Hand throttle - Page 3 - JeepForum.com
post #31 of 69 Old 12-01-2006, 10:58 PM
Weekender1969
Originally Posted by Airborne4X4
This is the part from my junk draw that worked perfectly. If you know what it is, tell us. I have no clue what this little metal piece is "supposed" to be used for. Whatever it is, it worked. I got a few more I could mail out to somebody if they're interested. Just cover the shipping and one of them is yours.
Any way here's some pics.
First is it installed. I basically cut the cable to lenght then threaded the homemade bracket down the cable until it what right. Then I bolted it in and was done.
That blue "X" is where I drilled a hole just big enough for a nut and bolt I had.
Good luck,
J
Those are clamps, I have them on my pickup. They were installed by a accessory dealer who used them for "no drill" bed cover install.
Weekender1969 is offline
post #32 of 69 Old 12-01-2006, 11:32 PM
CNY
Caught ridin' dirty
CNY is offline
post #33 of 69 Old 04-17-2007, 09:00 AM
SpoiledRotten
SpoiledRotten's Avatar
Originally Posted by Timfromjersey
are they legal everywheres? I am in New Jersey and i would want to do one
Why wouldn't they be legal? If you look in a handicap's van, they have full hand controls if parralized from the waste down. My paw-n-law uses hand controls for brakes and accelerator in his van. Pulls the race car around with the van.
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline
post #34 of 69 Old 04-18-2007, 01:32 PM
jeepamongzukis
Nice project! I can definatly see where a hand throttle would be good for restarting on a steep incline. Those tabs could be sink clips, but they also look exactly like the tabs used to hold a removable glass/screen door in place.
jeepamongzukis is offline
post #35 of 69 Old 04-26-2007, 11:03 AM
Heepajeep
Hand throttles are needed for the handicappers that do not have use of their legs and still drive.
With the control mounted to the shifter, does it effect the throttle when you shift?
And is the control lever the throttle or speed control off a self propelled lawn mower?
Looks good tho.
nevermind, you answered the source question while I posted the above.
I used a pto type pull-and-twist-to-lock cable on my CJ but it was an much easier install thru the sheet metal dash and firewall straight thru to the carb linkage.
Heepajeep is offline
post #36 of 69 Old 06-09-2007, 08:56 AM Thread Starter
Airborne4X4
Airborne4X4's Avatar
1948 CJ2A
Tandem ten speed bike gear selector, not from a mower. Although, you could probably make one of those worked if you did some engineering.
1948 CJ2a
Airborne4X4 is offline
post #37 of 69 Old 06-09-2007, 11:54 AM
ckowennos
Nice write up man, looks like a clean job. I did this to my XJ yesterday b/c I am going on a 7 hour road trip next weekend and wanted some cruise control.
ckowennos is offline
post #38 of 69 Old 09-20-2007, 04:56 PM
Scotch740
Scotch740's Avatar
Made my own, very happy with it.
Scotch740 is offline
post #39 of 69 Old 05-19-2008, 06:01 PM
O2GO4LO
That looks like a clip used for installing "storm window" or "winter glass" on a screen door. The screen comes out of the frame, and the storm window goes in, those look like the clips for securing them to door. BTW- good idea, that why I maintain a quality junk drawer (at least one) at home too!!!
<---- TJ boot camp...A MUST READ!!!
Been there and back, and always in a JEEP!
Black Jeep Society Member #45
San Diego Jeep Owners Club Member #33
O2GO4LO is offline
post #40 of 69 Old 05-28-2008, 11:42 AM
off-road man
What about when you are not using it does ot affect the operation of the foot pedal at all?? I thought that maybe the shifter would have to much tension to let the pedal move easily.
off-road man is offline
post #41 of 69 Old 05-28-2008, 11:56 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
not at all-- when the hand throttle is not in use, it sits, um... idle. the carb/intake linkage moves and the hand cable stays stationary-- until u need it by activating the shifter mounted lever. Do not use it for cruise control. Leave pleanty of slack in the line because if its too tight, some body or suspension flex can cause the hand cable to affect the throttle.
GL!
mb
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #42 of 69 Old 05-28-2008, 03:28 PM
CopperCJ7
I wound up buying the Teraflex version of this off my buddy for $20 and have yet to install it. It looks fairly simple though.
Jeep Wave
Guns don't kill people... Bad trail spotters do.
What CJ owner doesn't want to hack up his harness for the next owner to have fun with?
Originally Posted by Broseph View Post
The thread will derail quicker than a walrus on a Crisco-soaked Slip 'n' Slide.
CopperCJ7 is offline
post #43 of 69 Old 03-04-2009, 11:26 PM
O2GO4LO
Did it, Love it. i bought the indexed version (sounds like a little ratchet when I use it) but can adjust the tension of the indexing action with the thumb nut on the end. best 20 bucks I ever spent. I used an electrical connection (the circle one...lol) and a cotter pin to retain the cable on the throttle.
It's especially great for long freeway trips to give you gas foot a break without sitting weird....lol
O2GO4LO is offline
post #44 of 69 Old 03-09-2009, 09:00 PM
buckshot500
Cant remember where, but I saw this mod somewhere else.
They used a small (like 3") section of stainless steel bead chain, between the throttle lever (on the carb) and the end of the cable.
When the throttle is closed, there was a little slack in the bead chain.
This would prevent any throttle movement, due to body flex.
EDIT; after two hours of google searching, I found this;
http://www.tmcom.com/~tsm1/scout/faq/handthrottle.html
buckshot500 is offline
post #45 of 69 Old 03-11-2009, 03:00 PM
YJMCBoy
YJMCBoy's Avatar
2010 JK Wrangler
I have those clips too- except the ones you are referring to are a lot larger. I was thinking the same thing until I saw the pic of the clip next to the quarter, mine are a bit smaller than a dollar bill.
2010 JK 4-Door Unlimited Sport- Soft top, V6, 6-speed standard, bone stock for now
YJMCBoy is offline
How do you like your Hand Throttle? Edward777 Engines & Drivetrain 2 01-29-2008 03:49 PM
RE Hand Throttle TellyDSP General Jeep & Off-Road Equipment 21 06-13-2006 08:57 AM
hand throttle position LoneJeeper General Jeep & Off-Road Equipment 14 01-12-2005 07:55 AM
Anyone installed a Hand throttle? qadhafi General Jeep & Off-Road Equipment 7 08-31-2003 11:18 PM
Less touchy hand throttle desertjeeper Fabrication Shop 7 05-07-2003 01:58 PM
