I did this ________ for $100 OR LESS! - Page 10 - JeepForum.com
 21Likes
post #136 of 2241 Old 09-10-2009, 09:34 AM
muddy93
1987 FSJ Wagoneer
here's a link to my storage box setup, http://www.jeepforum.com/forum/f37/y...ite-up-596248/
I pretty much just designed it as I went, but I think it turned out ok. it consists of 4 seperate parts, two wheel well boxes, a bulkhead/trunk section that can be attached in two different locations, and a lid/tonneau.
gonehiking74 likes this.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #137 of 2241 Old 09-10-2009, 12:38 PM
TimeConsumer
Spraypainted the headlight bezels black. >$10 including paint and sandpaper. IMO really cleans up the front end.
offtopic, with all the namecalling, borderline trolling and obscene language wbrett1027 has used, one starts to wonder how he has retained member status... Or atleast his inflammatory posts.
Is it the dream that one day you might be something you're not?
TimeConsumer is offline
post #138 of 2241 Old 09-10-2009, 03:44 PM
theAuthority
theAuthority's Avatar
1981 CJ5
Originally Posted by wbrett1027 View Post
you would be amazed, im not scared of anyone. however i will respect my authority. but talking about my parents and about my problems...
we have a problem
im not scared of anything nor anyone i live my life one min at a time not worrying or having regrets.. i wish some of you guys would look at who your talking to. calling snobby.. FUNNY GUY A
You called ? Now stfu ...
I passed emissions today, 4 bottles of 99% isopropyl alcohol mixed with 2 gallons of 89 octane gas. IMS set at 1.5 turns and idle set at 1100.
Woot, no cats either
-Daniel
theAuthority is offline
post #139 of 2241 Old 09-10-2009, 06:30 PM
DiabloYJ
Originally Posted by CopperCJ7 View Post
You got some big mouth for a little troll. You tell me to shut up and I challenge you to shut me up - then this is your response?
Copper I will gladly take this responsibility off of your shoulders. Considering that I'm from MD...and he's from MD as well...I think I actually have a far better chance of getting some "results" than you do. Don't put him on your ignore list though...that takes away some of the fun.
How original. What movie did you steal this line out of?
"When Life starts to pass you by..............Downshift"
Then again that used to be my motto until I got the Jeep, now that doesn't even work half of the time.
GD Thread HIJACKERS Member #1
ΜΟΛΩΝ ΛΑΒΕ
-Justin
Originally Posted by 2006Sport View Post
Sometimes I wish I had leaf springs.
DiabloYJ is offline
post #140 of 2241 Old 09-10-2009, 10:35 PM
pentastar01
This thread is startin' to get good.
But back to the topic, Cherry Bomb exhaust with a side exit AAR 'Cuda style. Just because it's a Jeep doesn't mean it can't have a somewhat performance look to it, IMO.
Life's tough, that's why I drive a Jeep. Until it breaks, then life's a *****.
pentastar01 is offline
post #141 of 2241 Old 09-10-2009, 11:07 PM
DiabloYJ
Can you post some pics? My exhaust pipe was rubbing on my rear shackle after redoing the lift because of the length of the bolts so I had to sawzall it off because the noise was getting to me. I though about doing a side exit though but just didn't know how it would look.
ΜΟΛΩΝ ΛΑΒΕ
-Justin
DiabloYJ is offline
post #142 of 2241 Old 09-11-2009, 04:19 AM
Jones
Consider the following...
Jones's Avatar
This thread needs to get back on topic.
Jones is offline
post #143 of 2241 Old 09-11-2009, 05:53 AM
XJMuscle98
Auxiliary Fan switch.
All you need is some wire, a switch, two female quick connects whatever size your switch takes , and one of those strip free wire connectors.
Go to pin2 on connector 3 under the hood to the PCM.
Use one of those strip free wire connectors and run another line off to a switch and it will go in the "Power" position on the switch, then run another line off the ACC position on the switch and run it to good ground.
You are done.
What happens is the computer sees that the engine is getting hot, and grounds pin2 on c3. You just make this happen without the computer's interference.
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline
post #144 of 2241 Old 09-11-2009, 06:54 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Back on topic:
Homemade 03-06 TJ Transfer Case Drop
GPS Mount for Roll Cage
3rd Brake Light and CB Antenna mount
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #145 of 2241 Old 09-11-2009, 07:59 AM
pentastar01
I wish I could post a pick, but don't have a camera(at least not at the moment). Mine looks OK. If lookin' at it from the side you can see the Cherry Bomb and the rest of it. But the tip I picked isn't long enough so it doesn't stick out beyond the rocker(which is probaly better). If I do get a camera I'll be sure to post it up.
post #146 of 2241 Old 09-11-2009, 08:57 PM
compcrasher86
You are done.
Very cool, I'm doing this with my XJ soon. One thing I did was the Ext. Idle switch that most people know about but ill post it up here anyways. On my 98, I ran a switch that grounded the grey, solid color no stripes, wire coming out of the PCM. when you flick the switch, it grounds the grey wire and idle rpms rise to about 1100. useful for jumping, running accessories, getting good idle heat in the winter, etc. Disclaimer: wire colors vary depending on year so search around and find the correct thread (although in most years post 98 I'm pretty sure its grey)
Matt
compcrasher86 is offline
post #147 of 2241 Old 09-12-2009, 02:45 PM
danthejeepman90
1989 XJ Cherokee
i painted the fender flares and lower part of my doors and rocker pannals for a little more than $10
this is my cherokee... there are many like it but this one is mine, I will love my cheroke form the day of ownership untill the day it dies, I promise to modd it and beat it after said mods... i promise to treat all other cherokee owners as family even though they are complete strangers.... and promise to jeep on forever
(in reference to wheeling) if at first you don't succeed, you clearly don't drive an xj
1989 jeep cherokee
danthejeepman90 is offline
post #148 of 2241 Old 09-12-2009, 04:04 PM
TimeConsumer
The KC Daylighters may not be under $100, but putting them on my A frame was a cool mod for about ~$50 including brackets, wiring and a relay.
post #149 of 2241 Old 09-13-2009, 06:00 PM
pentastar01
LOUD air horn, for...wait... $0. Now that's cheap.
post #150 of 2241 Old 09-13-2009, 07:37 PM
Mtnduey
Made a simple but solid/rugged mounting system for my LJ Hard Top.
I did this on my old 88 YJ and was really pleased with it. The idea behind this is to spread the load on the hardtop mounting surface so no single point of the fiberglass is asked to bear the entire load should any form of incidental contact happen off road or otherwise.
In short one of the more common things I saw with other Jeeps was the fiberglass around the bolts would crack or wear at a much higher rate due to the pressure put on the glass whether from overtightening, contact offroad (trees, etc..) or anything else really.
Anyhow, I'm rambling. On with the info...
Hardware:
1"x36"x1/8" Alluminum, holes made with 3/8" drill bit
Forget the length on the Eye Hook bolts, think it's 2.5" but I know diameter is 5/16"
I experiemented with both single/double nut at the top to square up the mounting surface. Single Bolt seems to be the best if you want to use a double washer system on the underside of the bolt.
Top and Bottom I used a regular washer as well as a rubber washer.
I also used a nylon threadded nut to secure the bolts, could just as easily use locktite if you want.
Total Hardware investment about $20
Pic:
-D2
Mtnduey is offline
cheap , cj
