Quantcast Cheep/Free performance upgrades - Page 4 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Trick & Fixes > Cheep/Free performance upgrades
Old 07-15-2009, 08:36 PM   #46
crem
1993 XJ Cherokee
Originally Posted by Muddy Cherokee View Post
Lighten your load. If you're not wheeling do you need all your tools, Hi-Lift, Jerry cans, water and recovery gear? Losing 100 pounds gives you about .1 second on a quarter mile, so theres your performance. It will also take less throttle (therefore less gas) to accelerate and get over hills. Less weight will also reduce strain on suspension and drivetrain components.
...that and leave the fat girlfriend at home..
-Cory
1992 White Cherokee SOLD
-4.5 Lift
-35" Mickey's
-Axle Swap
-Custom bumpers
1993 Forest Green Cherokee Stock.. for now
4.0 bored over to a 4.2 Manual 4dr
Originally Posted by ghettosled View Post
hey, slap a toyota emblem on the trunk and scream "unintentional acceleration!"
crem is offline   Reply With Quote
Old 07-17-2009, 09:02 PM   #47
3S00W
by a JF membership, the sticker does wonders!!! It got my jeep all the way to ATL w/o ever turning the ignition!
M O O S E
J E E P : the dirtiest four letter word
1980 CJ5 5.7L 2006 TJ 4.0L 1990 XJ 4.0L(RIP)
3S00W is offline   Reply With Quote
Old 08-06-2009, 01:34 PM   #48
DUTCH97501
TB Boring
What about TB boring. It was free and If you have a cracked manifold the install of a header along with the free tb boring makes for a nice gain.
DUTCH97501 is offline   Reply With Quote
Old 08-20-2009, 04:52 AM   #49
InEmberClad
Originally Posted by Xtant View Post
Dude...don't listen to the haters...you can get a tornado off ebay for like $10. It'll make you faster AND save MPG. It's the shiznit.
I watched something on tv where they popped one of those in and put the vehicle on a dyno. Doesn't give you squat for hp and any mpg improvements you get are likely because you're losing hp as a result of decreased airflow.
InEmberClad is offline   Reply With Quote
Old 08-20-2009, 10:47 AM   #50
Mystake
Originally Posted by Davejb View Post
This is actually a common mod on Dakota's and Ram's, i did it to Dakota when I had it, it does have an effect. Haven't done it to the Jeep yet because it's too cold out!
As a member part of a Dakota/Durango forum... where it's only dakotas and durangos... I've never heard of this trick. I've been a member of that forum for some time now and I've never heard of this.
Keep in mind, I have an '01 Durango SLT+, AWD with the 5.9L
And trust me, we're all hurting for MPG on that forum
Mystake is offline   Reply With Quote
Old 08-20-2009, 10:51 AM   #51
Mystake
Originally Posted by Jeepguy00 View Post
Almost everything i have on my jeep is custom, i made a 2 inch spacer out of aluminum and bored it to 62mm, that made a difference with throttle response low end, that was a cheap mod for me because i got the material for free, and made it at work, but you can buy spacers online or in quadratec for around 60$, very easy to install too
Throttle Body spacers don't do squat. At least, in the magnum V8's they don't. The only purpose they would have is to give air and fuel more time to mix, aka a 2inch spacer gives fuel and air 2 more inchs of time (however fast the flow is) to mix in together.
BUT
In the Magnum V8's there is only air that goes through the throttle bodies. Therefore, no fuel is mixing. Therefore: the spacer doesn't actually allow anything to mix in and is therefore only good as a paper weight. it would do something with NOS systems where the Nitrous mixes in with the air and it can serve as a good location for the NOS to enter the air intake.... ish... I can't really explain it all that well.
I don't know about the 4.0L or the 4.2L because I haven't researched them enough. I only know this for the V8 Magnums as well as the 3.9L v6
I guess I'll find out more about the 4.2L when I go tearing into the Jeep later today!
source: I have a 5.9L Durango
Old 09-04-2009, 11:02 PM   #52
Castr8r
The throttle body spacer adds volume to the intake manifold plenum, giving a potentially larger volume of "air" to draw from. The results are generally of value to drag racers that are trying to eke out that last shred of speed.
I added a TB spacer when I rebuilt my 2.5 banger, and I don't really know if it helped. It didn't hurt either, so it will stay in place until the next rebuild- if I'm still alive!
Castr8r is offline   Reply With Quote
Old 09-04-2009, 11:06 PM   #53
Mystake
How does it add volume?
If the throttlebody barrel is 50mm, a 52mm spacer is bottle necked. Again, it doesn't do anything. Where does this "larger volume of air" come from? It still goes through the throttlebody. It just makes the throttlebody sit higher.
Old 09-06-2009, 10:39 PM   #54
wbrett1027
hahahahaha yeahhhhh. and i put rocks in my engine to make it go faster
wbrett1027 is offline   Reply With Quote
Old 09-13-2009, 07:43 PM   #55
gonejeepin04220
1995 XJ Cherokee
drill some holes in the air box..put the air right to er!
gonejeepin04220 is offline   Reply With Quote
Old 09-16-2009, 01:29 PM   #56
dsnell10
Cheap? ya right haha. good luck with that. the cheapest mod ive done is an air intake and exhaust.
dsnell10 is offline   Reply With Quote
Old 09-16-2009, 09:37 PM   #57
FaT00CaJuN
Ive just read an ancient forum artifact thread. I Feel Special!!
Where Were Going We Don't Need No Roads.
FaT00CaJuN is offline   Reply With Quote
Old 08-07-2011, 01:44 PM   #58
Tylerzap
1977 CJ7
This. is. dead. again. BRING IT BACK!!! has to be somthing out by now...
Tylerzap is offline   Reply With Quote
Old 08-09-2011, 08:40 PM   #59
Lre78hd
Well this is what I did it's easy and you actually make gas if you buy enough. I bought all the mpg increasers , filters, magnets for the fuel line, tornadoe ( this one pit me over 100% ) , g meter, etc and I added up the percent that each one adds. I'm at 135% so the way I figure it is I'm making gas. Take that bp
Lre78hd is offline   Reply With Quote
Old 08-10-2011, 12:47 AM   #60
wacked
I'm not sure exactly how TB spacers work better, but intake runner length does have a lot to do with low to mid range torque. How much length makes a difference I don't know. If a 1" or 2" TB spacer on a 4.0 makes a difference I couldn't say as there are other factors involved also..
But an example of long intake runner length was on the C4 Corvette Tuned Port Injection system (TPI of the mid 1980's) which had a total intake length of 17 inches and produced incredible torque at a low RPM. In fact, there was a modified system to gain more upper rpm power by shortening up the overly long intake runners. I'm pretty sure intake runner length is directly related to intake velocity at a given RPM range - longer length for low rpm and shorter length for high rpm.. The TPI long intake runners were great for low end, but sucked for upper rpm gains in power..
wacked is offline   Reply With Quote
Glock Forum
