Chip Locker - JeepForum.com
post #1 of 21 Old 12-29-2010, 11:43 AM Thread Starter
BlackDevil
1994 XJ Cherokee
Chip Locker
I am a little trouble when I have to pass through the muddy hill. The problem, open diff on the front axle D30 in my XJ. Locker certainly could be a solution, but are quite expensive.
One time, I accidentally saw a Volvo rear axle that contains a kind of locker. I am curious and trying to find out on the internet from its shape and the answer is that Eaton G80 product. I then tried installing it on the D30 and it worked.
Are there any on this forum who have used G80 as an off-road device? Can you share the experience with me?
BlackDevil is offline
post #2 of 21 Old 01-14-2011, 08:36 PM
Azzy
Looking around I saw the term Gbomb
Good luck
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #3 of 21 Old 01-15-2011, 12:18 AM
huntandfish
1992 YJ 2.5 SOLD
2004 Grand Cherokee Special Edition 4.0
IRO 3",JKS BPE's,DoetschTech8000's,Tenneco SS,Cooper Discoverer STT's 245-75R16,RC wheel spacers,SSBC Slotted Rotors, IRO Prem-sliders...
A great place for outdoorsmen in the NW.
Member Screen name- addicted
huntandfish is offline
post #4 of 21 Old 01-15-2011, 12:07 PM Thread Starter
BlackDevil
1994 XJ Cherokee
Thanks Azzy and Huntandfish. I might agree that some form of treatment will lead to the locker shattered. In the second video posted by Huntandfish, I noticed that the weight of the vehicle and large engine power may indeed not fit with the G80. Moreover, G80 mounted on the rear axle with a load more power. On the other hand, I use it to the front axle (D30) which of course get the distribution of power is smaller than the rear axle. According to friends here who already had plenty experience , whether the use of G80 on the front axle will still cause the damage as the videos posted by Azzy ? Please, if anyone can provide information how much approximately the power out put of the car that was shown on video posts Huntandfish? This comparison is important for me, because with the engine Cherokee XJ that only about 190 hp, G80 still safe until now. Anyway, thanks for sharing...
post #5 of 21 Old 01-15-2011, 12:14 PM Thread Starter
BlackDevil
1994 XJ Cherokee
http://www.youtube.com/watch?v=6Zit49L-7_A
Good luck
Azzy, if you have own experience with the use of lockers are falling apart like in the video? What happened to the other locker products? Thanks for let me know.
post #6 of 21 Old 01-15-2011, 12:47 PM
Boodyrider
Shock loading destroys axle components, not smooth application of powwer. Wheel hop is ROUGH on stuff. And I'd disagree that the front gets 'less power'. It certainly sees plenty of shock loading, but then part of the problem is wheelspin/hop.
But since the Aussie locker is tried and true for a D30... why screw around with Volvo parts?
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #7 of 21 Old 01-15-2011, 03:50 PM
kcaverly
Because you can probably buy it from a JY for $25 instead of $250 for an aussie.
I think this is really interesting. I think for a lightweight vehicle like a jeep with a lot less power than those v8 full sizes it should be ok. If GM put it in fullsize vehicles they must have thought it would hold up ok.
Kevin
kcaverly is offline
post #8 of 21 Old 01-17-2011, 03:42 PM
kcaverly
The discussion here is about the G80 out of older volvo's, which happened to use a D30 in the rear of many of their turbo wagons, with the G80 posi-lock.
How did you get it to work, BlackDevil? Did you just bolt your ring gear on it and install? Axle shaft lengths work out OK? I have a spare D30 lying around I can test install it in, but it would be nice to know any difficulties you had, and how you surmounted them.
Thanks,
Kevin
kcaverly is offline
post #9 of 21 Old 01-17-2011, 05:10 PM
Azzy
None, although the idea interested me so I started to look around. All I saw was issues and trouble. Makes sens though, it needs to get up to speed to get momentum and engage, so you have a violent action happening, and the insides do not look as sturdy as some of the others out there.
I think that if you were to engage the thing, it wouldnt even work until you got momentum to where it would blow apart.
Azzy is offline
post #10 of 21 Old 01-17-2011, 11:53 PM Thread Starter
BlackDevil
1994 XJ Cherokee
Thanks,
Kevin
Yes Kevin, its installation is not too difficult. Just go to the original carrier, remove the ring gear and carrier pairs on G80. Size of the carrier and the number of bolt holes are same, there are 10 holes. A little problem, because you have to cut the left axle shaft about 10 mm.
I've tried this G80 several times in the off-road terrain and muddy slope with MT tire, push the throttle til 4000 rpm or something and do not cause damage. As I know, G80 start work at speeds below 25 mph and if there are differences in rotation between the right wheel and left wheel about 100 rpm. Once you get same speed rotation, then the G80 automatically release more like an open diff.
post #11 of 21 Old 01-18-2011, 08:42 PM
kcaverly
Do you have any information about what vehicle it came from?
I know volvo, but what year, model, turbo?
Kevin
kcaverly is offline
post #12 of 21 Old 01-19-2011, 07:52 AM Thread Starter
BlackDevil
1994 XJ Cherokee
Kevin
You can get it from model wagon or sedan 900 series with turbo engine. But be careful, do not select from the Volvo 900 series which uses an independent suspension. This model is also equipped G80 locker, but uses 26 spline so it can not be used on D30. Please count the teeth or you can recognize the difference of their dimensions. G80 with 26 spline slightly smaller than a 27 spline.
post #13 of 21 Old 01-19-2011, 08:02 AM Thread Starter
BlackDevil
1994 XJ Cherokee
Oh ya, also can be checked from the white sticker located on the rear left side of the axle tube. Stickers inform the axle serial number, final gear ratio of 3.73 and axle 1041 series for G80 or 1031 which is only equipped with LSD (using FG 4.10). I have a sticker pic and the G80 sitting on my D30, but unfortunately I could not post them on this thread. If you need these pics, please pm your email address.
post #14 of 21 Old 01-19-2011, 09:01 AM
NYTrailrider
1988 MJ Comanche
What?
NYTrailrider is offline
post #15 of 21 Old 01-19-2011, 09:08 AM
onelow1ton
1983 FSJ Wagoneer
i had a g80 in my lifted Colorado wit 33s and took it 4wheeling all the time and it was fine but i traded that truck in and got a 2wd Colorado with a g80 and I'm on my second rear because the locker housing exploded
NEW BUILD 1983 wagoneer bagged and bodydropped Click here for build -->
onelow1ton is offline
How to install a ‘lunchbox’ locker (ex locker, aussie locker, etc) in your D30 axle. CanukYJ Fabrication Shop 107 12-04-2011 07:14 PM
jet chip USA_PRIDE Street Jeep Forum 10 12-18-2007 07:42 PM
Jet Chip Cruzer66 Audio, CB & Ham Radios, GPS, & Electrical 3 10-26-2005 04:17 PM
jet chip.... NATE DAWG Engines & Drivetrain 5 02-20-2003 06:42 PM
Jet chip for 4.0 XJ dawnme6a Engines & Drivetrain 3 09-09-2002 07:01 PM
