Cheap seat lift - Page 2 - JeepForum.com
post #16 of 72 Old 08-23-2006, 11:25 PM
i6jeep_1989
good idea.....
i6jeep_1989 is offline
post #17 of 72 Old 08-24-2006, 09:01 PM
eclipse27
only prob. no place to put all my tools behind my seat.
eclipse27 is offline
post #18 of 72 Old 08-25-2006, 04:48 PM
subculture08
[QUOTE=madmikey
Performance Accessory
So if you want 1" of lift order part #MB01 = 1"H x2"W sells for $1.31 cnd each
and if ya want 2" of lift order part #MB02 = 2"H x2"W sells for $3.99 cnd each
[/QUOTE]
Anyone know where these can be ordered online?
subculture08 is offline
post #19 of 72 Old 08-26-2006, 07:29 AM Thread Starter
madmikey
madmikey's Avatar
Go to www.driverfx.com
BEER
Now cheaper then gas!
Drink,don't drive
madmikey is offline
post #20 of 72 Old 09-22-2006, 12:05 PM
Songman
1990 FSJ Wagoneer
Originally Posted by UnlimitedFun
While I definately like the idea of more height in order to see better, I really don't need any more leg room. I'm only 5'5" and my wife is 5'4"...she stretches as it is sometimes when driving. Any ideas on improving visibility without having to grow taller first???
Just put the spacers under the rear of the seat. It will raise your bottom up and make your head higher, but won't make you have to have longer legs to reach the pedals.
Songman is offline
post #21 of 72 Old 09-28-2006, 09:39 PM
D_Dude2000
cool idea, i'm definatly going to think about possibly considing that.
D_Dude2000 is offline
post #22 of 72 Old 09-29-2006, 09:10 AM
Scorer75
Awesome idea, thanks.
Scorer75 is offline
post #23 of 72 Old 10-01-2006, 08:34 AM
BostonJosh19
Trombino
Looks good. What size and length bolts did you use? Are these all the parts you needed? Puck, Bolt and washer...for each one obviously.
Thanks.
I'm definetly thinking about doing this.
97 WHITE TJ SE | Hard & Soft Top | D30/D35 3.73 | LINED TUB
MORE TO COME.
BostonJosh19 is offline
post #24 of 72 Old 10-01-2006, 02:04 PM
Trombino
Trombino's Avatar
1978 CJ7
Originally Posted by BostonJosh19
Trombino
Thanks.
I used (1) 7/16-20x2 hex-head bolt and (3) m8-60 hex-head bolt. Then just (4) pucks cut to size and that's it. Pucks are appx. $.99 around here so this whole project should come in at less that $15 if you wanted to do both seats.
'78 CJ7 -- Chevy 350 SBC, Holley 4-BBL, TH700R4, B&M Performance Shifter, Dana 300 w/ Twin Sticks, 3" Shackle Lift, 3" Body Lift, D30 Front (Disc), AMC 20 Rear w/ Moser 1-Piece, 4.10's, 35x12.50/15 General Grabber MT's, Cragar Soft 8's (15x8 w/ 4" BS)
Trombino is offline
post #25 of 72 Old 10-02-2006, 11:15 AM
AMLechner
Do you know if the bolt sizes would be the same on all TJ's?
Penn State University - class of 2004
AMLechner is offline
post #26 of 72 Old 10-02-2006, 04:23 PM
Trombino
Trombino's Avatar
1978 CJ7
I believe they would be. If you wanted to double check, just take out (2) of the bolts from the passenger seat and take them with you. One will be a T-50 (maybe T-55) Torx bolt and the other (3) will be 13 MM I believe, maybe 14 MM.
Trombino is offline
post #27 of 72 Old 10-19-2006, 05:55 AM
Yamahar629
im looking up "m8-60" but im not able to find one online. Any sugestions as far as a specific link to a website? Im new to sizing bolts and cant figure out what the sz means.
Yamahar629 is offline
post #28 of 72 Old 10-20-2006, 04:13 PM
Trombino
Trombino's Avatar
1978 CJ7
Don't even bother online. Just go to your local hardware/Lowe's/Home Depot. Its not an uncommon size and any one of those places should have it.
Trombino is offline
post #29 of 72 Old 11-06-2006, 04:50 PM
89_Jeeper
just curious would this work for the xj ??? in my yj i usually sit with the sterring wheel adjusted all they way down on the tilt which is about 1" or so above my legs when driving, but when driving the xj the sterring wheel is like 2 or 3" away from my legs and it kinda uncomfertable and feels like it doesnt even have tilt, plus i also have to have my arm extended ALOT more then in the yj.... would the seat lift be a good thing to do???
89 YJ Islander 4.2L
87 camaro for sale
89_Jeeper is offline
post #30 of 72 Old 12-13-2006, 06:38 PM
droogsnightout
I used a set of skateboard wheels. They cost about $10 for a set of four and give about an inch and a half of seat lift. They are the perfect size and already have a hole drilled, so no sawing or drilling. $2 for longer bolts from the local hardware store and in 10 minutes I was done. Plus they seem to absorb some vibration. Absolutely love it, only problem is now I have to duck under the windshield frame to see the stoplights. Feels like a custom fit Jeep!
droogsnightout is offline
cool stuff cheap seat covers and tool pockets abbe Cheap Tricks & Fixes 9 10-10-2013 03:50 AM
cheap lift yes or no? vito30 General Jeep & Off-Road Equipment 2 01-06-2009 09:07 AM
cheap lift kit? FifteenCents Tires & Wheels 13 12-23-2005 05:50 PM
Cheap Lift bluejeepguy Tires & Wheels 1 01-03-2005 08:58 PM
cheap lift PoorFool Tires & Wheels 3 05-15-2002 08:02 AM
