door hangers - JeepForum.com
post #1 of 1 Old 09-14-2004, 06:08 PM Thread Starter
mdeesnuts
door hangers
Made some half door hangers yesterday. Works well, cheap, and it's nice to have them out of the way and safe. Requires exposed studs in wall (see pics).
This is much cheaper and easier than mine, but I didn't have eyebolts laying around like the stuff I made mine from and I was bored.
Supplies:
1 - 2x4 (2.5' minimum)
8 - 3" wood screws
16 - 1" wood screws (anything 1/4" and above will do)
4 - flat steel mounting plates w/ holes
1 - drill
1 - 5/16" wood drill bit
1 - wood saw
Finished product
plus jeep pic
Cut 2x4 into 13" to 15" sections.
Drill parallel holes on each side of both pieces at the very edge.
Screw mounting plates over sides that the holes go down for support and you get this.
Now screw the 2x4 into the stud w/ the 3" screws and hang your doors.
A couple of close ups
As you can see the driver's side door doesn't slide completely into the holes, but it works. A drill press would've been great.
I took lots more pics, but figured that was enough. Ask if you want more.
'04 TJ X (but I took that stupid decal off :)
Mods: Exterior Color-Fresh Mud
mdeesnuts is offline
Door hangers XRAYDRMIAH General Jeep & Off-Road Equipment 1 10-03-2008 08:45 AM
Easy door hangers MR.CLIFFORD Cheap Tricks & Fixes 8 11-19-2007 02:45 PM
Has anyone fabbed there own reverse shackle hangers E_ROCK Fabrication Shop 6 08-25-2006 10:11 AM
Cheap door hangers TJwithaTJ Cheap Tricks & Fixes 6 10-26-2005 08:26 AM
Front D60 Swap into CJ (outboarding hangers) BESRK Fabrication Shop 7 01-12-2005 05:09 AM
