Cheap yj mods - Page 2 - JeepForum.com
post #16 of 37 Old 09-29-2008, 08:54 AM
JaikYJ
You can trim your fender flares.
Best cheap mod I like are the round tail lights that are flush with the body. I paid 20 bucks for both of mine.
Foot pegs are cheap and easy to make if you ride without your doors.
There is a really good thread in the TJ forum its a sticky its called what have you made for your TJ
87 YJ(sold), 97 TJ(sold), 99 TJ(daily)
03 R1 (fun)68 Mustang Coupe(summer)
67 Fastback(resto)
JaikYJ is offline
post #17 of 37 Old 11-05-2008, 05:58 PM
thetrashman
remove traction bars and sway bars
HOW THE HECK DO YOU DO THAT!
(whoa caps)
but seriously, is it hard?
and other than what you stated is there any disadvantage?
95' Little Red Yj.
"My Jeep Doesnt Leak, Its Just Marking Its Territory"
Mostly Stock,With A Few Things
thetrashman is offline
post #18 of 37 Old 11-05-2008, 06:25 PM
Rowengarner
Read this thread.
Everything you need to know about removing track bars or swaybar.
http://www.jeepforum.com/forum/showt...oving+sway+bar
88 YJ 2.5L
Rowengarner is offline
post #19 of 37 Old 11-05-2008, 06:30 PM
thetrashman
thank you:]
95' Little Red Yj.
post #20 of 37 Old 11-30-2008, 09:53 PM
jmenegazzo
cheap mods for the YJ
We have the exact same one for YJīs search that...also the "I made a____for my YJ...lots of good ideas (its all homemade stuff)..hereīs the link
http://www.jeepforum.com/forum/f12/i-made-_____-my-yj-post-your-homemade-jeep-stuff-here-457361/
a cheap mod you can do is to add storage room with ammo boxes,, in the thread above you can find what i did.
weīre in the same boat,,,, in college and broke jjajaja
"If It Scares You, Then Do It"
"Jeep Harder"
--Your YJ is like sex, when itīs good itīs terrific and when itīs bad itīs still pretty good.--
jmenegazzo is offline
post #21 of 37 Old 09-13-2010, 06:30 PM
Bone_Stock95
Do you have any more info about this lift. I want to give my Yj a little bit of a lift.
Bone_Stock95 is offline
post #22 of 37 Old 09-22-2010, 06:38 AM
McFatter
Originally Posted by Jesse-James View Post
Here's a link for the tank conversion.
15 to 20 gal
I did this to mine and its the best thing that I have done to it so far. It used to take me 30 min to fill up my jeep and now it fills up like it should
McFatter is offline
post #23 of 37 Old 09-29-2010, 03:22 PM
Remops
I didnt see what year you have, but you could do the Blazer heater upgrade. I did it last weekend and it is AMAZING!! Nutter bypass, and emissions removal. I removed all my unnecessary vacuum lines and it runs GREAT. Once again, not sure about the year but search this forum for any of the aforementioned mods and youll get a lot of posts. Good luck!
Remops is offline
post #24 of 37 Old 07-20-2011, 03:14 PM
fdurham
On 2.5l liter engines you can visit the local junk yard and do a 4.0l throttle body convertion swap should run about 30 bucks or so just make sure the cherokee or wrangler you pull it out of is the same year or newer for emissions
fdurham is offline
post #25 of 37 Old 10-04-2011, 07:53 PM
mikesloudjeep
great reading!!!
Holy smokes this is great info! I keep coming to this site then google something that comes right back to it!
mikesloudjeep is offline
post #26 of 37 Old 09-26-2012, 06:35 PM
TeamJeepCrew
$15 mod!
A cool mod you can do is Rhino Line or Bedline your grille. I just did that to mine with Rustoleum Truck Bedliner spray for $7 and also bought a sheet of diamond mesh lath from home depot for $8 that I attached a section of it to the inside of the grille to use as a rock guard for protection of my radiator. I chose to spray paint the lath black so that is would not be noticeable and the grille looks awesome. As long as you follow the instructions on the can and just apply like 4 light coats, you will be good.
TeamJeepCrew is offline
post #27 of 37 Old 10-20-2012, 08:05 AM
J-BIRD-MEDIC
1987 YJ Wrangler
Some awesome tips. thanks to all the contributors!
1987 Wrangler YJ 4.2L (purchased 9/2012)
1999 Cherokee XJ (DD)
1999 Wrangler TJ (traded in for mini-van 2005) :(
J-BIRD-MEDIC is offline
post #28 of 37 Old 10-23-2012, 06:56 PM
ashland82391
tubes fenders around $80 dollars
Tire carrier from s10 blazer, cost 30$ and 10$ in grinding wheels.
ashland82391 is offline
post #29 of 37 Old 10-27-2012, 10:44 PM
mark9998
2010 JK Wrangler
good ideas Ill have to print this one out for my step dad since he has a yj
mark9998 is offline
post #30 of 37 Old 11-27-2012, 11:00 AM
Kuntryboy816
Kuntryboy816's Avatar
Paint it to look like what you want it to...... less than $100!!
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is offline
Cheap Cool Mods WranglerConway Cheap Tricks & Fixes 1364 01-12-2017 08:17 PM
cheap 4.0 mods? redneckwithajeep Engines & Drivetrain 17 01-04-2015 02:33 PM
best cheap perfomance mods?? flowrida2480 Engines & Drivetrain 14 12-13-2009 11:23 PM
cheap xj mods?? hoot20 Cheap Tricks & Fixes 0 05-25-2009 02:52 PM
CJ-7 Cheap Mods GoldenEagleGa Cheap Tricks & Fixes 1 02-06-2009 11:53 PM
