Free air intake - JeepForum.com
post #1 of 11 Old 02-21-2006, 04:39 PM Thread Starter
05F150
Free air intake
This is an ol trick that has been created by fellow stang owners and f-150 owners. What you do is disassemble the air box. Take a 3/8" drill bit, of course when you do this remove the air filter as well, and drill as many holes as possible. This should create a " swiss cheese" effect in your box. Put everything back together and whalla! Free intake. You just increased your air flow to about 85% and it has been dyno proven to work. My buddy did it in his stang and got about 12 hp to the wheels!!!! He also added the K&N air filter as well and it definitely helped him out.
05F150 is offline
post #2 of 11 Old 03-27-2006, 10:58 AM
Mr. Tobes
Nice. Now all I need is an airbox.
Mr. Tobes is offline
post #3 of 11 Old 04-03-2006, 08:38 PM
drew01929
I have been doing this to dirtbikes for years, and it usually works pretty well.
drew01929 is offline
post #4 of 11 Old 04-03-2006, 09:39 PM
Andrew F
Why is this posted twice? It's hasn't even made it to the second page yet.
http://www.jeepforum.com/forum/f46/free-air-intake-241677/
04 LJ
4.5 RE SF w/ 3.5 springs
32x11.50R15 BFG MT
4.88, Lock Right F/R
Red Jeep Club Member #347
Andrew F is offline
post #5 of 11 Old 04-03-2006, 11:21 PM
dr_phatcity
dr_phatcity's Avatar
Didn't someone complete a whole write up about how Jeep's are not starved by air intake and don't benefit much from changing the air intake dynamics
Also, if you are offroading your jeep and are drilling holes in the air filter -- don't you have to get TONS of dirt and dust in there -- sounds like a bad idea to me.
dr_phatcity is offline
post #6 of 11 Old 06-03-2008, 10:53 PM
zacjeff
just take the whole box out and put in a cone filter
zacjeff is offline
post #7 of 11 Old 07-22-2008, 01:56 PM
4jeepers
I am not positive but would this modification pass a visual inspection for smog in a state like California?
4jeepers is offline
post #8 of 11 Old 07-22-2008, 04:54 PM
flatlander757
Sounds like a good way to suck up water or mud
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #9 of 11 Old 07-23-2008, 06:44 AM
SOLOLUCKY
I was thinkin the same thing..mud, water, dust, welcome to my airfilter.
and also it's hot, underhood air. Not the best intake air...ya want COOL air. Thats whay it's called a "cold air intake".
SOLOLUCKY is offline
post #10 of 11 Old 07-23-2008, 06:47 AM
Luckyduck
I ran a bit with no air filter or piping what so ever just an open throttle body and noticed no change.
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build
Luckyduck is offline
post #11 of 11 Old 07-23-2008, 07:01 AM
Diehard
Diehard's Avatar
Not that I agree with this, but the area the holes would be drilled is below the filter so the air still would be filtered, but the filter would need to be changed more often, and this mod would increase the chance of more water to be sucked in if the box gets under water.
2004 GC Spec. Edit. V8 4x4 Quadra-Trac II. Bright Silver Metallic Clear Coat, 4" lift, RE shocks, adj. JKS CAs all around, 265/75/16, ProtoFab winch bumper, Vortex 10,000 lb. winch, dual OME steering stabilizer, Rockyroad rockrails, skids, JKS Discos. Addco front & rear sway bar, & Aussie locker.
Diehard is offline
Enclosure vs free air absentiabanish Audio, CB & Ham Radios, GPS, & Electrical 3 07-26-2007 10:47 AM
Free Lockers?? DamiJab General Jeep & Off-Road Equipment 24 02-21-2007 10:57 AM
Free air intake 05F150 Cheap Tricks & Fixes 29 03-22-2006 11:28 PM
Intake Development Free Intake F1sprint Engines & Drivetrain 6 02-13-2006 10:40 AM
Just got a free sub, and i need help EJames1226 Audio, CB & Ham Radios, GPS, & Electrical 20 08-30-2005 10:36 PM
