Extremely unique and confusing problem - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Extremely unique and confusing problem
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 01-16-2015, 02:19 PM   #1
kissmeimLoveles
2003 WJ
I've got a 2003 Jeep Grand Cherokee with 160,000 miles on it. The problem I have is I've got a bad catalytic converter, my mechanic said that my Jeep is from California so I've got to replace it with another California cat which is 700 dollars. I've found that a normal 49 state cat is like 250.... I live in Utah so I would really like to find a way to put on a normal 49 state cat but, I've been told that the check engine light will still come on because my ecu is tuned to the cali standard.... Anyone have a solution to this problem? I just want to install the 49 state cat!
kissmeimLoveles is offline   Reply With Quote Quick reply to this message
Unread 01-16-2015, 04:02 PM   #2
mike_dippert
hodophobic
mike_dippert's Avatar
I think your mechanic may be trying to milk you. Verify with other GC owners first, but any cat designated for your vehicle should make the computer happy. The California version parts are so pricey b/c they need to be CARB certified, that costs money.
You can't argue with ignorance.
Originally Posted by HurricaneRZA View Post
JF taught me that the 2.5L, Ax-5 and D35 together are so powerful that angels weep when I shift into 4LO.
The only thing a bicycle inner tube is good for, is tying a knot in the end of when you run out of condoms.
mike_dippert is offline   Reply With Quote Quick reply to this message
Unread 01-16-2015, 10:30 PM   #3
2000_limited
Contact your local dealership and ask them if they can reprogram your ECO to non Cali.
But I agree with Mike. The mech is bull ****ting you.
2000_limited is offline   Reply With Quote Quick reply to this message
Unread 01-17-2015, 12:36 PM   #4
biffgnar
biffgnar's Avatar
I live in NY which is a CARB state. When I replaced the cats on my TJ I used 49 state cats because of the price. Other than not having a CARB stamp on them there is no visual difference in the TJ cats at least. I suppose its possible the interior makeup is different. No CELs for me.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
catalytic , ecu , emissions , flashed
