Cure for TJ Crane Neck - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Cure for TJ Crane Neck
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!Nitro Gear Packages Now Available at Rockridge 4wd
Unread 02-22-2015, 10:13 PM   #1
TeeJayPee
Since owning my Jeep I've learned there are many issues to deal with when owning a TJ. One of the issues for anyone driving a TJ that is taller than four foot, is the crane necking at stoplights. I really hated looking like a gimp to see what color the stoplight was; so I came up with a solution that I could live with.
I bought 1.5 foot of 5/8in Acrylic rod that was cut in half lengthwise. acrylic-.5in-rod.jpg
I used some clear double sided tape and attached it to my window from the inside. Worked like a charm. You can see the red stoplights in the closeup of the acrylic rod. I was amazed at how well it actually worked. It is better in person than it appears in the photo. The photo is a semi-fisheye shot of a concave shaped rod.
Cheap easy fix, and now I have no more crane neck.
TeeJayPee is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:33 PM   #2
cowstick
Nice work! I just look at the reflection in my hood.
"Victory is our reward for all the blood we spill" - Amon Amarth
cowstick is offline   Reply With Quote Quick reply to this message
