-   Cheap Tricks & Fixes (http://www.jeepforum.com/forum/f46/)
-   -   High Lift Jack Mounting Location (http://www.jeepforum.com/forum/f46/high-lift-jack-mounting-location-229681/)
jsahara24 01-18-2006 10:36 AM
I am trying to decide where to mount my 48" High Lift Jack on my YJ? Any suggestions and pictures would be appreciated. I would like to mount it on the outside of the jeep if possible but any suggestions are welcome! Thanks
Jason
Fenix85182 01-21-2006 02:41 AM
I've seen pics of hi-lifts mounted on the hood. I believe Quadratec has a kit to do this. I'm lacking with pictures now though.
Raybz 01-21-2006 03:09 PM
I made a mount for on my front bumper
Used some square tube as spacers and threaded rod with some wing nuts to secure it
You can see where it is in this pic
http://i24.photobucket.com/albums/c4...z/DSCF0825.jpg
cheech 01-21-2006 04:03 PM
I have the hood mount,no drilling bolts right to the hood hinges.
2005RedTJ 01-21-2006 09:05 PM
I had mine on the front bumper, destroyed it by hitting a couple trees. I thought about the hood for the next location, decided I wanted it inside. I ended up getting some fence clamps from Lowe's and mounting it on the rear roll bars right above the tub. It fits great and it's inside. Cost - roughly $6.00
mferrari 01-22-2006 08:24 AM
I have the trunk thinking from DC when I bought. Simply added two bolts that bolt it down to the trunk top and makes a perfect mount!
http://www.projectferrari.com/Jeep_7_1-20-06.JPG
supaasianpdjr 02-08-2006 12:01 AM
14 Attachment(s)
I did the same thing here
http://coldwell.f2o.org/forum/customsubbox.jpg
blevinsbulldog1 02-08-2006 03:04 AM
seems like it would rust if mounted on the outside but not inside
jonster 02-10-2006 01:50 PM
Did you carpet the top of your trunk? Also did you just drill and install the bolts from the inside of the trunk? How about locking? Drill through the bolt and use a padlock. :wave:
WVMIKEsTJ 02-10-2006 02:20 PM
http://i48.photobucket.com/albums/f2...e/DSC00019.jpg
WVMIKEsTJ 02-10-2006 02:21 PM
http://i48.photobucket.com/albums/f2...e/DSC00020.jpg
Mount $2.63
JrTjK 02-17-2006 05:27 PM
my brother's neighbor has his mounted on the rear bumper...looks just like raybz's but on the back instead...i thought that was pretty interesting but wouldn't do it personally.
bloke279 02-18-2006 12:59 AM
ive got a warn front bumper, and if i find a hi-lift at the swap tomorow, im going to try an install inside of the front bumper... see how that works out, I will let you guys know...
webdr 03-05-2006 01:17 PM
yes, they will rust if mounted outside unless you cover it up. Im going to mount mine inside from now on
mr_user 03-05-2006 01:31 PM
I'm sure Grandman won't mind me posting up a pic of his YJ, but his is mounted on the hood.
The best I have...
http://img.photobucket.com/albums/v2...r/IMG_0970.jpg
The time now is 07:34 AM.
