High Lift Jack Mounting Location - Page 11 - JeepForum.com
 2Likes
post #151 of 455 Old 03-16-2009, 11:01 AM
SHAKEnBLAKE
Originally Posted by erickpl View Post
I have mine mounted such that the back seat is still functional (when I have it in). My passengers have not hit their heads on it at all and it doesn't impair top up or down functionality.
Sounds appealing. Do you take the top OFF or just fold it back? Do you have a behind-the-seat storage bin? These are all aspects of my jeep that have priority over keeping the jack inside. Does it rattle at all?
Ohio4x4.com
SHAKEnBLAKE is offline
post #152 of 455 Old 03-16-2009, 01:06 PM
DixiesCJ3B
Originally Posted by 2005X View Post
i dont see any issues if you sitting on flat ground but lets face it if your stuck, then odds are your not level, which would make it hard to get the lift off the hood, kinda like this pic
Thats very true, thats when it would be a pain in the butt having it there. I just cant justify putting it inside on the back roll bar. I could see people sitting in the back hitting there heads on it. Thanks for the pic though
1999 TJ Wrangler, 4 banger 5-spd
Soft-top, full doors
31" BFG AT, 3" Lift
1954 CJ3B Willys
Hurricane 4, 3-spd with Warn Overdrive, Snow-plow
NGJC# 15
Low Output 4 cylinder Jeep Club Member #166
Originally Posted by MysticGringo View Post
This "Jeep thing" is like dating a really really hot chick, who is crazy! Its alot of fun, you spend too much money, your up all night ending up sweaty & greasy from it, your friends are jealous, you get admission into some sort of weird club... but it gets mad at your for no reason, throws fits seemingly randomly, has unexplained issues which it somehow solves on its own only after you try a bunch of different things (and spend a bunch of money) to solve it... and yet you can't resist getting in it every chance you can.
DixiesCJ3B is offline
post #153 of 455 Old 03-16-2009, 01:21 PM
2005X
if you look closely you can see where mine is mounted on the front bumper, in that recovery my winch cable was stuck so i had to use the hi lift which i was able to get to.
2005X is offline
post #154 of 455 Old 03-17-2009, 06:15 AM
erickpl
erickpl's Avatar
Top down or top removed. I've done both with no ill effects. No behind the seat storage bin. But that would affect the soft top either way I'd think (at least partially). I think the big issue with that is handling the vertical corners of the top itself, but I can either run them down into the tub or horizontally along the 'side' of the tub and still keep everything above where a behind-the-seat bin would be since the soft top frame is wider than the lower area between the rear wheel wells.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #155 of 455 Old 03-20-2009, 01:29 PM
nicajeep
wich one are u talking about?
..l___l_.oooo
/__l_l_,\____\,__
l_---l_l__l----[ ]llllll[ ]
._(o)_)__(o)_)--o-)_)
nicajeep is offline
post #156 of 455 Old 03-20-2009, 04:16 PM
YJames90
YJames90's Avatar
I still think I have the best mounting location
My 2.5 to 4.3 swap thread
YJames90 is offline
post #157 of 455 Old 03-20-2009, 04:47 PM
SHAKEnBLAKE
Does it interfere with the backseat whn you open your trunk?
Ohio4x4.com
post #158 of 455 Old 03-23-2009, 07:07 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Can anyone show me how I could mount one on my Smittybilt Rear Tire Carrier?
2016 TJ of the Year
Founder, Offroad NC
Follow our journey:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
EugeneTheTJ is offline
post #159 of 455 Old 03-24-2009, 10:29 AM
YJames90
YJames90's Avatar
I have the back seat fold down latch permantly (read broken ) set to fold.
I just push the seat forward a bit and open the trunk
YJames90 is offline
post #160 of 455 Old 04-03-2009, 09:10 PM
DJDarkGift
I've got mine mounted on the hood with the kit from Quadratec. I had it on the hood under 30 minutes.
DJDarkGift is offline
post #161 of 455 Old 04-11-2009, 01:12 AM
SHAKEnBLAKE
Yup, up in Huntsville. Shoot me a PM and we'll meet up.\
As for the McMaster site.
I got the search wrong. Try "two piece clamp on shaft collar" as the search string. You should see the 2 piece version as one of the choices on the right window pane. IIRC cage tube diameter is either 2 1/4 or 2.5". Somebody here can confirm I'm sure. Then the outer diameter is 1" extra (1/2" thick clamp x 2 'sides')
The key is to then drill tap it and fit a bolt in there. You can either shave the head off or thread the open end into the clamp once attached. You'll need some way to space it to make it secure and tight (hence the approach used in my setup).
I got this URL but not certain it will return what you want:
http://www.mcmaster.com/#shaft-clamps/=y07ym
I just went to that site and the cheapest ones are like 30 bucks! that's almost as much as the stinkin jack! Please tell me it's a 50 count or something?
Ohio4x4.com
post #162 of 455 Old 04-11-2009, 11:32 AM
DC4W-93XJ
1990 XJ Cherokee
if your going to mount it outside be sure to get a good mess of anti-seize on all the pins and springs and mechanical moving parts on the hi-lift..
i use to have mine mounted to the roof rack of my XJ.. came time to use it and the dang thing was all rusted up.. left me hangin..
THIS AIN'T YOUR MAMA'S STATION WAGON!!
Built Jeep Tough With Chevy Stuff
"Tater 2" '91 2 door XJ chopped and bobbed, 4.0, AW4, dana 300, GM 60/70HD, 40" IROKs on H1s
DC4W-93XJ is offline
post #163 of 455 Old 04-12-2009, 09:48 AM
SHAKEnBLAKE
Originally Posted by FitchVA View Post
i did some quick googling and found a link to a place that sells 'em http://www.savannajones.com/products/92200_9002.htm
80 dollars? that's rediculous. My offbrand jack cost 50. I'll be going with a homemade one when the time comes to mount it inside...
Ohio4x4.com
post #164 of 455 Old 04-14-2009, 02:01 PM
Tooch81
My only suggestion is to keep it out of the weather. They rust pretty easily and unless you carry WD40, keep it in the interior. I have mine behind my rear seat, but I'm working on a new/better location.
Tooch81 is offline
post #165 of 455 Old 04-14-2009, 07:26 PM
johnoh
mine
johnoh is offline
Hi-Lift jack location 2000TJDude General Jeep & Off-Road Equipment 0 05-31-2007 09:41 PM
High lift Jack Blaster General Jeep & Off-Road Equipment 13 11-17-2006 09:22 PM
mounting a 60" hi jack lift sahara0207 General Jeep & Off-Road Equipment 16 11-01-2006 06:45 PM
high lift jack jm708 Cheap Tricks & Fixes 15 02-07-2006 03:07 PM
Best High Jack Lift urwaker General Jeep & Off-Road Equipment 8 07-30-2005 11:46 AM
