High Lift Jack Mounting Location - Page 29 - JeepForum.com
 8Likes
post #421 of 460 Old 09-24-2013, 01:39 PM
drandersoninc
drandersoninc's Avatar
Originally Posted by reddirtTJ View Post
Yes. I run without a top most of the time. Due to a surgery I had to put my hardtop back on. I found that mine wouldn't fit on the back on roll bar with the hardtop. I had to get out the grinder and cut an angle on the top side to be able to slide it in. I have a 06 factory top on a 97 if that matters. Obviously it is no problem with soft top etc. I hope that helps.
Attachment 701961
Hmm... it looks like you got yours to mount on the top of the roll bar and I like that position much better than mine (under the roll bar). Would you mind either posting pics of your mount points for both sides of the HiLift for comparison or at least PM them to me? Thanks...
drandersoninc is offline
post #422 of 460 Old 09-25-2013, 06:28 PM
reddirtTJ
I'm still not 100% content with the mounting. I'm kinda concerned with it becoming a projectile during a wreck/roll over. Especially now with kid in the back. I did have to drill holes in the base and one to line up with the roll bar on the other side.
97 TJ 4.10s, 33s, 4" Clayton.
"TJ's and CJ's are Jeeps. BJ's are something else entirely. I can only help you with the first two." Sundowner
reddirtTJ is offline
post #423 of 460 Old 11-22-2013, 12:47 PM
auburnhunter
I had mine mounted to the front of the stock bumper on my LJ, and I looked at it as "extra bumper". However, now that my LJ is my DD, I took it off and will be installing it in my CJ6, probably lenghtwise in the bed. I use mine a lot on the farm, mostly for jacking up tractors and especially for pulling fence posts. It works great for popping metal fence posts out of the ground with a short length of chain.
"The problem with quotes on the internet is that you never know if they are real or not" - Abraham Lincoln
auburnhunter is offline
post #424 of 460 Old 12-16-2013, 09:32 PM
ocblaze
1979 CJ5
Originally Posted by OldTexas View Post
Jes mounted mine in a spot that was empty.
Do you have any close-up pictures of how you mounted the hi-lift?
ocblaze is offline
post #425 of 460 Old 12-17-2013, 12:04 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
looks like the standard hi lift stand-off mounting kit.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #426 of 460 Old 02-25-2014, 07:39 PM
462FSJ
1973 J-Series Truck
Where did you find that American motors windshield deval?
462FSJ is offline
post #427 of 460 Old 03-07-2014, 10:03 AM
Ferrachi
I run a full size rear storage box so mounting it on the back roll bar is a no go. I put it right in front of the box with some homemade brackets. Stays clean and out of sight.
Ferrachi is offline
post #428 of 460 Old 04-16-2014, 08:48 PM
Bobby_S
Sort of reviving an old thread, but...
I mounted mine on the side of the stock tire carrier on the tailgate. It is high enough to clear the bumperettes and my future rear bumper that I'm building this summer.
The first picture is where the bolts that the Hi-lift sits on are, the second is the Hi-lift mounted, and third is it holding my rear window open:
Bobby_S is offline
post #429 of 460 Old 04-21-2014, 01:58 PM
Nitr0EngiEx
i like the way they look when mounted on bumpers
Nitr0EngiEx is offline
post #430 of 460 Old 06-23-2014, 07:01 PM
johendley
Originally Posted by GTI2JEEP View Post
well i have the steves fab. front and rear bumpers with the tire carrier and he already puts on the tabs to mount a hi-lift but the problem is, the jack blocks the license plate and i dont really feel like getting pulled over all the time for something stupid, so i decided to get some 2x2 angle iron and mount it up on the angled bars for the tire carrier.
This looks a great way to do it
johendley is offline
post #431 of 460 Old 06-23-2014, 07:09 PM
johendley
Originally Posted by YJames90 View Post
I still think I have the best mounting location
Looks a nice clean way to mount it
post #432 of 460 Old 06-23-2014, 07:17 PM
johendley
It's a shame that by now some engineering minded person hasn't come up with a folding hi- lift jack.
post #433 of 460 Old 06-23-2014, 08:13 PM
CrawlAK
its definitely possible this day and age but i dont think thats the issue, with as sketchy as hi-lifts can be i don't think anyone wants to add a folding/hinge element into the mix.
CrawlAK is offline
post #434 of 460 Old 06-23-2014, 09:15 PM
Ice_Box
i know i almost got a concussion when i was lowering down a farm implement when i was younger because i didn't know that you have to hold and be careful.
Ice_Box is offline
post #435 of 460 Old 06-24-2014, 10:57 AM
rdgblk
I had mine mounted similarly to Reddirt (post #422).
It wasn't that much of an obstruction when I was trying to get stuff in/out of the tailgate. But obviously it gets in the way if you are trying to load anything in that is larger and won't fit over or under it. It also was kind of a hassle to lower the soft top and fold the loose material under the jack.
I took the jack out last year. I only put it back in occasionally if I think I'll need it.
rdgblk is offline
Best High Jack Lift urwaker General Jeep & Off-Road Equipment 17 07-11-2017 08:32 AM
Hi-Lift jack location 2000TJDude General Jeep & Off-Road Equipment 0 05-31-2007 10:41 PM
High lift Jack Blaster General Jeep & Off-Road Equipment 13 11-17-2006 10:22 PM
mounting a 60" hi jack lift sahara0207 General Jeep & Off-Road Equipment 16 11-01-2006 07:45 PM
high lift jack jm708 Cheap Tricks & Fixes 15 02-07-2006 04:07 PM
