Diy quick disconnects - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Diy quick disconnects
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Billet LED Tail LightsCurrie
Unread 09-16-2014, 02:04 PM   #1
448661
Here's my solution for no quick disconnects. I got this from a buddy because I did not order them from rough country when I purchased the 3.25" lift. This solution is equally effective and cheaper You'll need 4 5/8" adjustable draw pins from tractor supply 2 lock pins A 5/8 or 3/4" drill bit Sockets, t55, and a bfh. (Big fing hammer) Step 1 remove sway bar bolts with t55 and 18 mm socket. Save the washer Step 2 inside the bushing to the sway bar links on the bottom end there is a metal bushing. Beat it out. I put the 18mm socket between the frame and sway bar link put the draw pin on the other side and whack with bfh. image-3597800932.jpg image-69007556.jpg image-431605058.jpg
Along frame there is an oval slot. Mount a draw pin on each side align before tightening by mounting sway bar links to it (dish soap helps them slide on. Be sure to allow room for the washer so you don't damage the bushing every time you put the pin in
Use drill bit to drill the old 1/2 hole big enough so you can mount the other draw pins on the bottom. Again leave just enough room for the washer so you don't damage the bushings each time you disco.
Total cost was $23.
448661 is offline   Reply With Quote Quick reply to this message
Unread 09-18-2014, 11:31 PM   #2
NumbSkull
Does this need to be done to both sides, or just one? I'm thinking one would work...
NumbSkull is offline   Reply With Quote Quick reply to this message
Unread 09-20-2014, 02:46 PM   #3
448661
I did both sides as far as the retention when your disconnected. The pins are $4 an change so there's not a huge cost to do it and make it look nice. As far as the axle side I would say yes you need to do both sides. A 5/8" drill bit worked to make the hole bigger. If you turn the steering wheel you can get more room to get your drill in.
They worked perfectly at the uwharrie today.
Unread 09-23-2014, 07:51 AM   #4
TEXAIR
Sounds like a great idea for when disconnected. But I am guessing you save the bushing and re-install it when you re-connect?
'05 TJ Unlimited. Black, 4" Superlift. Warn M-8000, Homemade Disconnects, Homemade In-Cab Winch Controller, Homemade S-Pod, DIY Rokmen Front Bumper, Homemade Rear Rock Crawler Bumper, 32" x 11.5" BFG MT's, Lockrite on the front D-30, Onboard Air
TEXAIR is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 09:03 AM   #5
448661
No. The rubber bushing always stays on the stabilizer link. The metal sleeve that you take out never goes back in. It's now garbage or goes in your spare bolts bucket.
Unread 09-25-2014, 10:45 PM   #6
Maverickxeo
Does it rattle at all when connected? Is it still firm? Im thinking my dad might be interested in this, but his Jeep is a DD (Like mine) but he puts ride quality over off road performance. He saw my discos and liked them, but couldnt bring himself to spend the money on them that I did.
Maverickxeo is offline   Reply With Quote Quick reply to this message
Unread 09-27-2014, 01:56 PM   #7
448661
No it doesn't rattle...but what jeep wrangler doesn't rattle or squeak?
Unread 10-01-2014, 08:37 PM   #8
Colin_TJ
How did you mount the draw pin into the frame through the oval slot? Does it go all the way through the frame? How did you get the bolt on the back
1999 TJ 4.0
4 inch Zone lift 33x10.5.15 BFG
Northeast Georgia
Colin_TJ is offline   Reply With Quote Quick reply to this message
Unread 10-02-2014, 11:08 AM   #9
448661
I put the nut on my pinky finger then put it the ought the slot. I held it in position with needle nose pliiars and threaded it in.
Unread 10-03-2014, 04:19 PM   #10
Colin_TJ
Just picked up me a set today from tractor supply. Gonna install this weekend and see how it goes !
1999 TJ 4.0
Northeast Georgia
Unread 10-03-2014, 07:08 PM   #11
448661
Awesome. It did help to turn the tires away from the axle side to allow more room for the cordless drill. Try and keep it nice and level. A little dish soap helps get the swaybar links to slide on the new draw pins
Unread 10-04-2014, 03:10 PM   #12
1975cj5jeep
Going to tell a buddy about this
1975cj5jeep is offline   Reply With Quote Quick reply to this message
Unread 10-04-2014, 03:11 PM   #13
1975cj5jeep
Great idea
Unread 10-06-2014, 05:30 PM   #14
Colin_TJ
Got them installed today! Pretty easy install, but my only question is when both sway bar links are connected how easy is it supposed to be to get them off the draw pin? Mine seem hard to get off and I didn't know If that's normal
1999 TJ 4.0
Northeast Georgia
Unread 10-06-2014, 08:35 PM   #15
448661
I'd say that's normal. Your olfactory setup had bolts which were pretty tight. This setup with no bolts is tight via the bushing. You wouldn't want a lot of slop in there. With my winch and bumper I usually have to pick up in the front end to help get them off. Glad it's working!
