fender flare paint! - Page 2 - JeepForum.com
post #16 of 36 Old 08-16-2009, 04:29 PM
kswyg001
2010 JK Wrangler
heat is a NO-GO. you will get weird spots in the plastic where you overheat it. i tried, it doesnt work. dont use heat. i painted mine on the jeep with Krylon Fusion Satin Black. washed them with dishsoap and a scrubby pad, rinse and dry thoroughly. mask the hellllll out of everything else. overspray is ridiculous. i unfortunately did not mask all that well and i have black overspray all over the jeep. no sanding is needed, no primer (krylon says no primer) and deff take your time. nice even strokes and make sure you let it dry before you drive it. i didnt let mine dry totally and now i have bugs embedded in the paint.
kswyg001 is offline
post #17 of 36 Old 08-17-2009, 02:32 PM
13mx
Yeah I used alot of newspaper when I painted mine. I prolly should have cleaned them up a little better than I did. I would use some aceatone if I did it again.
13mx is offline
post #18 of 36 Old 08-17-2009, 09:17 PM
Solidsyko
1995 XJ Cherokee
If I were to do it again I would mask and paint. I took them off to paint and it was a major pain in the butt as most of the mounting bolts broke off. Just something to think about.
Solidsyko is offline
post #19 of 36 Old 08-18-2009, 07:06 PM
RKBA
I have used three paint products for Jeep black plastic trim over the past eight years: Krylon Fusion Satin Black, Rustoleum Textured for Plastic and Duplicolor Flexible Bumper Paint. The Duplicolor looks better, coats more evenly and lasts longer. It stinks to high heaven and takes a little longer to dry, but in my experience is a superior product in the rattle bomb solution to flare fade.
It also looks good on......
the bumpers
2002 TJ SE
2006 LJ
2007 Rockwood Freedom 2280
RKBA is offline
post #20 of 36 Old 09-29-2009, 01:25 PM
robtre
I have painted fender flares but I want to make them Black, how much do I have to sand them down before I can re-paint?
His:2005 Wrangler Rocky Mountain Edition
Hers:2005 Grand Cherokee Laredo
robtre is offline
post #21 of 36 Old 09-30-2009, 03:01 PM
jeepgurl775
Can I use that on the side trim too? My XJ is red and all the trim is silver, but its so worn and faded you can see the red in places.
jeepgurl775 is offline
post #22 of 36 Old 09-30-2009, 08:08 PM Thread Starter
WalrusPaul
yeah you can use it on the side trim, shouldn't matter.
Krylon fusion is a no-sanding-required product. Scuff it with FINE sandpaper if you really want to.
I did it to mine, and it turned out real nice with the krylon fusion, haven't tried the flexible bumper paint mentioned above.
The 350 YJ on dana 44's. :
Looking for a set of four 35-37" tires you want to sell. PM me!
WalrusPaul is offline
post #23 of 36 Old 09-30-2009, 08:51 PM
jeepgurl775
Right on, I can't wait to try it out!
post #24 of 36 Old 10-01-2009, 03:52 PM Thread Starter
WalrusPaul
even if it does fade in say, 2 years, how bad is it to take another 4 hours or so to fix it again.
post #25 of 36 Old 10-08-2009, 12:58 PM
greensaharatj
Just curious have any of you guys done this to the stock painted flares? I have the green ones that come with sahara edition, will the black paint work ok or should I do something else to them first?
2003 Jeep TJ w/RC 3.25 lift rockin 35x12.50r15 Dunlop Mud Rovers on Crager Soft 8's, Currie HD Steering system, Delta Quad-Bar headlights, KC 55watt fogs, 130watt long range KC daylighters on the windshield, Smittybilt Tube Fenders, Smittybilt X20 10k Winch, Poison Spyder front Stinger--future stuff, SYE/CV Driveshaft, Rear corner armor, Engine/Oil skid, Tummy Tuck
Don't forget to wave :wave:
greensaharatj is offline
post #26 of 36 Old 10-08-2009, 01:06 PM
motown2
1992 XJ Cherokee
I USED DUPLICOLOR TRUCK BED COTAING....SCUFFED IT FIRST W/ LIGHT STEEL WOOL AND MASKED THE CRAP OUTTA IT.....HERES THE BEFORE AND AFTER (SCROLL)
http://www.jeepforum.com/forum/f177/...8/#post8002092
92' Cherokee Laredo-33's, snorkel, 3.5" Lift
98 Camaro Z28-H/C, Suspension, 3.90's
motown2 is offline
post #27 of 36 Old 10-11-2009, 07:22 AM
karlo
Duplicolor bedliner is more durable than using paint, though it seems to fade quicker when exposed to elements.
karlo is offline
post #28 of 36 Old 10-26-2009, 09:06 AM
hoytpotater
I used the krylon fusion and it worked great. I used printer paper and masking tape behind the flares. It took all of 1 hour to complete.
hoytpotater is offline
post #29 of 36 Old 11-08-2009, 10:19 PM
97wrang78
Krylon -- all the way. I even used it to repaint my tan soundbar cover black. The cover is made from nylon which is plastic. It took quite a few coats to cover all the nooks and crannies, but 2 years later it still looks great.
It will feel slightly sticky for about a week afterwards.
Whoever thought it was a good idea to give the Jersey Shore cast a TV show should be stabbed....... repeatedly........ every day....... for the rest of his life.
97wrang78 is offline
post #30 of 36 Old 06-24-2012, 12:48 PM
adammendelsohn
1990 XJ Cherokee
I'm gonna re-paint my fender flares with Krylon Fusion - It's a white & Chrome 1990 XJ so the fender flares are grey/silver. Does anyone know what color code that is? As in, what color Krylon should I use to get the original silver/grey stock color back on the fender flares/body trim/bumper caps?
adammendelsohn is offline
Fender Flare Gap/Sag? willydigger General Jeep & Off-Road Equipment 6 07-24-2008 06:05 AM
OE Sahara fender flare 98tjsahara General Jeep & Off-Road Equipment 1 09-12-2007 02:55 PM
Fender Flare question 99cherokeexj Street Jeep Forum 2 08-09-2007 10:20 PM
Need fender flare advice pfd53 General Jeep & Off-Road Equipment 5 03-28-2007 07:31 AM
retaining that new fender flare look ? TJ on the Rocks General Jeep & Off-Road Equipment 13 09-10-2006 12:02 AM
