Elastic Door Straps - JeepForum.com
post #1 of 8 Old 03-20-2012, 05:21 PM Thread Starter
cyoos
Elastic Door Straps
I've had the footman loop ripped off the old passenger door before from a gust of wind. Not being a fan of the limitations of a web type strap, I'm installing 2" wide elastic from a local fabric shop. Once looped over the post it will be 8 layers thick, and I'm thinking 4-1/2" from the post to the mounting point as it will allow additional stretch if needed. I'm not going to bother with a footman or the stock screws; I'm boring and securing them to the doors with 1/4x20's. I'm also planning to include a longer loop of seatbelt strap as a safety limiter in case the elastic fails.
If I can post pics I will, but I'll let you know how it works out nonetheless.
cyoos is offline
post #2 of 8 Old 10-12-2012, 09:48 PM Thread Starter
cyoos
FAIL!!! Stick with the web type door straps.
cyoos is offline
post #3 of 8 Old 10-16-2012, 05:12 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Because why again? Your post was so informative, I was overwhelmed with the amount and detail supporting your position I could scarcely comprehend all of it. If you could cliff/sparks/for dummies it for me that would be so great.
To the OP. You might have some unintended consequences from the bungee strap. How is it working so far?
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #4 of 8 Old 10-16-2012, 09:59 PM Thread Starter
cyoos
For the way I made them, 3 layers of elastic strap, they are great until a good gust of wind catches the door. My drivers door has a web strap made from a seat belt that limits it's travel, but the passengers doesn't and will swing fully open with a good gust.
The straps are one of my "Need to rethink this" projects. Maybe if I make the elastic straps different lengths, so the tension is applied and increases earlier when opening the door....
I'll rework them pretty soon and post the results. I've been tied up lately with this project that does have a happy ending to it.
http://www.jeepforum.com/forum/f12/a...panel-1426537/
cyoos is offline
post #5 of 8 Old 10-17-2012, 11:04 PM
schitzangiggles
King of Macastan
Why not sew the nylon limiter to the elastic so it limits the amount of travel.
Kinda like v
WW
The elastic is the straight line and the limit strap is the "W" part so that way you get the benefits of both with out the entanglement of two separate pieces.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #6 of 8 Old 10-18-2012, 04:18 PM Thread Starter
cyoos
Hmmm...now there's an idea. I won't be able to get to it at least for a few weeks, but I'll try that once the other gators are out of my swamp. Thanks!
cyoos is offline
post #7 of 8 Old 10-19-2012, 11:29 AM
schitzangiggles
King of Macastan
No worries. I borrowed the idea from some safety equipment I use.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #8 of 8 Old 10-25-2012, 03:27 PM
416469
Try an old boyscout webbelt which you can cut into smaller pieces and the sew a loop in it. That should work
416469 is offline
door strap
Just put on my safarari straps... Beefstew General Jeep & Off-Road Equipment 2 06-27-2011 06:41 AM
Shorter Door Straps for TJ's blupupher Cheap Tricks & Fixes 15 08-02-2009 06:15 PM
Two straps OrangeSteel General Jeep & Off-Road Equipment 2 08-28-2008 04:15 PM
Tow Straps? .Jch. General Jeep & Off-Road Equipment 6 03-21-2008 07:11 AM
straps JR General Jeep & Off-Road Equipment 6 05-16-2001 01:11 AM
