Cheap seat lift - Page 5 - JeepForum.com
post #61 of 72 Old 12-22-2008, 08:37 AM
Mud Machine
Jeep Addict
Mud Machine's Avatar
Originally Posted by Krautzy View Post
Sorry to bring up an ancient thread,but does anybody who has done this mod know if ALL the seat mounting bolts are the same length? This will be going into an 04 TJ this weekend, and Id like to keep the parts runs down to a minimum. Thanks!
Check out post #24 in this thread for the sizes you need.
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, 35" Pittbulls, 5.13's, Revolution Axle Shafts, LS-III, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #62 of 72 Old 01-16-2009, 02:21 AM
storman113
New to Jeep's and I just love this forum!! Read thru all the post and went with the 1'' riser kit. (leery of the hockey puck fix). What a difference! Don't feel like a old lady looking thru the steering wheel and the sun visor works now!
storman113 is offline
post #63 of 72 Old 07-06-2009, 05:27 PM
VanBCguy
How well do they work?
Originally Posted by droogsnightout View Post
I used a set of skateboard wheels. They cost about $10 for a set of four and give about an inch and a half of seat lift. They are the perfect size and already have a hole drilled, so no sawing or drilling. $2 for longer bolts from the local hardware store and in 10 minutes I was done. Plus they seem to absorb some vibration. Absolutely love it, only problem is now I have to duck under the windshield frame to see the stoplights. Feels like a custom fit Jeep!
Just came across your post about using skateboard wheels as seat risers. I have a 03 TJ and am used to the 02 TJ I used to own awhile ago that had an extra 1.5" of seat rise. I'm wondering if you could let me know how the skateboard wheels worked for you? Any problems or would you recommend doing the same thing?
Thanks!
P.S. - What diameter and length bolts did you use?
VanBCguy is offline
post #64 of 72 Old 07-08-2009, 01:31 PM
jweaver321
Does anyone else have to lean forward to see traffic lights through the windshield? I can't imagine wanting the seat any higher...
jweaver321 is offline
post #65 of 72 Old 07-08-2009, 01:34 PM
Bigbob
Bigbob's Avatar
Ditto. 6'6" here. My head hits the rollbar!
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #66 of 72 Old 08-18-2009, 10:12 AM
cleveland2009
Bigbob,
What was your solution? I have a 92 so I'm not sure the mastercraft brackets will work? I'm 6'4, please help!
cleveland2009 is offline
post #67 of 72 Old 08-18-2009, 11:12 AM
prd_cdn
prd_cdn's Avatar
Originally Posted by eclipse27 View Post
i unno if i can go with a higher seat lift...my legs hit the steering wheel already...and my heads not to far from the roof. the only thing i can think of is fabing up something to make my seat flush with the end of the cab.
I am in the same quandary, I want to do this mod, I dont want my legs hitting the steering wheel.
Then again, if it is an issue, I could always take it out ... just as easy as I put it in.
prd_cdn is offline
post #68 of 72 Old 09-01-2009, 10:43 PM
Fireman4949
One thing to consider is to use Grade-8, or the metric equivalent (I believe they are 10.9) bolts. They will help to prevent shearing of the bolts and the seat dislodging if involved in an accident.
The difference in the cost of the bolts is negligible, but the added safety is invaluable.
Fireman4949 is offline
post #69 of 72 Old 09-08-2009, 10:06 AM
maaghimself
Does this work for those of us without tilt wheels?
maaghimself is offline
post #70 of 72 Old 11-19-2009, 10:48 PM
Terrible2
Originally Posted by awlamas View Post
ok Im going to do this but I have 2 ques........1. Does this sacrafice SAFTEY in the seat?.....2.Does anyone know the exact size of bolt I need for my unlimited?
THANKS
I know this is an old thread, but if you look on the first page, it says the govt mandated that 03+ Jeeps be lowered further to accommodate for the Air Bag and where it hit. Also I can only imagine the risers not being threaded therefore making it easier for the bolt to rip out including the seat. BUT I really dont see that happening, never really heard of some guys seat flying out, not to mention the seatbelt should keep you strapped in.
I was thinking about putting in seat risers, but I kinda want my safety.
Terrible2 is offline
post #71 of 72 Old 01-21-2011, 04:34 PM
monkeygruven
Sorry to resurrect a super old thread, but what diameter bolt & thread size are the bolts for the seats? I know the T-50 Torx on the inside rear bracket is larger than the other three corners, but that's it. Diameter? Thread size?
Originally posted by MotoSoul:
The real trail rated badges are located on your skid plates.
monkeygruven is offline
post #72 of 72 Old 03-25-2013, 09:31 PM
njohnson412
Originally Posted by UnlimitedFun View Post
While I definately like the idea of more height in order to see better, I really don't need any more leg room. I'm only 5'5" and my wife is 5'4"...she stretches as it is sometimes when driving. Any ideas on improving visibility without having to grow taller first???
try putting pucks in the back brackets and not the front or if its too steep make the front pucks a little smaller in height then the back ones so it is not such a big difference.
Im only 5'3" so i am defiantly going to be doing this seeing as my steering wheel adjuster was not there when i bought my tj
njohnson412 is offline
cool stuff cheap seat covers and tool pockets abbe Cheap Tricks & Fixes 9 10-10-2013 03:50 AM
cheap lift yes or no? vito30 General Jeep & Off-Road Equipment 2 01-06-2009 09:07 AM
cheap lift kit? FifteenCents Tires & Wheels 13 12-23-2005 05:50 PM
Cheap Lift bluejeepguy Tires & Wheels 1 01-03-2005 08:58 PM
cheap lift PoorFool Tires & Wheels 3 05-15-2002 08:02 AM
