Convert to 4x4 wj - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Convert to 4x4 wj
Jeep Gear & Install Packages!Rough Country Lift Kits and Parts!USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4
Unread 11-18-2014, 01:55 AM   #1
CATarpley
Convert to 4x4 wj
What do I need in order to convert my 2x4 2000 jeep grand cherokee limited v8 to a 4x4, I'm wanting to do an electric system but I am open to a shifter as well!
CATarpley is offline   Reply With Quote Quick reply to this message
Unread 11-18-2014, 06:02 AM   #2
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Everything from a 4x4 WJ.
Front axle and steering components, front drive shaft, transfer case, rear drive shaft, crossmember, shifter, and so on.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
leftlanetruckin is offline   Reply With Quote Quick reply to this message
Unread Today, 02:07 AM   #3
Maverickxeo
You would need a lot... If you arent that attached to it; get rid of it, and buy a 4x4.
Maverickxeo is online now   Reply With Quote Quick reply to this message
Unread Today, 02:57 AM   #4
CATarpley
I've read a lot about it and from what I've read I could probably buy the needed parts for around 500-700 depending on the "scrap yard" fees, and do almost all of the work myself as well
