Extending Shifter after body lift - JeepForum.com
post #1 of 3 Old 11-20-2013, 06:14 AM Thread Starter
JustinJeep40
Hello all, so this past weekend I put a 2 inch body lift on my 2000 wrangler and I've gotten every thing figured out except for the shifter. The instructions that came with the lift told me to take out the shaft that goes into the transmission, cut it, weld a piece of 2 inch steel the same size to it, to extend it. I was wondering if anyone on here has done anything like that before? Or any alternative ideas that could help. I would just leave it the way it is but the bend on the shaft is down to low. And the way it sits, I can only drive it with the inner and upper boots off. With the boots on, I can't get into 2nd, 4th, or reverse. Due to the boots bunching up and not allowing me to get all the way into gear. Long story short, for those of you that have installed a body lift. What did you do? I would just drive my jeep without the boots on but there's a lot of transmission and road noise without them. Also it's a little cold here in the mornings and it's not pleasant having 20 degree air pushing through my jeep constantly. Haha any help is appreciated!
JustinJeep40 is offline
post #2 of 3 Old 11-24-2013, 11:37 AM
athos76
Loosen the Center console and move it as far back as possible to see if that takes care of 2nd, 4th, and reverse... When I bought my TJ, the PO had a 3" BL and an extended shifter with a bend in it. After removing the BL, I had to tweak the bend a bit to keep from hitting the dash when shifting.
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #3 of 3 Old 12-17-2013, 04:23 PM
DrDmoney
Hopefully you've fixed your problem by now, if not this is an option, it's a little pricey but it sure shortens the throw on the shifter.
Quadratec
Short Shifters
Get rid of those long sloppy shifts with a B&M or Hurst short shifter. They can reduce a throw up to 30% and eliminate unwanted play in the shifter. Direct bolt on installation.
'90-'04 Wrangler from $234.99
DrDmoney is offline
