slipped the insulation over the bars. Peeled off one side of the adhesive and then worked my way down the new padding, exposing the other half of the adhesive as I carefully lined up the pad.
It's not as thick as the old, worn out padding, but it's better than none at all. Best of all it was only $1.50 for a 6' length!
loch_carron is offline
post #1544 of 2232 Old 07-08-2013, 10:13 PM
higgins192
You must have the best top super top like I do
higgins192 is offline
post #1545 of 2232 Old 07-08-2013, 10:37 PM
95YJMountie
Pictures wouldnt uploadnin my previous attempts, but here it is. Tailgate mod. Cost well under 100. Also the tj gas filler mod. Cast around 95 but only because i also bought a locking cover.
cheap , cj
