Cheap spindle puller - JeepForum.com
post #1 of 1 Old 10-12-2004, 09:00 PM Thread Starter
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Weld a spindle nut to an old spindle wrench. Then weld a nut over the ratchet hole. Run a long bolt through the nut. To use, simply spin the spindle nut on the spindle till it bottoms. run the bolt in till it contacts the stub axle. Continue to turn the bolt and it will pull the spindle off. If it acts like it won't come, smack the bolt lightly with a hammer. This simple tool makes servicing the spindle bearings on a D30/44 open knuckle front axles a snap.
jeepdaddy2000 is offline
spindle, is it really a must?? shu2kill Fabrication Shop 10 02-20-2009 07:58 AM
Dana 30 Bearing Puller james509 Engines & Drivetrain 4 10-04-2006 08:30 AM
D44 spindle bearings rustyCJ General Jeep & Off-Road Equipment 2 08-20-2005 06:36 AM
use a hand puller for a winch???? Brandon Moore General Jeep & Off-Road Equipment 8 05-16-2005 07:33 AM
Crank Pulley Puller? MudLover Engines & Drivetrain 1 03-22-2004 01:00 PM
