Doors... - JeepForum.com
post #1 of 4 Old 09-05-2012, 03:05 PM Thread Starter
Jleming
Doors...
Probably a simple process, but I just got my first jeep and im wondering how to take off the doors, its a 96 jeep grand cherokee laredo, suggestions??
Jleming is offline
post #2 of 4 Old 09-08-2012, 08:17 PM
PeejPilot
no idear- on wranglers, theres a retaining nut under the hinge that you remove, then on older ones that havent had the doors removed youll likely have to use a hydraulic jack or something similar to help push the pins up through the hinge. good luck with that, i just looked up some pictures of a laredo...
PeejPilot is offline
post #3 of 4 Old 09-08-2012, 08:27 PM
tinktinkTJ
I had 2 97 GCs. Unless you have to take the doors off to replace the pins or bushings, I wouldn't bother removing them. They are a real pita, and they weigh a ton. There are some mods you can do to make the door hinges to make them removable(like wranglers). IMHO its really not worth it, although some people with disagree.
Edit: I don't know of any zj door hinges that have been modified to be removable. Only xj hinges.
tinktinkTJ is offline
post #4 of 4 Old 09-08-2012, 10:39 PM
BriansCJ
1994 XJ Cherokee
I havent seen a ZJ hinge personally, but it shouldnt be that hard to mod.
Post up some pics of your hinges.
You could always unbolt them too.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
