Does anyone know how to remove paint from Soft top plastic windows? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Does anyone know how to remove paint from Soft top plastic windows?
Rough Country Jeep Suspension Deals at Rockridge 4WD!JEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 08-24-2012, 07:41 PM   #1
Snowblur
This is my first post on here so if I screw up certain procedures sorry in advance. Anyway I just bought my first Jeep (2008 Wrangler X) and so far I love it. I am starting to customize it and was wondering how to get paint off of the soft top plastic windows. The previous owner spray painted the inside of the back window black rendering the rear view mirror useless. Any tips to get this window mack clear? Paint thinner? Scraper? Your help and suggestions will be greatly appreciated.
Snowblur is offline   Reply With Quote Quick reply to this message
Unread 08-26-2012, 02:01 AM   #2
athos76
Pretty much anything you use is going to leave a mark. The paint probably already has. You can try denatured alcohol and a microfiber cloth and let it sit and don't use too much pressure. Once you get the paint off, some Novus plastic polish should get rid of some of the haze
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline   Reply With Quote Quick reply to this message
Unread 08-26-2012, 08:17 PM   #3
Snowblur
Thanks, I'll give it a try
Unread 08-28-2012, 10:21 PM   #4
AZdEvilYJ
Try grafitti remover from walmart. Worked good for me on multiple surfaces without any damage. Just a thought.
'95 YJ 2.5L
March '13 & '14 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
http://www.jeepforum.com/forum/f22/a...nally-1575209/
AZdEvilYJ is offline   Reply With Quote Quick reply to this message
Unread 08-30-2012, 01:56 AM   #5
MrMud
1988 XJ Cherokee
Laquer Thinner, walmart sells it.
MrMud is offline   Reply With Quote Quick reply to this message
Unread 09-20-2013, 12:31 PM   #6
MarlboroWrangle
just be careful, the solvent based stuff may cause some clouding where you use it because of the chemicals
have you tried goo-gone?
MarlboroWrangle is offline   Reply With Quote Quick reply to this message
