Cheep/Free performance upgrades - Page 10 - JeepForum.com
 5Likes
post #136 of 140 Old 09-20-2017, 06:42 AM
Ross
Originally Posted by Jeep25 View Post
I'm running Firestone Destination 225/75/15
I checked the side wall and it shows a max of 44psi.
So 35psi is fine.
Thanks
Nope
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is offline
post #137 of 140 Old 09-20-2017, 06:43 AM
Ross
Checking Tirerack, shows Firestone Destination tires when putting in 2003 Jeep Wrangler X (which I was informed is the Freedom Edition with some upgrades).
https://www.tirerack.com/tires/TireS...inLoadRating=S
Does not matter. IT IS ALL BASED ON THE WEIGHT OF YOUR LOAD!
Ross is offline
post #138 of 140 Old 09-20-2017, 06:52 AM
Jeep25
Totally stock.
If the side wall shows max of 44, how can 35 be to high with a stock Jeep.
Jeep25 is offline
post #139 of 140 Old 09-20-2017, 07:01 AM
Ross
Totally stock.
Those tires are made for a wide range of vehicles not specifically for your Jeep Wrangler. People with heavier Vehicles carrying heavier loads can also use them. Firestone does this so they can sell the same Tire to mrore people therefore increasing their profits.
This is not just a firestone thing, all tire manufacturers do this.
Ross is offline
post #140 of 140 Old 09-20-2017, 10:24 AM
cranbiz
Ross is right.
Here is a real world example, my BFG tires on my JK have a sidewall rating of 65 psi and a load range E. This is the pressure you should run in a full size pickup carrying the maximum load the tire is rated for. On my JK, the factory says 33 psi on the original P225/75R16 tires. You can't go by this with P305 tires. So I needed to calculate the max weight I would carry and the weight of the Jeep and then calculate what psi I needed. In my case, P305/65R17 BFG KO2 tires require 28 psi.
Read up on tire pressure here. https://www.4wheelparts.com/tire-whe...e-checker.aspx
06 KJ
12 JK,2.5" Teraflex lift,Bilstein 5100's,BFG KO2's P305/65R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
4.0 Performance upgrades. boondaba Engines & Drivetrain 5 08-17-2009 11:49 AM
Cheap Performance Upgrades mekanik Street Jeep Forum 2 06-03-2008 10:23 AM
Performance upgrades for my 05 grand cherokee 3.7 V6 djoc2000 Engines & Drivetrain 2 02-13-2006 07:05 PM
Places to get performance upgrades- CETROV Fabrication Shop 3 06-23-2003 09:27 PM
Engine performance upgrades eastwood Engines & Drivetrain 24 02-01-2003 12:19 AM
