Heat Question - JeepForum.com
post #1 of 11 Old 10-27-2012, 10:41 AM Thread Starter
chodge40
Heat Question
Heater is putting out warm air instead of Hot . Any fixes for this? Thanks
chodge40 is offline
post #2 of 11 Old 10-28-2012, 05:12 PM
festerw
festerw's Avatar
Check the coolant level if it's ok then pull the heater hoses and try flushing the core with a garden hose.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is online now
post #3 of 11 Old 10-30-2012, 03:14 AM
Maverickxeo
Thermostat could be a good place to start.
Maverickxeo is offline
post #4 of 11 Old 10-30-2012, 07:40 AM
Whizzerbike
Go to the self-serve car wash.
Unplug your heater core.
Hook up the pressure washer to the top/bottom and blow that gunk out of there!
She thinks my JEEP is SEXY!
Whizzerbike is offline
post #5 of 11 Old 11-06-2012, 11:31 PM
mscottz
2011 JK Wrangler
Then go buy a new core to replace the one you just destroyed...
Colorado Jeep Club member #1969
mscottz is offline
post #6 of 11 Old 11-07-2012, 06:32 AM
mt585633
So what is the fix for the heater? I'm having the same problem. How do i get my heater to heat.
mt585633 is offline
post #7 of 11 Old 11-07-2012, 06:33 AM
mt585633
Without destroying it would be great.
mt585633 is offline
post #8 of 11 Old 11-07-2012, 08:53 AM
Diverdown87
http://www.jeepforum.com/forum/f9/he...hotos-1266369/
My idea of help from the man above is a sniper on the roof.
Diverdown87 is offline
post #9 of 11 Old 11-08-2012, 09:39 AM Thread Starter
chodge40
mt
I removed the heater core from the radiator end the top and the one right under it. While engine is cold. Get water hose (I use the nozzle) sprayed water through the lower hose blowing the crud out the top hose. I did this a few times until the water was clear coming out. The Heat is working. Next I plan on flushing the radiator because if it was in the core it's in the radiator also! Hope this helps
chodge40 is offline
post #10 of 11 Old 11-10-2012, 10:26 PM
cory4um
Now this is far fetched and not sure if this can work on a I6 engine. But anyway for future reference on any vehicle you may need to do this too for cheap.....
Friend has an early 90's V8 dakota that puts out poor heat. He modified the line from near the thermostat to the heater core. Used rubber hose that went form the stat and routed it to towards the exhaust manifold. When at the manifold he went to a copper pipping line that ran right next to manifold (using the heat from the manifold to heat the copper pipe) thn back to rubber to the heater core. He also used a ball valve to adjust flow/ heat to the core. Works great!!
He plans to wrap the manifold and copper pipe together in heat wrap to keep the heat in.
cory4um is offline
post #11 of 11 Old 12-29-2012, 07:21 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
most newer vehicles require certain temp thermostats, check to see if yours is opening all the way.. lots of if's with a heater for sure, but a thermostat controls what heat goes into that heater core... there again, if the heater core, hoses, or anything else is plugged, well..... another thing, if you have to change that heater core, definately look into the fan motor upgrade.. WOW, what a difference it made on mine..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
