High Lift Jack Mounting Location - Page 27 - JeepForum.com
 8Likes
post #391 of 460 Old 02-13-2013, 01:02 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
Originally Posted by slawkin93 View Post
I mounted mine on the rear bumper. Would add a pic but cant yet. New member
its real easy-- link via a hosted site such as photobucket.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #392 of 460 Old 02-13-2013, 03:02 PM
saharacon87
Originally Posted by RARECJ8 View Post
nice mount to keep a good COG, but seems that will negatively affect your departure angle and it may soon be ripped out or bent up. And perhaps dirt/pebbles and moisture from rear tire spraying up into the jack climbing mechanism any also affect its functionality when really needed. (Side note: in 30+ years of wheeling rarely if ever do externally mounted jacks function properly when needed-- someone has to hunt up some WD40, etc and that defeats the concept of having a jack at the ready.) Regular lube and maintenance + work out under load helps keep them in shape.
So i like the styling of the low rear mount, and this is just one dude's perspective, you may not be happy in the long run for the above reasons.
That's a good point. I mount mine externally so I don't lose cabin space but I try to take it off when I'm driving around town to keep it from seizing up. Pb blaster is always in my jeep as well lol
TJ 3" FT, Front Currie Arms, v8 zj steering, 30 locked/44 open, 33 m/t, Armor
saharacon87 is offline
post #393 of 460 Old 02-21-2013, 11:28 AM
JeepNut4581
Originally Posted by Raybz View Post
I made a mount for on my front bumper
Used some square tube as spacers and threaded rod with some wing nuts to secure it
You can see where it is in this pic
Great info...thanks!
JeepNut4581 is offline
post #394 of 460 Old 02-21-2013, 02:38 PM
wilywillie
I mount mine between the roll bars in the rear (pic/post somewhere WAY up above).
I keep the doors and windows off 1/2 the year, so even mounted "inside" like that, it still gets weathered.
Maintenance is important to me, like I hope every serious Jeeper feels. I use LP grease, straight from the grease gun I keep in it. PB, liquid wrench, and WD are great penetrants, but aren't much for lubrication!
my $0.02
I'm just here for the gasoline. --Max
wilywillie is offline
post #395 of 460 Old 02-26-2013, 01:25 PM
99XJFan
Interesting idea to have it under front bumper...hard to get when buried in mud, though!
99XJFan is offline
post #396 of 460 Old 02-26-2013, 06:16 PM
ashland82391
Just moved mine from the hood to my tire carrier.
ashland82391 is offline
post #397 of 460 Old 03-06-2013, 07:16 PM
Md_06Unltd
Has anyone with an LJ tried mounting it on the inside, lengthwise (front to back) instead of widthwise?
I'd like to see the mount set-up
01 XJ Sport
06 LJ Unlimited Rubicon
08 XK Commander
66 M416
Md_06Unltd is offline
post #398 of 460 Old 03-07-2013, 04:18 PM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
yes, page 20 is in the tub and page 25 is across above the rail in this exact thread
SEMPER FI
LifeProof is offline
post #399 of 460 Old 03-08-2013, 06:40 PM
Md_06Unltd
Thanks for that...I prefer it going across from roll bar to roll bar lengthwise...in the one pictured on page 25, he has a homemade cage, but the idea is the same.
I'm thinking maybe I'd prefer the end with the jack mechanism toward the rear. I would hate to have that bust loose and punch me in the back, or smack me in the head.
01 XJ Sport
08 XK Commander
66 M416
post #400 of 460 Old 03-15-2013, 09:36 PM
whiskeywiz
Originally Posted by JeepinYahoo View Post
youre a *******, the reason I put it there it because my Hi-Lift brand mounting kit suggested that as the place to put it, you suck, I was only joking about the Deer thing, and yes I do think it would be smooth in a crash to have a big *** piece of steel mounted to your bumper. Maybe if you had a good mounting kit like I do you would have seen that that is the way the Hi-Lift company wants you to put it...and I see them like this all the time. So, what do you think abou that. i bet you think Hi-Lift is wrong, Right? Well its better than mounting it on the Friggin hood like some people ive seen. And my bumper doesnt take many beatings, I take care of my Jeep.
Hi-lift wants you to put it there so you can buy a new one when you get into a bumper-bender. Roid much?
whiskeywiz is offline
post #401 of 460 Old 03-17-2013, 11:01 PM
Krazman
JK TeraFlex HD Hinge Mount
While TeraFlex has released a jack mount for their HD hinge and tire carrier, it is seemingly on perpetual back order. I wanted something sooner rather than later so I ordered a Rugged Ridge jack mount and modified it to fit the the TeraFlex hinge by welding a couple of tabs to pick up existing holes. I also added a bit of reinforcement to the mount since it seemed a bit flimsy. After a bit of cutting, drilling and welding, the end result turned out great and seems plenty stout to take the punishment of the trails now.
Keith "Kraz"
Real Jeeps have 2 doors, anything else is just a station wagon with big tires.
2006 LJ Rubicon "Vader"
4" Lift, 1.5" Body lift, 35's.
"May the Forrest be with You"
2013 JK Rubicon "Sarge"
Krazman is offline
post #402 of 460 Old 03-18-2013, 09:27 AM
wilywillie
That looks really good/practical, Keith! Is that jack the 48" or the 52"? I just might steal your idea
post #403 of 460 Old 03-18-2013, 04:58 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
looks nice! Are there any body contact issues when its fully opened?
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #404 of 460 Old 03-18-2013, 10:00 PM
Krazman
All Jacked Up
Thanks for the feedback.
It is the 48" jack. I like it because it doesn't stick up so far as to require removal if I need to pull it into the garage.
Not at all. The gate opens to the stop and the jack clears the taillight and the rear hatch clears just fine.
I used some .100" thick x 2.00" wide steel from the scrap bin to make two mounts with 1/2" drilled holes. I also welded 1/2" washers to these straps for reinforcement. I used some door shims to set the height of the bracket from the bumper and measure the third hole which goes through the bracket itself (hidden by the jack in the picture). Okay, maybe I miss-drilled the first hole which caused the bracket to hit the bumper before using the door shims, but at least I double checked before getting too weld happy. The bottom now sits about about 3/8" above the bumper.
Since the upper and lower straps went behind the bracket, I welded a washer to the back of the bracket at the third mounting location to serve as stand off to keep things straight. Lastly, I added a piece of 3/4 angle (.063 thick) down the left side (also hidden by the jack) to stiffen up the back and keep the base from bending down from being bounced down the trail.
I used Rustoleum spray on truck bed paint which matches the wrinkle powder coat on the bracket (as well as the bumper) nicely. It really could benefit having what is left of the power coat stripped off and refinished, but it is passable for now. Plus, add a bit of mud and it will be well camouflaged. Overall, I couldn't be happier with how it turned out.
Keith "Kraz"
Krazman is offline
post #405 of 460 Old 03-20-2013, 09:22 AM
Cannonball888
Originally Posted by Cannonball888 View Post
I had to leave it in a parking lot on top of a lamp post base because it was too big too fit on my Jeep.
Just letting you guys know this wasn't Photoshopped. It is a photo taken in front of the Hi-Lift Jack factory
Cannonball888 is offline
Best High Jack Lift urwaker General Jeep & Off-Road Equipment 17 07-11-2017 07:32 AM
Hi-Lift jack location 2000TJDude General Jeep & Off-Road Equipment 0 05-31-2007 09:41 PM
High lift Jack Blaster General Jeep & Off-Road Equipment 13 11-17-2006 09:22 PM
mounting a 60" hi jack lift sahara0207 General Jeep & Off-Road Equipment 16 11-01-2006 06:45 PM
high lift jack jm708 Cheap Tricks & Fixes 15 02-07-2006 03:07 PM
