Dummy Guide-Putting Hole Vents in Hood - JeepForum.com
post #1 of 79 Old 03-15-2011, 09:50 PM Thread Starter
Jadetastic
Hey everyone!
I'm sure there's a Thread on this already but I will do one for like myself the lazy and impatient peeps anyway.
1st of all, I want to give credit to stogie25 & 2005X for helping me out with this mod, by giving me quick tips and additional info. (Thanks guys! Couldnt of done it w/o you)
Seeing that my Jeep is getting ready to be Solarmax/Rhinocoated here in a couple weeks, I wanted to do my quick conversions/mods before they cover my entire jeep with the solarmax. (That way everthing is already sealed)
Items Needed:
(should already have in the garage/if not BORROW) I had these already in my garage
*Safety Googles/Gloves
*Drill
*Kobalt 13-Piece Bi-Metal Hole Saw Set ($69.00 @ Lowes)
*Dremel
*Dremel 7-Piece Drill Bit Set ($10.00 @ Lowes)
*Drafting Circle Guide Template 46 From 1/16 - 2 3/4 ($8.00 @ Staples)
(Had already from past drafting class)
*Measuring Tape (the kind you measure your body)
*Sand Paper or Black&Decker Metal Wire attachment
*Aluminum Gutter Guard ($10.00 @ Lowes)
*Spray Paint (if needed)
This project should only cost less than $20.00
__________________________________________________ _________
Measure 2" above curve of hood, this will be your centerline. Draw the centerline down along the hood. Double check to make sure the 2" is consistent down the line.
Measure 2" over from the Edge of hood and mark, this will be your 1st circles edge.
Using your circle template, use the hole saw size 2 1/2 to make sure your using the correct template.
Draw the Circle within your template, using that 1st circle edge mark & the centerline as your guide.
After that circle is drawn, use a 1" gap between EACH circle
Repeat the above steps for the rest of the Hole saw sizes:
2 1/4", 2", 1 3/4", 1 1/2" for both sides of Jeep, when done-double check on all your measurements.
Some would opt to sand down then mark, I wanted to use pencil on the rust instead of bare metal & sharpie. Pencil shows up better on the rust and if you had any mistakes, its easier to rub off than wipe off sharpie. After all measurements are corrected and completed. Your going to tap your centermark for your bit.
Use your dremel to start the center hole
Use 1/4 drill bit to make it bigger, seeing I was too lazy to take my hood off and drill, I attached a guide on the drill bit, to avoid going too far.
safety first! Those metal bits & pieces are a PITA so Use googles & gloves!
Drill away.
Next Use your Hole Saw Bits to drill, using your center hole guide. To me- I used a hole saw instead of using the Greenlee Knockout punches. 1) They are really expensive, 2) How many times are you going to use them where you can get to the other side of the metal to punch the hole. So I went with the Hole Saw Method. JUST BE CAREFUL DRILLING, BE AWARE OF WHAT IS UNDER THE HOOD
After Drilling the holes, sand them down and buff out the circles you jacked up or if you did. (I know I did)
Spray Paint if needed, Since my jeep will be rhinocoated all on the outside- I just spray painted it black for protection against new rust and moisture.
Next the aluminum gutter guards, you will just need one- Measure just to be sure
I will be spray painting mine black since my Jeep will be Fire-Engine Red, But I will wait till after she is rhinocoated then finish the final touches on the aluminum guards.
Use the dremel to cut in half.
After the aluminum guards are cut, you will be able to slide them in under the hood. Use Silicon/duct tape/clamps or whatever you want to keep them mounted.
And There you have it- fancy schmancy Hood Vents
-You wanna see how a "real" asian drives? let me show you
Jadetastic is offline
post #2 of 79 Old 03-15-2011, 10:16 PM
Skytard
Damn, that turned out great.
Poor college student.
Skytard is offline
post #3 of 79 Old 03-15-2011, 10:56 PM
T-Jay
T-Jay's Avatar
Originally Posted by Jadetastic View Post
Ok you need to have a talk with my wife dammit Every time I mention ANYTHING Jeep related she roles her eyes at me and tunes out. And here you are posting how-to tech threads. Life just ain't fair lol! Nice job by the way...regardless of your gender and obvious good looks. Nice job.
T-Jay is offline
post #4 of 79 Old 03-16-2011, 01:18 AM Thread Starter
Jadetastic
Let's start of with, does she have her own jeep? If no I would see if she wants one lol
The other half & I have separate projects.
Bikes/jeeps/cars/guns our problem is just trying to get one another to shut-up about their own project so the other can talk about theirs.
The best way we have learned is to both the same project but our own toys- (we don't share very well + very competitive against one another)
I wish you luck! thanks
post #5 of 79 Old 03-16-2011, 05:30 AM
stogie25
stogie25's Avatar
Good work. Nice write up. It came out great.
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #6 of 79 Old 03-16-2011, 06:07 AM
T-Jay
T-Jay's Avatar
Nope She's a tiny little Taiwanese woman and can barely see over my TJ's steering wheel . It's not all bad though. She admittedly had a few laughs mudding my old RamCharger back in the day. She could barely reach the peddles, it was hilarious. As for projects...her's are collecting purses and reading Perez Hilton. I can't complain though she's a cutie, a hell of a good cook, and she lets me blow boat loads of money on my obsession. I suppose that's worth a rolled eye now and then.
T-Jay is offline
post #7 of 79 Old 03-16-2011, 07:53 AM
CopperCJ7
@Jade: Did you think about using aluminum rivets and washers to mount the gutter guards?
Guns don't kill people... Bad trail spotters do.
What CJ owner doesn't want to hack up his harness for the next owner to have fun with?
Originally Posted by Broseph View Post
The thread will derail quicker than a walrus on a Crisco-soaked Slip 'n' Slide.
CopperCJ7 is offline
post #8 of 79 Old 03-16-2011, 08:31 AM
dbbd1
dbbd1's Avatar
Real nice trick with the gutter guards. Sharp!
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #9 of 79 Old 03-16-2011, 08:43 AM
Jeff88
Those look really good. If I tried this, I am certain I would have them looking like...
o O O o O
Jeff88 is offline
post #10 of 79 Old 03-16-2011, 10:20 AM
Skytard
I like your jeep bro, one question tho, if you ever had to use your stinger would your roller fairlead rip off, it looks like it sticks out farther than the stinger. just curious
Skytard is offline
post #11 of 79 Old 03-16-2011, 10:23 AM
Skytard
When I started reading this I thought that sentence was going in a different direction.
Skytard is offline
post #12 of 79 Old 03-16-2011, 12:36 PM
stogie25
stogie25's Avatar
I hope never to use the stinger for roll protection. The best use I see for it is seeing the forward most point of my Jeep from the drivers seat.
Jarhead Jeep Club
O|||||||O
My Build Thread
stogie25 is offline
post #13 of 79 Old 03-16-2011, 12:46 PM Thread Starter
Jadetastic
Mmmmm Asian food- OK so thats where she has me beat. I cant cook very well but if i can soak it in beer then cook it then it usually turns out great haha
I bet she looks cute when she's angry then
I know when I do, my asian accent comes out really bad and he just starts laughing which makes me even more mad. I have the same problem when it comes to being short, short legs syndrome- thats why i like having a jeep, its perfect for midget asians. As for the purses/jeep parts funds- I can understand then seeing purses can rack up pretty quick. I bet you guys make a great couple
post #14 of 79 Old 03-16-2011, 12:48 PM Thread Starter
Jadetastic
Haha I did too- when I read "when she lets me blow..." my mind went to the gutter but hey girls can be perves
post #15 of 79 Old 03-16-2011, 12:49 PM Thread Starter
Jadetastic
I didnt think about that- But That is a great idea! I may have to do that after she gets painted.
thanks
A guide? XJ16 Fabrication Shop 3 11-17-2009 01:17 AM
Potential Hood Vents seanyb505 Street Jeep Forum 27 03-26-2008 11:00 AM
CB Dummy Tryin DaleB Audio, CB & Ham Radios, GPS, & Electrical 14 05-14-2007 05:19 PM
Winch Guide linux24 General Jeep & Off-Road Equipment 5 04-30-2005 10:20 PM
CB Dummy Install Mezlo Audio, CB & Ham Radios, GPS, & Electrical 3 01-11-2005 04:47 AM
