Door Hanger - JeepForum.com
post #1 of 16 Old 02-08-2010, 08:02 AM Thread Starter
stuckmehere
2009 JK Wrangler
Door Hanger Question
I have heard door hangars that incorporate hanging the doors from the window frames will wreck the welds and cause problems with the weatherstripping. Any truth to that? Would eye bolts that use the hinges for hanging be better? I have looked at several posts, just looking for a general consensus.
stuckmehere is offline
post #2 of 16 Old 02-09-2010, 07:57 AM
muddy93
1987 FSJ Wagoneer
I don’t know about the JK doors, but the CJ doors that I have on my YJ are pretty heavy. And I can easily see where being hung by the window frame could damage the window seal.
I made a set of hangers for my doors using some scrap angle iron. I cut two pieces about 6” long, and in one side of the angle, drilled some holes so I could bolt the pieces to the wall in the garage. On the other side of the angle, I drilled holes that were just slightly larger than the hinge pins on the doors. With the two pieces of angle iron bolted to the wall, the doors just drop onto them just like they do on the hinges on the jeep.
I'll try to remember to get a picture of the hangers, and post them here.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #3 of 16 Old 02-09-2010, 09:49 AM Thread Starter
stuckmehere
2009 JK Wrangler
I'll try to remember to get a picture of the hangers, and post them here.[/QUOTE]
That be great I'd like to see those.
post #4 of 16 Old 02-14-2010, 07:37 AM
jbars
I just bought a cheap set of hinges on ebay just like the ones on my jeep, and screwed them to the wall in my shop. Now when I take the full doors off and put the half doors on, I just rehang the doors on those hinges on the wall. works great and real cheap fix... good luck !!
jbars
94 yj
hoosierland
jbars is offline
post #5 of 16 Old 02-15-2010, 06:59 AM
muddy93
1987 FSJ Wagoneer
ok, here's some pics of the hangers that I made. currently my soft doors are hanging on them, but the full steel doors fit the same way.
I have CJ style mirrors (the kind that mount to the windshield frame) on my jeep, so none of my door have mirrors attached to them. If your doors still have mirrors on them, you may have to space the hangers (or hinges if you use an extra set as hangers) away from the wall to allow clearance for the mirrors.
muddy93 is offline
post #6 of 16 Old 02-22-2010, 11:30 AM Thread Starter
stuckmehere
2009 JK Wrangler
Modified an idea I stole from another forum. rwitte42 gets the credit I just adjusted some things.
post #7 of 16 Old 02-22-2010, 11:56 AM
EaglesSJ
EaglesSJ's Avatar
thats a pretty nifty little setup. how much it cost to build one of those? im guessing thats metal pipe under that foam?
EaglesSJ is offline
post #8 of 16 Old 02-22-2010, 12:34 PM Thread Starter
stuckmehere
2009 JK Wrangler
I had the wood, carpet and hardware laying around. I used the pipe, casters, flange's along with the elbows and insulation and it cost me around 60.00. The wheels are freakin expensive like 6$ per but I liked the set up.
This is his list of materials:
Bill of Materials:
Furniture Dolly ........................... 2 @ 24.96 .. $49.92
3/4" x 48" Galvanized pipe ................ 4 @ 8.94 ... $35.76
3/4" x 18" Galvanized pipe ................ 2 @ 4.53 ... $9.06
3/4" Galvanized 90deg bend ................ 4 @ 1.17 ... $4.68
3/4" Galvanized floor flange .............. 4 @ 3.46 ... $13.84
Stainless oval-head phillips machine screws 4 @ 4.00 ... $16.00
5/16" flat washers ........................ 4 @ 1.80 ... $7.20
5/16-18 stainless finished hex nut ........ 4 @ 2.04 ... $8.16
3/4" x 6' pipe insulation ................. 2 @ 1.18 ... $2.36
Total: 146.98
Per cart: $73.49
post #9 of 16 Old 03-01-2010, 04:26 PM
Benderff
Benderff's Avatar
Die spammer
Benderff is online now
post #10 of 16 Old 03-03-2010, 02:44 AM
daox
swampbutt
daox's Avatar
who is the spammer?
I LIKE BEING CALLED A NOOBIE BECAUSE IT SOUNDS LIKE BOOBIE AND THAT MAKES ME GIGGLE!
daox is offline
post #11 of 16 Old 03-03-2010, 05:17 PM
Benderff
Benderff's Avatar
It was deleted. I should have quoted it for those that don't understand.
post #12 of 16 Old 10-04-2010, 02:57 PM
dennystyle
jeep door hangers
check out ebay surch the word MASTERHANG looks like it could be a cool door hanger
dennystyle is offline
post #13 of 16 Old 10-04-2010, 06:25 PM
Benderff
Benderff's Avatar
Whoever makes that is in Kalamazoo, and hey so are you. That's funny.....
post #14 of 16 Old 10-05-2010, 05:57 PM
dennystyle
well do you like them or not! I made 6 of these, one for me and put the rest on ebay. Im just looking for an honest opinion. I might make some more if there is any intrest out there.
post #15 of 16 Old 10-05-2010, 06:17 PM
Benderff
Benderff's Avatar
Funny you brought up being honest.
CHEAP and simple hardtop "hanger" DIY VanBCguy Cheap Tricks & Fixes 10 08-09-2009 08:05 PM
CJ front spring hanger swap. dmcfla Tires & Wheels 0 08-13-2008 12:28 PM
How to repair innner door panel on 97 TJ full hard door? RDNZL General Jeep & Off-Road Equipment 0 03-22-2008 08:39 PM
Frozen Hanger Bolts porkchop Tires & Wheels 5 02-28-2004 05:42 AM
Shackle Hanger off the rear bumper? Briznett Tires & Wheels 4 02-02-2004 09:47 PM
