did you break your shifter knob of your shifter - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Trick & Fixes > did you break your shifter knob of your shifter
XJ guys, clock your transfer case!Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-25-2005, 03:02 PM   #1
2cjs
did you break your shifter knob off your shifter
This has happened to me twice(2 jeeps)
must know how to weld or know someone who does.
first off grind the shifter down flat then get a 3/8 16 thread 1 and a half inch bolt,cut the head off the bolt and weld it the the shifter.
throw a little paint on it and screw your knob back on and your good to go.
note: be sure to disconnect your battery and distributor before welding.
kenny
83 cj-7 258c.i., 727auto, d300, d44 front, d60 rear
92'yj 4.3(roller) tbi chevy,700r4 ,soa, 35-12.50-15 maxxis bighorns
89'yj wife's jeep 4.2l stock ,2"bl ,31-10.50-15 bfg mud terrains
work smarter not harder
2cjs is offline   Reply With Quote
Unread 04-25-2005, 04:37 PM   #2
HokieYJ
Thats a pretty good idea!!
What i did with mine is grind enough around the lever to jam a fitting that came with the Hurst "T" shifter on. I put some JB weld on the inside of the fitting and then tapped it on the lever and let it dry overnight. Then all i had to do was screw on the handle. It is REALLY solid!!
HokieYJ is offline   Reply With Quote
