Dim fog lights - JeepForum.com
post #1 of 10 Old 12-29-2012, 02:42 PM Thread Starter
Jeep_Jumper
Dim fog lights
I hooked up 5 fog lights up in a series and running it with one switch and one 25 amp fuse.. The lights are very dim and if I disconnect a light or two it gets brighter. How can I get all five to be bright?
Jeep_Jumper is offline
post #2 of 10 Old 12-29-2012, 04:59 PM
rdsk8ter
1982 CJ7
Are you saying you put all the positives together and all the grounds or you tied one into the next into the next? what gauge wire did you run and what size lights?
here is my build threads
http://www.jeepforum.com/forum/f104/randys-offroad-trailer-1164102/
rdsk8ter is offline
post #3 of 10 Old 12-29-2012, 05:04 PM
sjones26573
If you ran in series, that is your problem and I am amazed your car has not caught on fire. They must be wires parallel to a relay.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #4 of 10 Old 12-30-2012, 03:48 PM
rdsk8ter
1982 CJ7
ha I missed that part yeah I'm fairly shocked too
rdsk8ter is offline
post #5 of 10 Old 01-03-2013, 12:18 PM
captainauti
why would it catch fire? if there is 5 light in series with a 12v source, then each light is only getting 2.4v. prob not enough to light them. sounds like he put them in parallel and needs to check for voltage drop due to wire gauge, connections, or ground. there is too much resistance somewhere in your circuit.
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline
post #6 of 10 Old 01-16-2013, 11:58 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I hate it when people start the same thread in multiple locations. Dim fog lights
***Chris***
chris87xj is offline
post #7 of 10 Old 01-18-2013, 07:12 AM
captainauti
yea ...... stupid.
Capt. Nate
aka Scallywag
post #8 of 10 Old 01-19-2013, 11:42 PM
papitt
... Fire I guess to much draw .......
... I just put 5 up on top of my Diesel 4BT Bronco .. I have 5 wires running up top . And 5 50amp toggle switches under the dash . I believe I ran 10 gauge, might be 12 ga. wire to mine. Each one is on it's own Fuze also, And battery to new Fuze block is 8 gauge. .
papitt is offline
post #9 of 10 Old 01-20-2013, 11:20 AM
captainauti
overkill? do the math, use whats needed. just saying.
Capt. Nate
aka Scallywag
post #10 of 10 Old 01-20-2013, 05:47 PM
papitt
.. Well I could not find what was needed.. for a guaranty.. So I went with the items I had at home and What I was pretty sure would work.
.. I had people telling me to run it through a Constance Duty Solenoid. And all off relays. Internet is so lovely.
papitt is offline
