Quantcast Cheap wal-mart remedy for a prop top? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Trick & Fixes > Cheap wal-mart remedy for a prop top?
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 04-26-2006, 02:04 PM   #1
losfreddy
has anyone ever made thier own prop top? i was thinking along the lines of cutting a strip of plastic out of a gaint rubbermaid box and invert it out. I really dont see how hard it could be to make your own if you can find a good material. ANy ideas?
99 TJ. 5 sp Manual. 4 cylinder. 2.5 liters. airaid intake.
Rock Guards. 32x11.50r15. 4 inch lift. nitro Shocks.
losfreddy is offline   Reply With Quote
Old 04-26-2006, 02:24 PM   #2
badoosh27
what is a prop top?
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
[url]http://www.cardomain.com/ride/2634280[/url]
badoosh27 is offline   Reply With Quote
Old 04-26-2006, 02:30 PM   #3
losfreddy
a prop-top is a strip of plastic that hold up your front half of the soft-top so it will stop flapping in the wind, make rainwater roll off instead of gather and prolongs life of soft-top due to less wear and tear..
http://www.4wd.com/newsite/shop/productdetail.asp?pid=8532
Old 04-26-2006, 02:55 PM   #4
Bgeddes
Ridin' with the King
I saw pictures of one some guy made out of PVC pipe. Looked great for $4.
'05 KJ CRD and '00 XJ Classic > Stock DDs
'88 YJ Sahara > Weberized, HEI, Shackle Lift, Herculiner, more on the way
Bgeddes is offline   Reply With Quote
Old 04-26-2006, 03:06 PM   #5
adam728
Fiberglass rod, like from a bicycle flag pole.
adam728 is offline   Reply With Quote
Old 04-28-2006, 12:07 AM   #6
schitzangiggles
King of Mac-istan
schitzangiggles's Avatar
Get 2 1.75-2in X .5in PVC "T"s, a stick of .5in PVC and some glue.
Cut the "T"s in half with the connector part for the .5in PVC intact. Cut a length of 5.in PVC that is @ 1-2in longer than the width of the bars that connect the windsheild to the roll cage (streamer bars). Place the .5in PVC into the connector on the "T"s so it looks like an "I". Place the short ends of the "I" on the streamer bars and bow the PVC up. Test fit to make sure it is the proper length before gluing everything together. I wish I had some pics of the one I did (sold that jeep) to help out with the description.
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline   Reply With Quote
Old 04-28-2006, 07:18 AM   #7
jeep loser
Need a better discription^^^^^^This just doesn't make sense
5 % of people make things happen
65% of people let things happen
30% of people say "what happened?"
jeep loser is offline   Reply With Quote
Old 04-30-2006, 10:08 PM   #8
M&C_TJ
Sure it makes sense well to me it does. Just take a T connect peice of pvc pipe and cut in half on the top of the T part. That part will be placed on the "streamer bar" (the part of the roll cage that connects your windsheild and the roll cage behind your head.)
Then take a peice of regular pvc pipe that will fit in the other end of the T that you did not cut. Do the same for both ends. That part of the T that is cut in half will be placed on the top of the streamers.
The pipe will connect both T's and you need to cut them a little longer than the width of the inside of the streamer bars. I would use some hose clamps to hold the T on the streamer bar just a thouht.
All you have to do is get the size of piping want like giggles said 1.75"x2"x5" T and you need 2 of them. What that means it the top of the T is 2" long and leg of the T is 1.75" long and the holes are .5" in diameter. Then you need a pvc pipe that will fit in the .5" diameter hole in the leg of the T. Then if it fits to your personal standards then glue it all together.
Does this make a little more sense just going by what i can imagine in my head?
Rock Krawler 5.5 X-Factor L.A. Rock Krawler Heavy Duty Steering System AA SYE and TW CV DS
D44 w/ superior shafts/D44 w/ usa alloy shafts from northridge ARB front and rear
Pro Comp series 97 Rims holding 35" BFG A/T
M&C_TJ is offline   Reply With Quote
Old 05-01-2006, 06:16 AM   #9
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
I used to put a frisbe on a stick and stand it on the console. Now I just leave the top off all summer, park it inthe garage, and take the Durango when it rains.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers
JeeperDon is offline   Reply With Quote
Old 05-01-2006, 06:26 AM   #10
M&C_TJ
well that is a good idea too i like that one and you can be lazy too.
Old 05-01-2006, 04:49 PM   #11
jeep loser
I went the pvc route, it works pretty well, Kind of redneck looking, but so's my jeep.
Old 05-01-2006, 10:20 PM   #12
TJ_with_Tusks
eh, its only $40 for a real one. You're not saving that much. I'd just buy one.
04' Columbia TJ
33" BFG AT's, OME HD lift, front airbag suspension, teralow 4:1 kit & supershort shaft kit, TW CV shaft, 4.10 gears, JKS body lift, track bars and quicker disconects, Warn 9.5ti, warn front bumper, garvin wilderness rack, and solid cast aluminum tusks,
TJ_with_Tusks is offline   Reply With Quote
Old 05-01-2006, 10:29 PM   #13
TellyDSP
Poland and PPV!!!!
http://jeepforum.com/forum/showthread.php?t=191252&highlight=prop
I made one last year and it worked great. No need to glue anything together. The pressure does it just fine. Make sure to get the thin walled stuff for the cross piece.
-Craig-
95 Rio Grande
07 Ram 1500
SIRA4x4 Club
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline   Reply With Quote
Old 05-02-2006, 01:40 PM   #14
AWILD
I bought an extendable ice scraper (dual use in MI)...just extended it, twisted it closed, and viola!, a $5 no rain puddles, no 100lbs of snow on my top prop.
TJ
4.0L, 5spd, 2"BB, 31x10.5 Mud Terrains, Black Steelies,Hella 100W, Custom Brushguard, IPF H4 housings w/ Fatboys, Sirius 23 Hair Nation!
AWILD is offline   Reply With Quote
Old 05-02-2006, 02:44 PM   #15
M&C_TJ
looks good telly
Glock Forum
