Quantcast Cheep/Free performance upgrades - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Trick & Fixes > Cheep/Free performance upgrades
Old 01-05-2007, 09:02 AM   #16
ryobi
Haaahaha. That's funny.
Originally Posted by Xtant
Dude...don't listen to the haters...you can get a tornado off ebay for like $10. It'll make you faster AND save MPG. It's the shiznit.
ryobi is offline   Reply With Quote
Old 01-05-2007, 01:39 PM   #17
Barchack
every review that i've read from a trusting source says that the tornado actually hurts gas mileage and performance.
'94 Cherokee Sport w/ 3.5" Skyjacker double-flex lift with new full leafs, plus some other goodies.
Near Binghamton, NY
I remember when jeepforum was ugly...
Barchack is offline   Reply With Quote
Old 01-05-2007, 06:49 PM   #18
eclipse27
it is the dumbest thing first of all. Second of all, without extra "fuel", theres no purpose of "sucking in extra air".... Stock engines suck in more air then they need. Its not doing anything. Same with those cheap "10 chips" you pop in your sensor and it adds 20hp. IT DOESN"T WORK. Dont waste your money.
eclipse27 is offline   Reply With Quote
Old 01-05-2007, 06:53 PM   #19
AlaskaTJ
the point of something like the Tornado(which doesn't work) is atomization, not increase in airflow. The more you can atomize the fuel(which is helped by the swirling of the air intake charge), the more efficiently it burns.
But the tornado doesn't help, because the head design is almost always the limiting factory in airflow characteristics...and any swirling the tornado may or may not introduce to the intake is canceled out by the head porting.
AlaskaTJ is offline   Reply With Quote
Old 01-06-2007, 09:09 AM   #20
360wrangler
cheap no!!! get a cc with a high limit and go nuts!!
360wrangler is offline   Reply With Quote
Old 01-08-2007, 05:12 PM   #21
pendleton
A GM small block is relatively cheap!
pendleton is offline   Reply With Quote
Old 01-09-2007, 12:29 PM   #22
littleman66
http://www.angelfire.com/my/fan/IAT_sensor.html
claims to make horsepower for pretty much free
2001 60th Anniversary TJ.
2" BB. 31" Goodyear Wrangler MTR's
Dana44 LSD. front Aussie Locker
homemade rear bumper with hitch, two recovery points
dual battery. 1750 watt inverter
Dukes of Hazard/Dixieland horn. Neoprene seat covers
littleman66 is offline   Reply With Quote
Old 01-25-2007, 04:34 PM   #23
Xtant
Currently Depolyed
Xtant's Avatar
Oops...forgot the "[sarcasm]...[/sarcasm]"
Well, in the mustang world there's a saying: You can have fast, cheap, reliable...but only 2 out 3 at the same time.
2004 Wrangler X: 4.0 auto, black on black on black, REBB, 1.5" JKS BL, 1" JKS MML, 33x12.5x15, Black Soft 8's, homemade front bumper and steering skid...more armor to come in a year or so
1989 Mustang GT vert: stripped shell of a project that hasn't been started.
2006 Suzuki SV650S: Went nekkid. Aztec8 setup, Pazzo levers, M4 full Ti exhaust, PCIII, Poly26 belly plan, GSXR rear shock upgrade, Sonic springs and emulators
Xtant is offline   Reply With Quote
Old 01-25-2007, 05:58 PM   #24
Bigbob
Bigbob's Avatar
Originally Posted by deermanjoe
What are some cheep/free upgrades I can do for the 4.0 jeep? Example Engine, Air cleaner, airbox.
If your air box has a air horn that looks like a trumpet pull it off. It just twists off. You can feel a difference, not much, but free. If you drive in a lot of water don't do it.
Here's an interesting read. Not more power, but better MPG. I may try this for kicks to see if it is true.
http://www.jeepforum.com/forum/f9/rubicon-mpg-improvement-363465/?highlight=intake
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline   Reply With Quote
Old 02-17-2007, 11:55 AM   #25
Davejb
This is actually a common mod on Dakota's and Ram's, i did it to Dakota when I had it, it does have an effect. Haven't done it to the Jeep yet because it's too cold out!
Davejb is offline   Reply With Quote
Old 02-17-2007, 04:02 PM   #26
firejeeper
[QUOTE=lj_wil]Tighten the flux capacitors [/QUO
00 TJ 2.5L recently to 4.56, no lockers :( 2" budget boost
Warn front bumper, JKS discos, Fire extinguisher, high lift jack and 12 ga Remington 870 (for the squirrels)
firejeeper is offline   Reply With Quote
Old 02-18-2007, 05:35 PM   #27
JeepBro5
Wow... people get real excited about gas milage. If that were an actual in-person conversation I think someone would have died.
It would be nice to see some actual dyno numbers on that waste exhaust heat setup though.
JeepBro5 is offline   Reply With Quote
Old 03-06-2007, 08:02 PM   #28
Jeepguy00
Throttle Body Spacer
Almost everything i have on my jeep is custom, i made a 2 inch spacer out of aluminum and bored it to 62mm, that made a difference with throttle response low end, that was a cheap mod for me because i got the material for free, and made it at work, but you can buy spacers online or in quadratec for around 60$, very easy to install too
Jeepguy00 is offline   Reply With Quote
Old 03-12-2007, 12:43 AM   #29
gregs887
Up your butt Jobu
gregs887's Avatar
go easy on the skinny pedal
Greg
Never underestimate the predictability of stupid- Bullet Tooth Tony
gregs887 is offline   Reply With Quote
Old 03-12-2007, 01:08 AM   #30
Muddy Cherokee
Lighten your load. If you're not wheeling do you need all your tools, Hi-Lift, Jerry cans, water and recovery gear? Losing 100 pounds gives you about .1 second on a quarter mile, so theres your performance. It will also take less throttle (therefore less gas) to accelerate and get over hills. Less weight will also reduce strain on suspension and drivetrain components.
[SIZE="1"]1996 Cherokee Sport
4.0L HO, AX-15, NP 231
RE 4.5" Lift, 32" Dunlop Mud Rovers, RE Hack'n'Tap, CV Driveshaft, D30/D44, 4.10's, Aussie Lockers, ZJ Tierod, F/R recovery points[/SIZE]
Muddy Cherokee is offline   Reply With Quote
Glock Forum
