A couple of issues - JeepForum.com
post #1 of 8 Old 04-04-2014, 10:31 AM Thread Starter
AnalyzeIt
A couple of issues
I have a 2000 Jeep Cherokee. It is in very good shape, runs good, and I do the maintenance a bit more than the manual calls for.
I've been have problems with the hazard and turn signals. I changed the unit and it worked for the last several months. Last night when I used the turn signal it blinked a few times then stopped. The next time I did it, it worked, and then the next time it stopped after a few blinks. Any ideas?
Also the glue appears to be drying on the ceiling cover allowing the cloth to drop down. Is there a remedy?
AnalyzeIt is offline
post #2 of 8 Old 04-05-2014, 02:48 PM
SourNewspaper
I'm not 100% sure what's going on with your turn signal, and if you said you replaced the multi switch with an official OEM part than I'm not sure why that isn't working. Knockoffs which may be cheaper often fix problems at first, but fail in time like you've said. However for your ceiling falling, gorilla glue will do the job no better than any expensive appoxy you'll find in stores and is probably cheapest.
SourNewspaper is offline
post #3 of 8 Old 04-08-2014, 07:02 AM
rjbruzan
Here is for the headliner.
http://www.jeepforum.com/forum/f46/4...ehicle-821160/
Ive done this myself and it costs a little more than 45 bucks. I think $30 for the material at Joanne Fabrics and $36 for the best glue at Lowes (2 cans).
It really makes a difference in the looks of the interior. Overall maybe 6 hours work.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #4 of 8 Old 04-15-2014, 12:08 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
I used to to marine interiors and automotive stuff and for the DIY'er the 3M Super 77 or Super 90 spray adhesive is the best and longest lasting adhesive available to the masses. You can find it at lowes/HD or even Walmart. Avoid the "Hobby adhesive as it will not stand up to the temps that your vehicle will get to during the summer months.
The 77 is a great adhesive but if you are feeling the need for something a bit more, the 90 is impressive. You just had better get it right the first time, because it will not be coming back apart.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #5 of 8 Old 04-15-2014, 12:54 PM
strvger01
1966 CJ5
for the blinkers, double check all the grounds for each of the lights as well as at the switch, and also the main body, frame, and engine grounds.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #6 of 8 Old 04-16-2014, 10:29 AM Thread Starter
AnalyzeIt
Thanks for all the good info.
My blinkers are functioning fine now. I bought the stalk directly from a local Jeep dealer. I didn't think of the grounds.
I'll look for that adhesive.
post #7 of 8 Old 04-16-2014, 12:09 PM
schitzangiggles
King of Macastan
Oh and wear goggles, an N95 dust mask and a long sleeve shirt of you will glue your nose hairs together and bring the suck when it glues your arm hair together. It is potent stuff
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #8 of 8 Old 04-21-2014, 12:56 PM
Nitr0EngiEx
can you check for a loose ground wire ? i have been guilty of putting screws in loose and ground wires not connecting if this is an intermittent issue could be valid
Nitr0EngiEx is offline
