DYI Reduce Road Noise & Improve Insulation With This Cheap & Effective MOD - JeepForum.com
post #1 of 7 Old 11-24-2013, 05:48 PM Thread Starter
Jeepocalypse
Looking to reduce road noise and keep your cabin warmer. Here’s a cheap alternative to those expensive hardtop headliner insulation kits.
Cost me around $50 and my time.
  • $10 PolyShild half-inch foam board – Home Depot
  • $10 Fleece Blanket WalMart (on sale)
  • $10 3M 77 Spray Mount Adhesive WalMart
  • $5 Spray Mount / Rubber Cement Remover
  • $10 3M Heavy Duty Double Sided Tap
TIPS: I split the top panel in two, using the natural ridge as a divider.
If you have satellite radio, be sure to remove the Mylar where your antenna is. Mine is centered on top of my roll bar.
I installed the liner while my top was still hanging. May have been easier working on the the ground - but I didn't want to bring it down and them back up to install the top.
AFTER THOUGHTS: Because I have a roll bar speaker kit, the half-inch PolyShild foam board just makes the gap between the roof and the roll bar. So the hard top now rests on the sound bar. While the front clamps hold down the top as it did before the mod, the rear portion of the top floats a bit. When I tightened it down I noticed that my rear door just makes contact along the window rubber keeping the window closed. I haven’t had any air or water leaks; maybe quarter inch foam would have been a better choice – if available.
I think the pics show my progress.
Overall it really it looks great like a factory install.
It helped with the noise - radio sounds better - I can have a conversation with riders in the back. Also feels warmer.
Good luck ... Keep Jeeping On!
Jeepocalypse is offline
post #2 of 7 Old 11-24-2013, 05:58 PM Thread Starter
Jeepocalypse
I somehow I posted this twice .. sorry about that!
post #3 of 7 Old 12-02-2013, 08:32 AM
ReconMill
Flat-4 Turbo
ReconMill's Avatar
2005
Taken care of. Dont worry about it. Nice work on the insulation!
Kyle - I mod stuff®
2005 Subaru Legacy GT
ReconMill is offline
post #4 of 7 Old 07-30-2014, 01:22 PM
waif69
1987 YJ Wrangler
Nice job! Cheap, effective and looks good.
If I didn't keep my top outside during the 3 seasons, I would copy you. The bugs and small critters would love the fabric and foam and I would have to remake it every year.
waif69 is offline
post #5 of 7 Old 07-31-2014, 05:15 PM Thread Starter
Jeepocalypse
Thanks ... why not get an outdoor storage bag / cover? There are a couple floating around: http://www.acmejeepparts.com/products/11091_201_07.htm / http://www.quadratec.com/category/Je...p+Storage/230/
post #6 of 7 Old 08-14-2014, 10:13 PM
1972cutlass
looks good. i appreciate the write up. i have been thinking about doing some homemade type of insulation to my hardtop as well.
1972cutlass is offline
post #7 of 7 Old 09-11-2014, 02:32 PM
RaceBannon
Great job and pictures. I'm looking for a new hard top and will keep this
RaceBannon is offline
