Quantcast Cheap soft top padding replacement - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Trick & Fixes > Cheap soft top padding replacement
RUBICON EXPRESS Lift Kits and Accessories Available at BasTruck-Lite's New LED Headlamp SeriesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 08-09-2007, 01:37 PM   #1
malone_ge
Not sure is someone has suggested this but:
The foam on my soft top frame rotted and tore so I used a couple of those pool noodles to replace it. The hollow ones are the perfect outside diameter so you just have to cut it lengthwise, and make some notches for the snaps. A couple wraps of duct tape and you’re set.
I got mine at the dollar store so my grand total was $2.
Enjoy...
malone_ge is offline   Reply With Quote
Old 09-05-2007, 11:54 PM   #2
bjf498
1983 CJ7
you can just use some pipe insulation from home depot
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline   Reply With Quote
Glock Forum
