Diff cover vent - JeepForum.com
post #1 of 12 Old 02-15-2013, 04:40 AM Thread Starter
Cavalier2000
Diff cover vent
So I am doing some maintance to the old jeep and came across a leaking rear axle, like all of it, cover seal both end seals and the pinion seal.
I noticed the breather/vent on my diff cover looked a little ragged and beat up and when I touched it, air came out so apparently it's not working correctly
Now covers with vents (that I have found) are a bit high in price.
It is possible to just remove the vent, attach a 90 degree elbow and run a hose up to a dry area or does it need to be some sort of check valve?
Thanks in advance
Cavalier2000 is offline
post #2 of 12 Old 02-17-2013, 12:19 PM
DanZ51
A better idea would be to run a hose up high then cap it with a small fuel filter like the ones you find on a lawn mower.
"I will always be an American Soldier"
DanZ51 is offline
post #3 of 12 Old 02-18-2013, 01:49 AM Thread Starter
Cavalier2000
Here is what I ended up buying
post #4 of 12 Old 02-18-2013, 10:02 PM
DanZ51
Cool. What did you cap it with?
DanZ51 is offline
post #5 of 12 Old 02-18-2013, 10:15 PM Thread Starter
Cavalier2000
As of right now nothing, it's just chilling in my engine bay.
post #6 of 12 Old 02-24-2013, 08:22 PM
damessor92
are those aerator stones for a fish tank?
damessor92 is offline
post #7 of 12 Old 02-24-2013, 08:43 PM Thread Starter
Cavalier2000
Lol yea they are. About 87 yen a piece(about a dollar)
post #8 of 12 Old 02-27-2013, 08:56 PM
cargo33
If you had a snorkle intake could u run those into that? Or would that cause a positive preasure in your pumpkin?
cargo33 is offline
post #9 of 12 Old 02-27-2013, 10:58 PM Thread Starter
Cavalier2000
That I don't know. I suppose it would depend on how you had it setup.
post #10 of 12 Old 02-28-2013, 10:07 PM
cargo33
Im just wondering if u could put all yor fresh air inlets in one high vented spot (snorkled intake) then you would only hav to worry bout keeping one spot above water. Im just throwing out ideas lol. I do like the tubes tho. I should do that
cargo33 is offline
post #11 of 12 Old 03-01-2013, 08:09 AM
DanZ51
The military HMMWV does just that. Differentials, transmission and transfer all run into a common vent tube which is connected to the Air Filter. There shouldn't be any positive or negative air pressure build up, unless you have a kink in a line.
DanZ51 is offline
post #12 of 12 Old 03-01-2013, 03:41 PM
cargo33
Good to kno. Maybe il try that one of these days
cargo33 is offline
