Cup Holder Mod. - JeepForum.com
post #1 of 8 Old 06-01-2013, 09:49 PM Thread Starter
JimJ_99WJ
Cup Holder Mod.
If you own a GC similar to mine (I've got a '99) you know the cup holder is a piece of engineering junk. it won't hold a cup of coffee or water bottle up while going 10 MPH down a straight, smooth road. I had the same problem, here's my solution.
Items needed:
4" length of 3" I.D. ABS plastic pipe
Gorilla Glue
Cut one piece of pipe 2 1/2" long. It fits snuggly into the drivers side hole. If you only want one side to hold a cup you're done.
If you want the other side too like me, it's a little trickier since the hole on this side is smaller and the pipe won't fit in it.
Cut a 1" length of pipe. Cut a section off one side at an angle so it will lay up against the other pipe and sit directly over the other hole (see picts). Then taper it from 1" to about 7/8" on the cut edge (again see picts). This is because the housing it is over is rounded and the taper is to follow the rounded top face. Glue the pieces together with Gorilla Glue. When it dries file the glue down so it's smooth. A tapered coffee cup won't fit in the passenger side yet though, the top edge of the first pipe is in the way. So file it down enough to accept the tapered cup (once again see picts). Once this was done I painted mine with flat black paint so it would look a little better. Voila, cup holders that actually hold a cup for little or no cost and they work great.
The picts with a flash show a lot of detail of the filing and such, but in reality this is really not noticeable. Maybe one day I'll smooth things out a bit more.
.......Jim
JimJ_99WJ is offline
post #2 of 8 Old 06-09-2013, 01:38 AM
Moezer
2015 JK Wrangler
Hahahaha that's awesome
Moezer is offline
post #3 of 8 Old 06-09-2013, 01:38 PM Thread Starter
JimJ_99WJ
It looks better after a coat of crinkle finish black paint
.......Jim
post #4 of 8 Old 06-12-2013, 04:01 PM
cherokeetina220
1997 XJ Cherokee
Hahaha I should try that for my 97 grand cherokee then my soda won't spill anymore!
cherokeetina220 is offline
post #5 of 8 Old 06-19-2013, 08:08 PM
um7267
ya i just use a beer koozie(minus the beer while driving) and it holds cans just fine and bottled water
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
post #6 of 8 Old 06-19-2013, 08:22 PM
cherokeetina220
1997 XJ Cherokee
I mean the sodas I get from burger king or wendys. That **** spills over all the time! It pisses me off lol
post #7 of 8 Old 06-22-2013, 08:22 PM
Motorcharge
Hole saw and a $2 flared pipe end for my XJ. Could probably thread it into a WJ cup holder to make it bigger. Works awesome for everything because the pipe is 2 different sizes. Holds everything from water bottles to those big foam flared cups from fast food places.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #8 of 8 Old 06-23-2013, 02:39 PM
CITYXJ2390
I know just where MOTORCHARGE is coming from, except I havent put one in......
Intrepid to Astro to XJ = upgrade!
CITYXJ2390 is offline
