High Lift Jack Mounting Location - Page 22 - JeepForum.com
 7Likes
post #316 of 459 Old 11-06-2011, 08:02 AM
2003X
I did the same:
My Build
2003X is offline
post #317 of 459 Old 11-19-2011, 09:21 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Mounted mine to the roller fairlead. Not sure how many have done this as I only read the first two pages then started on this page and went backwards.
Luck Favours The Prepared
Anticanman is offline
post #318 of 459 Old 11-20-2011, 12:36 PM
Ross
Great pic!! /\
But would you leave your other tools out in the rain?
Who would strap their tools outside there Jeep and drive through mud, climb rocks, expose them to salt covered roads, dust, dirt and whatever else?
If you wouldn’t do it with other tools, why would you do it with your Hi Lift?
I just don't get it?
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #319 of 459 Old 11-20-2011, 01:21 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Did ya see the cover for the internals on the jack? I keep my jack lubed and it still works. And we don't have salt here.
post #320 of 459 Old 11-20-2011, 03:23 PM
Ross
Its your jack.
Ross is online now
post #321 of 459 Old 11-20-2011, 03:44 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I keep all my jacks outside in the back of the service trucks exposed to the elements. But they get used four to five times a week in a farm environment. Much more than a jeeper would ever use one.
post #322 of 459 Old 11-21-2011, 05:58 AM
jpms
2009 JK Wrangler
Glad someone else understands that.....
jpms is offline
post #323 of 459 Old 11-21-2011, 08:43 AM
mudbug95
Originally Posted by 2003X View Post
I did the same:
what LED tails are those?
mudbug95 is offline
post #324 of 459 Old 11-21-2011, 12:05 PM
2003X
Off Road Only Lite DOTS
My Build
2003X is offline
post #325 of 459 Old 11-26-2011, 09:13 AM
jpms
2009 JK Wrangler
Home made mount that works for my uses...
jpms is offline
post #326 of 459 Old 11-26-2011, 10:07 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I like the yellow! I'd be afraid that it would get chipped by rocks in that position. Unless you used some implement paint or powdercoated it like that.
post #327 of 459 Old 11-27-2011, 08:34 AM
jpms
2009 JK Wrangler
I just painted it, give it a year it wont make a difference as much as I use it. It will be scratched up and nasty looking again....
jpms is offline
post #328 of 459 Old 11-28-2011, 05:28 PM
jpms
2009 JK Wrangler
Here I am unspringing a door that is sprung from that counter weight mounted on the door, tonight.... I use the jack more for work than wheelin.
jpms is offline
post #329 of 459 Old 12-05-2011, 09:13 PM
pickleman
this is what i am gonna do http://www.riverraider.com/store/ind...product_id=100
my 99tj build http://www.jeepforum.com/forum/f22/bad-company-tj-1291247/
pickleman is offline
post #330 of 459 Old 12-05-2011, 09:16 PM
2003X
I had these made by another member on Wrangler Forum, I will be installing this week to mount it to the roll bar. It is a 2.25", 2 piece clamp-on shaft collars from McMaster-Carr. Drill and tap to accept a bolt. Add washers, lock washers and nuts. The second and third picture show how it will look when its done.
My Build
2003X is offline
Best High Jack Lift urwaker General Jeep & Off-Road Equipment 17 07-11-2017 07:32 AM
Hi-Lift jack location 2000TJDude General Jeep & Off-Road Equipment 0 05-31-2007 09:41 PM
High lift Jack Blaster General Jeep & Off-Road Equipment 13 11-17-2006 09:22 PM
mounting a 60" hi jack lift sahara0207 General Jeep & Off-Road Equipment 16 11-01-2006 06:45 PM
high lift jack jm708 Cheap Tricks & Fixes 15 02-07-2006 03:07 PM
