High Lift Jack Mounting Location - Page 15 - JeepForum.com
 2Likes
post #211 of 454 Old 02-25-2010, 01:04 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
Originally Posted by tealo951 View Post
I ordered a neopren booty for the mechanisims so they be safe. if you look closely, the wing nut ont the pass side has a lock through the top of the bolts. so it's safe. when the things get here i'm takin it off and lubbing it and cleaning the rust that has been on it since i bought it last year. EXCITED! haha
maybe its a wives tale or not, but on the ranch growing up we were always instructed when lubing a high lift to do so under a load, so jack up ur bumper while ur lubing the heck out of it. just spraying it on in a static condition does not fully work the moving pins, springs, etc.
i have the neoprene boot and it seems to be holding up well to the elements.
good luck
mb
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is online now
post #212 of 454 Old 02-25-2010, 01:06 AM
tealo951
good luck
mb
when i put the boot on i lubbed it with my dad pushing down on the foot part while i lubbed and raised/lowered the mechanism.
Thanks for your advice! next time i won't use my father. lmao
- CPL Maskell -
tealo951 is offline
post #213 of 454 Old 02-25-2010, 05:05 PM
newbiejpr
Here's my latest creation, put it on the Jeep when I want to carry the Jack, take it off when I don't...All it took was a recovery point from Harbor Freight (I guess you could use a hitch extension, or a hitch, or a piece of 2" square tube), a 24" piece of angle, and some 3/8" hardware. put it together for under $20!
John Gilkey's Photos | Facebook
NewbieJPr
FTM-PTB-RFB-DTRT
newbiejpr is offline
post #214 of 454 Old 03-04-2010, 08:04 PM
ronsaun
2003 WJ
cant wait to review this thread
aussie rear end, drilled and slotted rotors, ceramic brake pads, ironman adj.front upper/lower and rear lower control arms, teraflex 4" spring lift, fat bobs 2' bb, rusty's drop pitman arm, jks adjustable trackbar, moog tie rod ends/ball joints, rancho 9000 shocks, kor dual stabilizer, rough country front and rear bump stop extensions, homebrew front quick disconnects, rough country rear swaybar link drop kit, IRO a-arm spacer, transfer case drop kit, homebrew rocksliders, rola roof rack, speed bleeders, 2" wheel spacers, 4-treadwright guard dog mt 265/75/16, mud flaps, superchip, k&n cold air intake, straightpiped, chrome tailpipe tip, v-led hid headlights w/halo, v-led hid foglights w/halo, kidde fire extinguisher w/bracket, maglite w/mounting bracket, cobra cb, firestik antenna, white gauges gauge face overlays, viair compressor, blue led interior lighting upgrade, hi lift 48" jack, hi lift jack base, wind deflectors for: hood, moon roof and windows, sony stereo, garmin nuvi gps, recovery D ring, interior mount keyed battery switch, custom dash brackets for gps, cb, sat radio, cellphone, bumper mount halogen reverse lights, cobra radar detector, smittybilt gear seat covers and tailgate organizer, browning rooftop camo cargo bags, grille insert, washer fluid reservoir relocation, foldup cargo carrier, aluminum side steps, addco rear swaybar, deer whistles, mobile one synthetic oil, slick 50 high mileage oil additive, k&n oil filter
TO DO:
reece front hitch, warn winch, elocker or arb front selectable locker, bulldog remote start, hi lift essential parts kit, 2-hella driving lights, gerry can and bracket, stinger bar, wood dash kit, snorkel, washer fluid heater, rear swing tire carrier, finish the skid plates, fender flares, addco front swaybar
ronsaun is offline
post #215 of 454 Old 03-04-2010, 10:25 PM
tealo951
have at it. haha
- CPL Maskell -
tealo951 is offline
post #216 of 454 Old 03-10-2010, 10:18 AM
steveojeepster
1978 CJ7
Check out the Quick Fist rubber clamps here. These guys make high quality, easy to mount / use clamps for everything including hi-lifts, shovels, etc. I've got some mounted on my tire carrier for a shovel.
QUICK FIST clamp in use
steveojeepster is offline
post #217 of 454 Old 04-22-2010, 01:52 AM
polo196
Originally Posted by Burlbook48 View Post
Cobbled together a hi-lift mount on my BESRK tire carrier out of 3" square tube. Nothing special, just some free scrap left over from my fence project.
A couple 1/2" grade 8 bolts hold the tube to the carrier, and three 1/2" grade 8 pan-head Allan bolts hold the jack to the mount. Why three? Because if I drop/lose one wing nut in the mud I'll have an extra.
The slight angle of the bolts relative to the long axis of the tube keeps one end of the jack base pressed against the mount and rattle free.
Like it and I'm going to steal that idea.Thank you sir.
Wow, I'm a member. Thats not the word I'm normally called.
Yellow Jeep Club Member #196
polo196 is offline
post #218 of 454 Old 04-22-2010, 07:09 AM
danielweaver
I saw the hood mount by Warrior for $79.99... I thought that was way too much for welded metal scraps.
Amazon.com: Hood Mount Kit For Hi-Lift Jack Warrior 1997-2006 Jeep Wrangler TJ & Unlimited TJl # 1540: Automotive
So, I made mine out of solid aluminum. There are pictures at the link below...
Daniel Weaver's Photos - Jeep | Facebook
If anyone is interested, we can make a pair for you for $100.00. They are sent to you as the raw aluminum, but with a little elbow grease they shine up really nice. It only takes about a week to make them and shipping will just be the postal "Flat rate" .. handling is included
danielweaver is offline
post #219 of 454 Old 04-22-2010, 08:34 AM
shu2kill
so the Warrior ones are expensive @ $80, but then you want to sell your for $100??? i think the welded metal scrap ones work just as good....
shu2kill is offline
post #220 of 454 Old 04-22-2010, 09:30 AM
danielweaver
The issue is, that if I am spending that kind of money I would rather spend a little more and get a heavy duty solid aluminum piece. I am not making money on these. This is made here in the US at a local tool and dye shop here in Michigan. I told him I would let people know about these. These custom pieces are way better than anything I could fabricate or buy. Just thought I would share... if you do not see how nice they are, then I am sorry.
post #221 of 454 Old 04-22-2010, 09:45 AM
shu2kill
i see they are nice, buy way too expensive for what they are... just another high lift holder...
i made this for free (had the materials laying around), and it has been holding for almost 2 years now... plus it also holds my shovel, and you could put lights on it also...
shu2kill is offline
post #222 of 454 Old 04-22-2010, 01:12 PM
bharris68
I sell these via this forum and eBay - if you're curious, please PM Me and let me know:
More pictures on my Vendor thread:
http://www.jeepforum.com/forum/f43/h...style-1009510/
bharris68 is offline
post #223 of 454 Old 04-22-2010, 01:57 PM
DaveinHouston
Here's mine. I just finished moving the jack mount lower on the carrier.
- 2003 Rubicon - 4" Lift, 35" KM2s, 5.13 gears, winch
- 1968 CJ5 - Dauntless V6, T-86, Dana 18, D27 & D44
- NRA Life Member - Licensed to Carry and Do.
DaveinHouston is offline
post #224 of 454 Old 05-02-2010, 06:55 PM
2000jeeper
Has any body mounted theres to the floor behind the front seats?
AMSOIL DEALER
2000jeeper is offline
post #225 of 454 Old 05-04-2010, 01:14 PM
tealo951
why would you want to do that? do you not have a back seat? lol just saying.. I usually always have friends in the back. lol
- CPL Maskell -
tealo951 is offline
Hi-Lift jack location 2000TJDude General Jeep & Off-Road Equipment 0 05-31-2007 10:41 PM
High lift Jack Blaster General Jeep & Off-Road Equipment 13 11-17-2006 10:22 PM
mounting a 60" hi jack lift sahara0207 General Jeep & Off-Road Equipment 16 11-01-2006 07:45 PM
high lift jack jm708 Cheap Tricks & Fixes 15 02-07-2006 04:07 PM
Best High Jack Lift urwaker General Jeep & Off-Road Equipment 8 07-30-2005 12:46 PM
