Help! No heat in my TJ - JeepForum.com
post #1 of 4 Old 01-02-2013, 03:54 PM Thread Starter
gregorydeal
I've lost all heat in my 2001 Wrangler. I've replaced the blower switch and resistor. It will blow a bit when I'm moving, but that's it. Before that it would only blow on high. I live in Pittsburgh, and it is super cold. Thanks for any help!
gregorydeal is offline
post #2 of 4 Old 01-02-2013, 08:24 PM
trakwrkr
I'm not a mechanic, it it sounds like the fan to me.
I'm having a similar problem, it blows luke warm and blows only on setting 2 & 4. I was told to try flushing out the heater core or replacing it. I'm just waiting for a warm day to flush, I'm in WV
2000 tj
trakwrkr is offline
post #3 of 4 Old 01-02-2013, 08:26 PM
lozzib
Something is loose on my to causing similar issue. I reach through the glove compartment door and wiggle the connector and the heat goes on. Mine seems to be the switch connector that goes to the location selector switch. I need to make time to pull it open to have a closer look. I am in New England and is below freezing here as well. Give it a shot!
lozzib is offline
post #4 of 4 Old 01-03-2013, 09:17 AM Thread Starter
gregorydeal
I'll give that a shot today! Thanks.
