Cheep/Free performance upgrades - Page 5 - JeepForum.com
post #61 of 109 Old 08-14-2011, 12:15 AM
1999JeepLaredo
You want a cheap mod? Take a 1/4" drill bit and drill your fuel injectors out. Puts the fuel right to the motor. Haulin azz after that.
But seriously, get a programmer if you want performance. But if you want gas mileage, I use Lucas fuel additive to clean out my system. And I've done a seafoam treatment. Cleans the upper and lower parts of the engine. Pretty spiffy. But in all honestly bro, it's a jeep, gas mileage is gonna be a problem, day or night, rain or shine
Build Thread: http://www.jeepforum.com/forum/f22/500-wj-project-soon-dd-1255793
1999JeepLaredo is offline
post #62 of 109 Old 08-14-2011, 12:40 AM
1999JeepLaredo
Oh and depending on how many miles, change out the fuel filter, you'd be surprised how much that actually helps out.
post #63 of 109 Old 08-14-2011, 12:49 AM
Xerxes
Originally Posted by wenkebach View Post
exactly
Originally Posted by melk:
"Either more or less lube may change the moaning!"
|::Sahara Owner::|
Xerxes is offline
post #64 of 109 Old 08-14-2011, 01:51 AM
Tylerzap
Do a seafoam treatment. if its not a high output get the parts and conever. all i can think of.
Tylerzap is offline
post #65 of 109 Old 08-11-2012, 05:13 PM
backyardjeeper
1992 XJ Cherokee
Originally Posted by wacked View Post
I'm not sure exactly how TB spacers work better, but intake runner length does have a lot to do with low to mid range torque. How much length makes a difference I don't know. If a 1" or 2" TB spacer on a 4.0 makes a difference I couldn't say as there are other factors involved also..
But an example of long intake runner length was on the C4 Corvette Tuned Port Injection system (TPI of the mid 1980's) which had a total intake length of 17 inches and produced incredible torque at a low RPM. In fact, there was a modified system to gain more upper rpm power by shortening up the overly long intake runners. I'm pretty sure intake runner length is directly related to intake velocity at a given RPM range - longer length for low rpm and shorter length for high rpm.. The TPI long intake runners were great for low end, but sucked for upper rpm gains in power..
The intake manifold length makes a difference. The closing of the intake valve makes a pulse in the airflow ( think when you close a door in your car... It can make a puff of air out of a cracked window. That's why they tell you not to close your door hard when you have a new windshield put in because it can damage the fresh glue) that pulse bounces off the throttle body, and back into the engine, resulting in a slight forced induction effect. This only works at a certain RPM range, depending on the length of your intake manifold. Some cars have a variable length intake manifold, that changes the length according to the RPM's. Google VLIM or Variable Length Intake Manifold. BMW came out with an infinitely variable type. They stopped doing it because the gains in HP weren't enough to offset the cost. Most are two stage, meaning they have 2 lengths to choose from.
But if there's a certain RPM range you want extra power in, keeping in mind that there won't be a huge difference, you can build an intake to do so.
This throttle body spacer might do it, if I understand the physics right. Otherwise, it would be only good if your fuel mixes with your gas before the cylinders, I. E. TBI or carb.
If I'm wrong please correct me but that's the way I understand it.
92 xj on 235/75/15's. $2000 into a $400 dollar jeep.
backyardjeeper is offline
post #66 of 109 Old 08-12-2012, 05:07 PM
castorriver
Does anyone know how many hp you gain from removing and bypassing the ac compressor? How about going to an electric fan?
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
post #67 of 109 Old 08-12-2012, 06:50 PM
Maverickxeo
Originally Posted by castorriver View Post
Does anyone know how many ho you gain from removing and bypassing the ac compressor? How about going to an electric fan?
Not enough to make it worthwhile. Well, the AC compressor probably uses a fair bit (with it running) but with it OFF, its probably about 5HP at the crank, and an electric fan may net you about 10HP at the crank.
I actually havent done either of these, but Im going by the averages seen by other vehicles.
Maverickxeo is offline
post #68 of 109 Old 08-12-2012, 07:55 PM
castorriver
It's on my list of things to do. The ac hasn't worked on my jeep since I got it and I'm not going to fix it so I have nothing to lose.
post #69 of 109 Old 08-12-2012, 09:46 PM
Border Dave
Got Sand?
Border Dave's Avatar
Originally Posted by Maverickxeo View Post
... but with it OFF, its probably about 5HP at the crank, and an electric fan may net you about 10HP at the crank.
I actually havent done either of these...
Oh, how I love the internet!
Border Dave is online now
post #70 of 109 Old 08-13-2012, 12:07 PM
Maverickxeo
Ive done them, but not on a jeep, and have had some proven gains.
post #71 of 109 Old 08-14-2012, 04:17 PM
castorriver
That's good enough for me.
When I had a Geo Metro I had to turn off the ac on the highway when I was accelerating to speed or pulling a long hill... Otherwise I couldn't keep up.
post #72 of 109 Old 08-17-2012, 12:00 PM
alleyoup
Ok the wife and i bought a 2007 sahara soft top.. (i have a 2010 sahara hard top)anyway when it rains the drivers seat belt inside the door frame gets wet. Can anybody tell me where it might be leaking. The top looks like its sealed but im very new too all this and we dont have a garage.
alleyoup is offline
post #73 of 109 Old 08-17-2012, 12:56 PM
Squish91
check the seams, the stitching tends to pull apart overtime. I have found the best fix for it is to take a small amount of clear silicone and run it along the stitches. If its done right you wont even notice it and it keeps the water out very well.
Squish91 is offline
post #74 of 109 Old 08-17-2012, 02:01 PM
Stud_man50
I never thought a thread from 06' would 1. survive this long and 2. turn into talking about leaking tops 6 year later!
Stud_man50 is offline
post #75 of 109 Old 08-19-2012, 01:47 AM
gr4y
window tint
gr4y is offline
4.0 Performance upgrades. boondaba Engines & Drivetrain 5 08-17-2009 12:49 PM
Cheap Performance Upgrades mekanik Street Jeep Forum 2 06-03-2008 11:23 AM
Performance upgrades for my 05 grand cherokee 3.7 V6 djoc2000 Engines & Drivetrain 2 02-13-2006 08:05 PM
Places to get performance upgrades- CETROV Fabrication Shop 3 06-23-2003 10:27 PM
Engine performance upgrades eastwood Engines & Drivetrain 24 02-01-2003 01:19 AM
