#1 | |
Hidden garage door remote
After growing tired of no place to put a door remote due to the wedge shape of the visors I decided to hide my remote.
I took my three button "Genie" remote apart to locate the switch contacts. ![]() I took the pc board out and looked it over closely to locate the solder points for both switches. ![]() I then soldered a pair of wires to two of the switches that I wanted to use. I then put the case back together and routed the wires out a hole that was already in the case. You could leave the pc board out and wrap it with taped if you need to put it in a tighter spot, but the location I chose allowed me to use the case. ![]() I chose to locate my switches in the flat panel below the switches for my axle locker switches. ![]() This panel easily pops out at the top and has a pair or tangs that slide into a notch on either side at the bottom. I decide to locate my remote in a cavity directly behind this panel with velcro. This allows access to change the battery which should last a couple of years. ![]() ![]() I used a couple of "momentary" switches from radio shack part #275-0644 for the new buttons. This requires drilling a 1/2" hole for each one in the panel, but you must pay attention to where it goes in order to have depth for the back of the switch when you put the panel back in place. I then soldered the switches to the ends of the wire and placed the remoted in its location behind the panel and tucked the wire out of harms way and re-installed the panel. ![]() Regards, Tony
#2 | |
formerly VetteDriver
- Bill (formerly VetteDriver) |
#3 |
Hey, thanks. I've been planning on doing this - just have not gotten around to it. Now that I have instructions, I am more likely to get on it (:
I'll probably do this in a few weeks when I wire in the trailer brake control and a couple of accessory switches in this same location. I only need the big main switch to work though - just have the one garage door. Can you please update your photo to show which solder point corresponds to the big button? I've got the same remote (: Thanks! td |
#4 |
F'ing brilliant. Wish I had a garage to put a garage door on.
2007 Jeep Wrangler Sahara Unlimited 2 1/2" Rough Country Suspension Lift 35" Nitto Terra Grapplers AT Pro Comp 1069 Wheels |
#5 |
wow...
you know you can put them inside the rollbar padding above your head? Right? The genie remote fits perfectly in the space. Reach up and feel the rollbar. You will feel an indention.... thats where the remote fits
2007 JK Unlimited Sahara 2.5" Teraflex Budget Boost, 1" MORE Body Lift, KC Slimlights, ProComp 7047 Wheels, 305x65x18 (34's) BFG AT KO's, Airraid CAI, Riddler Differential Covers, Headlight & Taillight guards, etc... |
#6 |
Gold Member
That is way cool. I have the same remote, but also only use one button..... mine is here:
#7 |
SE Expedition Society
Neat idea; thanks.
My remote is living in the sportbar padding right now.
Safety fast, Bill I have never been lost, but I will admit to being confused for several weeks. I was happy in the midst of dangers and inconveniences. Daniel Boone Overland Rallies & Workshops ** Overland Expo 2012 |
#8 |
Beer is Food!
I really like this idea. I currently have mine double-sided taped inside of the center console on the little lip in the front. It can be a little awkward to use somtimes, but its fairly stealth for a would-be theif.
While it hasn't happened to me, Opener + Registration (address) theft has become rampant in NorCal. More important than the convenince is the anti-theft nature of the permanent install. Good Work!
2008 Silver Rubicon Unlimited - 6-Speed, Rock Krawler 3.5 Flex, 35" MTR/K's, Bilstien 5100's |
#9 |
I just bought a keychain remote for $25 at the Home Depot. It never gets stolen from the Jeep when the top is down, it never falls off the visor, and when I use the remote start to warm up the Jeep in the winter, I can open the garage first to avoid the fumes building up.
#10 |
i use to have a nissan frontier and i took my remote appart and wired it into the hi beams on the headlights... that way when you approach the garage door all you have to do is flash the hi beams once and the door opens. it was a pretty easy install. just my 2 cents!
#11 | |
Thanks for the idea (: |
#12 |
Hey Guys...new to the site but not to the jeep...lol...well cruzing thru here looking for something and saw the garage door opener ideas....well i thought i was the only one that was tired of that little box...well I have home automation in my house which is remote and voice controlled lighting etc and thought about how cool it'd be to have Home Link in the new Sahara...well i took the garage remote apart and a x-10 automation remote apart and took the section over the mirror down and drilled holes and lots of x-acto blades til i had a custom Home Link built right in my BABY. All you see is the round buttons and a light .I just had to add that little extra...lol...right now I"m doing leather and vinyl custom trim on the MyGig, a/c area and lots of other areas to give it that reddish brown western look that looks so hot on my girl that is rocky red...will post pics if any interested..keep up the great forum guys
#13 |
I guess I am just lazy. I put mine in my glove box. The clip works on the side of the box to keep it from getting lost.
DoDco Dan 2007 Wrangler 4dr and other toys |
#14 | |
2001 XJ... 3.5" RE Lift, 31" BFGs, Bilsteins, Defender roof rack, Dana 30 HP front True Trac and 4.10s, Dana 44 Rear True Trac 4.10s, SYE, tom woods D/S, SUPER CLEAN LOW MILES |
#15 |
I like the button up high like this one. Good job.
2009 JK Rubicon. Auto, Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear; 11,000# Pull-Pal, Uniden 520XL CB with 3' FireStik Whip. Shrockworks Mid-width Front Bumper with Warn 9.5Ti -- Ordered 7/17/2009; Bumper Received 12/4/2009. Visit here to view my wheeling Pics: Moab-4/2006, 5/2008, 4/2009, 5/2011; Ouray-8/2007, Rubicon-9/2008. http://community.webshots.com/user/thunder1strike |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
