fire extinguisher - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > fire extinguisher
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 07-08-2008, 07:12 PM   #1
eagles4094
fire extinguisher
has anyone done a homemade mount?
eagles4094 is offline   Reply With Quote Quick reply to this message
Unread 07-12-2008, 11:57 PM   #2
athos76
I havent used it, since I bought a velcro mount, but some thick zip ties, and a 1" piece of aluminum angle at the bottom to keep it from slipping out... Just zip tie the aluminum angle down, then rest the bottle and Ziptie the bottle down tight enough to where you can still slip it out. That how my friend does it.
athos76 is offline   Reply With Quote Quick reply to this message
Unread 07-13-2008, 01:27 PM   #3
eagles4094
thanks....
Unread 07-31-2008, 05:03 PM   #4
metallatem
water bottle holder from a bike !!!
works great with small ones
get a set of BFG KM2s
metallatem is offline   Reply With Quote Quick reply to this message
Unread 01-22-2009, 07:34 AM   #5
donutsrd
some large zip ties and velcro straps from hardware store.
donutsrd is offline   Reply With Quote Quick reply to this message
Unread 01-22-2009, 09:51 AM   #6
Happy Joe
For roll bar extinguisher mounts I just hose clamp the plastic mount that comes with the extinguisher to the roll bar.
Mine currently resides in the plastic mount screwed to the floor beside the driver's seat.
I have also used Velcro "Onewrap" (great stuff!) to secure the extinguisher to the driver's seat floor mounting angle.
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline   Reply With Quote Quick reply to this message
Unread 01-22-2009, 07:57 PM   #7
Jeep2003
1946 CJ2A
http://www.earlycj5.com/forums/showt...ght=fire+mount
1967 cj-5, 1946 Willys Jeep cj-2a, 1982 911sc turbo look, 1958 impala, 1987 k5 blazer
Jeep2003 is offline   Reply With Quote Quick reply to this message
Unread 01-22-2009, 08:07 PM   #8
jay-h
guys!!!!!
Please don't use a mount designed for a house, or plastic ties, or water bottle mount!!!
In even a relatively low speed collision that extinguisher becomes a lethal weapon. Use a mount designed for a vehicle (or make one equivalently strong).
jay-h is offline   Reply With Quote Quick reply to this message
Unread 01-22-2009, 10:31 PM   #9
Fire651
Originally Posted by jay-h View Post
guys!!!!!
AGREED!!!!!! From a firefighter who has seen a fare share of accidents, the last thing you need is another projectile during an accident. The same goes for cheap extinguishers (ones with the plastic pin/head assembly), steer clear, too many can be easily activated once the pin is dislodged or the head is snapped.
Fire651 is offline   Reply With Quote Quick reply to this message
Unread 01-22-2009, 11:00 PM   #10
rkwfxd
guys!!!!!
X3 additionally, I have read a number of posts about extinguishers and the general consensus is you need at least a 5 pound bottle to do any good at all in a vehicle fire. This is from those that have actually put out fires and professional fire fighters. The size of a 5 pound bottle pretty much dictates a bottle/vehicle specific mount.
rkwfxd is offline   Reply With Quote Quick reply to this message
Unread 01-23-2009, 08:39 AM   #11
flyboy14295
Coming from a firefighter, any small extinguisher that you will be able to easily mount and is probably a dry chemical extinguisher will just make a mess and not really do much. If there is smoke coming from the hood, leave the hood closed and get away from the car. The hood will restrict the airflow to the fire and slow the extension down a little.
I have a 2 1/2 pound dry chem extinguisher in the house mount that has been reinforced with much stronger metal.
WJ. 4.Slow I6. The Underdog
2" Teraflex BB, 265/70R16 BFGoodrich TA KO's, JKS Adjustable Track Bar, JKS HD Tie Rod, Rusty's Tow Hooks, Block Heater, CB
New York City EMS
Originally Posted by LoneJeeper View Post
I came into this world via broken rubber, i'm not going out the same way.
flyboy14295 is offline   Reply With Quote Quick reply to this message
Unread 01-23-2009, 11:09 AM   #12
Happy Joe
Contrary to the above posts; I have successfully used small extinguishers to put out small fires (use your intelligence when dealing with fire and flammables, as well as at all other times).
"Run away" is not valid advice for most circumstances in life. Instead; evaluate the circumstances and assess your chances of success versus the possible risk to yourself and others.
I have also been in several collisions with extinguishers in the vehicle and not one has not come loose; mounted to the floor, my current extinguisher is unlikely to cause a problem if it did. I do agree that the extinguisher should be accessible and securely mounted; though. Again, use your intelligence.
If you want to live in a rubber padded world and helplessly depend on others for your life and well being; go ahead, but simple precautions will work, at least part of the time.
Just my $.02.
Enjoy!
Unread 01-23-2009, 05:40 PM   #13
careyfl
Right on Happy joe.
careyfl is offline   Reply With Quote Quick reply to this message
Unread 01-23-2009, 06:42 PM   #14
Jeep2003
1946 CJ2A
right on x2 . notice the newer jeepers comments from the older jeepers
Unread 02-01-2009, 07:53 AM   #15
DEET
So what your saying is I should stand there on the trail and watch my vehicle slowly burn to the ground instead putting it out with a fire extinguisher? Seriously folks 99% of the time when you detect a vehicle fire it's still very small and can easily be put out with a small extinguisher. Where as maybe 1% of the time the fire department will be able to put it out in time to still be able to recognize what your vehicle was. I for one have never seen a fire truck on any of the trails I have run.
Beer is proof that god loves us and wants us to be happy.
BLACK JEEP SOCIETY MEMBER
DEET is offline   Reply With Quote Quick reply to this message
