DIY JK Door Hanger/Shelf for Doors with Rainguards - JeepForum.com
post #1 of 15 Old 03-05-2013, 01:27 PM Thread Starter
ciphershort
2009 JK Wrangler
Since I have rainguards on my JK unlimited doors, I couldn't use the conventional door hangers so I decided to build my own. I got this idea from somewhere else online and modified it to fit my needs. Thought I would share. Feel free to ask me any questions.
Here's the layout and materials list:
I used an electric stapler to staple the foam pipe insulation with a little glue underneath. Since it was originally circular, it takes a little convincing to flatten it out.
This is the blocks up top that the top part of the doors rest against. The center line should be at 45" to hit the doors right. I put an eye lag screw in the sides for the bungee straps to hook to. I used more pipe insulation foam here. It is smaller in diameter...maybe for 1-inch pipe I can't really remember. You can cut it to size really easily.
Here's it all completed with the doors. I added a block in the center to hold my mirrors when I have my doors on so they don't get damaged. It's just a block with two 3/8" holes drilled out for the mirror shafts to slide down into.
ciphershort is offline
post #2 of 15 Old 03-07-2013, 09:55 PM
kjg26
kjg26's Avatar
Love it!
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #3 of 15 Old 03-08-2013, 01:27 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Looks great.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #4 of 15 Old 03-08-2013, 08:18 PM
medijeep
very sharp!
medijeep is offline
post #5 of 15 Old 03-11-2013, 09:35 PM
silverstonemkiv
great idea!
silverstonemkiv is offline
post #6 of 15 Old 03-12-2013, 11:09 AM Thread Starter
ciphershort
2009 JK Wrangler
Thanks! In retrospect, I wish I would have hung the shelf a little lower. The front doors are a slight struggle getting them up that high. Not impossible obviously... Those doors are heavier than I anticipated.
post #7 of 15 Old 03-16-2013, 12:06 AM
whiskeywiz
[QUOTE=ciphershort;15121126]Thanks! In retrospect, I wish I would have hung the shelf a little lower. The front doors are a slight struggle getting them up that high. Not impossible obviously... Those doors are heavier than I anticipated.[/QUOT
and if i were to do exactly this, what is the current and suggested measured height from top of floor to top of shelf? Looks great.
whiskeywiz is offline
post #8 of 15 Old 03-16-2013, 12:10 AM
whiskeywiz
[quote=whiskeywiz;15142327]
Oops... I found your current elevation on the print. How much would you say to drop it?
post #9 of 15 Old 03-16-2013, 01:30 PM
BigWhis
2011 JK Wrangler
That's pretty cool. Thanks for sharing!
Semper Fi!
BigWhis is offline
post #10 of 15 Old 03-19-2013, 10:41 AM Thread Starter
ciphershort
2009 JK Wrangler
[quote=whiskeywiz;15142345]
I'm 6ft tall and would be comfortable with it being about 6-8 inches lower. A good way to measure may be taking your door off and lifting it as high as you can with your elbows locked and getting a second person to measure the distance from the floor to the door.
post #11 of 15 Old 03-21-2013, 08:08 AM
whiskeywiz
obviously, it could be built just a couple inches off the ground. Why might you suggest not too? To prevent paint dings? Low wall space is premium too, right?
post #12 of 15 Old 03-21-2013, 03:50 PM Thread Starter
ciphershort
2009 JK Wrangler
Right. I keep things like bikes and other items on the ground and didn't want them to scratch the doors. That's pretty much my only reason for having it higher than lower.
post #13 of 15 Old 10-10-2013, 04:27 PM Thread Starter
ciphershort
2009 JK Wrangler
Just thought I would report back after several months of use... It is all holding up awesomely well as my doors have been sitting on it for practically the entire summer. The only thing I might change if doing this from scratch again is make the bottom shelf deeper somehow for the front doors. My front doors are a *exact* fit and the pattern in the plastic on the inside of the door down low has rubbed the paint off the sheetrock from the few times I've taken them down. I may try to router out part of the front-facing 2x4 to give me some more depth for the front doors.
post #14 of 15 Old 07-09-2017, 07:39 PM
Charlie92
Thanks for this info. After looking at all kinds of YouTube videos showing hangers that put stress on the weatherstripping, I wondered if a shelf design would make more sense. Your design is exactly what I was picturing. My trail doors will arrive this week and I'll use your design and make the shelf deeper as you suggested. I wonder about the safety of bungi cord though so I might use some kind of strapping instead. Thanks again!
Charlie Niner Two
Charlie92 is offline
post #15 of 15 Old 07-09-2017, 08:00 PM Thread Starter
ciphershort
2009 JK Wrangler
The bungees have been super secure. Been using this same set of bungees since I put this up. Doors stay on the shelves about 8 months out of the year and have no problems. Since the eyes lags are mounted higher than the top of the door there's no way the bungees will come loose.
One thing I ended up changing was making the bottom shelf a bit wider. The 2x6 allowed literally just enough room for the door depth. Made me a tad uncomfortable with the paint being against the wood lip so I just rigged it and jumped another small 1x2 between the lip and the 2x6. Overall, still happy with my design after all these years and haven't seen any issues to date.
1499648341229529194537_1499648364853.jpg   1499648400107824532547_1499648415517.jpg
