Hand throttle - Page 2 - JeepForum.com
post #16 of 69 Old 09-07-2006, 07:18 PM
Hopper_
Anyone ever seen one of the floor mounted ones that re use in semis in a Jeep? i have a friend with one in his trail only Bronco and I'm thinking of putting one in the Jeep.
These things are one of the very best mods you can make to any manual tranny equipped vehicle. They make rocks 110% easier. Also good for cruise control.
Hopper_ is offline
post #17 of 69 Old 09-08-2006, 02:26 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
in addition to the 3rd foot, it helps run up and keep RPMs steady for either running the premier power welder or to air up tires w/ the york driven OBA. Only caution is if u have extreme flex, i found it pulled the cable and caused unwanted RPM jumps. Still, worth the $10 for the bike store parts.
mb
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #18 of 69 Old 09-08-2006, 01:02 PM
nailhead
Those are screendoor clips, used to hold in the glass or the screen, depending on the season. Het themn at home depot. Careful though, they are aluminum and are thin on the one end.
Steve
nailhead is offline
post #19 of 69 Old 09-10-2006, 04:53 PM
1stJeepyj
Doesn't it bend the cable each time you press the gas pedal? Does it give any resistance to the pedal? Besides my concerns, it looks like a great install and I'm going to copy.
Thanks, Glenn
95 YJ, 2.5L, 32x11.50x15 Dunlop Mud, MSD ignition, 4.0 throttle body w/spacer, Black all rattle can, Taurus electric fan, K/N cone filter, 2" BL, 1" H/D shackles, 1.5" Black Diamond suspension lift, soft top, Harbor Freight 8000Lb winch, Pioneer CD reciever w/4 speakers, Cobra CB, Posi-Loc, Coca Cola Bottle opener, custom rear bumper, 48" Hi-lift Herculined tub, 11 lights in front and two backup driving lights
1stJeepyj is offline
post #20 of 69 Old 09-10-2006, 05:03 PM Thread Starter
Airborne4X4
Airborne4X4's Avatar
1948 CJ2A
When the hand throttle is in it's resting postion, applying throttle with the gas pedal is no problem. The wire cable from the hand throttle just bends up and out of the way. When you engage the hand throttle, the gas pedal's wire cable just bends out of the way. So, when doing this installation, cut the sheath (the black outer portion of the hand throttle cable) several inches back from the attachment point on the throttle body. Four inches of exposted wire should be enough.
1948 CJ2a
Airborne4X4 is offline
post #21 of 69 Old 09-10-2006, 05:17 PM
tommaho
tommaho's Avatar
Steve
I considered that too, but the machine screws are way too long to be useful on a screen door.
tommaho is offline
post #22 of 69 Old 09-10-2006, 10:31 PM
1stJeepyj
One more stupid question, Where did you get the cable and lever? What is it?
Thanks, Glenn
post #23 of 69 Old 09-10-2006, 10:37 PM Thread Starter
Airborne4X4
1948 CJ2A
Thanks, Glenn
The lever is a non-indexing gear selector off of a ten speed bike. The cable is a ten foot in lenght...from a tandem bike. Although you might be able to use a shorter wire. I chopped about 3 or 4 feet off of it. I should have measure the piece I cut off, but it was in the trash and gone before that thought crossed my brain.
1948 CJ2a
post #24 of 69 Old 09-12-2006, 05:10 AM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
i'm afraid to do this, because i'm a wuss, but the cruise controll would be a great thing. why not for 10 bucks.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #25 of 69 Old 09-15-2006, 09:02 PM Thread Starter
Airborne4X4
1948 CJ2A
Don't be afraid. Do the 30 minute install. If you don't like it, do the 5 minute uninstall. That simple.
I got over my fear when I took a jigsaw to my corners during the LED stoplight mod.
Don't turn away from fear, get in front of it!!!
1948 CJ2a
post #26 of 69 Old 09-15-2006, 09:40 PM
TJ on the Rocks
TJ on the Rocks's Avatar
Good job Airborne4x4 ! I've had the RE version setting around in the box it came in for like 2 years now . Yours looks better
TJ on the Rocks is offline
post #27 of 69 Old 10-11-2006, 07:28 PM
kevin A Whitler
The spring on the Throttle body, does it have the tension to pull the lever back in place or does it stay in wahatever position you place it?. I would like to do this to my YJ, and use as cruise.. Whats your thoughts? If the spring pulls the throttle lever back, What about a PTO locking cable?
kevin A Whitler is offline
post #28 of 69 Old 10-20-2006, 08:53 PM Thread Starter
Airborne4X4
1948 CJ2A
The stock spring on the trottle body doesn't have the strength to pull the hand throttle closed. Once you lever up the hand throttle to the RPM you want, it stays there.
1948 CJ2a
post #29 of 69 Old 10-31-2006, 01:55 PM
dr hook
great writeup, i bought my gear selector/ cable last wee and just haven't had time to hook it up yet.
Lifted ZJ with stuff.
dr hook is offline
post #30 of 69 Old 10-31-2006, 05:59 PM
KrazyGimp
1982 CJ5
Originally Posted by AZG23
...As for the shaky trail/throttle pedal problem...next time you are out on surface like that..find the correct speed you want, and push your foot into the transmission hump...hold your foot against the hump instead of trying to hold down the gas...try it...youll be amazed how much smoother it is...
Good recomendation. This works extremly well with a Herculined tub. Your foot wont slip at all. Sometimes I try to push the gas down and can't figure out why I can accelerate, it's because my fat foot is sticking to the tranny hump . Another trick I have used is to get some heavy duty throtle return springs. It takes quite a bit of force to move the gas pedal down, resulting in less throttle blips when you hit a bump.
Props to the OP for a super clean install though. It almost looks factory!
1982 CJ-5 Laredo 258, T-176, D-300
1972 240z in pieces...
Originally Posted by BESRK
...that's why you push in that little nipple (hehe.. I said nipple on the internet :D )
KrazyGimp is offline
How do you like your Hand Throttle? Edward777 Engines & Drivetrain 2 01-29-2008 04:49 PM
RE Hand Throttle TellyDSP General Jeep & Off-Road Equipment 21 06-13-2006 09:57 AM
hand throttle position LoneJeeper General Jeep & Off-Road Equipment 14 01-12-2005 08:55 AM
Anyone installed a Hand throttle? qadhafi General Jeep & Off-Road Equipment 7 09-01-2003 12:18 AM
Less touchy hand throttle desertjeeper Fabrication Shop 7 05-07-2003 02:58 PM
