Cheap Cool Mods - Page 7 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Trick & Fixes > Cheap Cool Mods
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!
Unread 02-26-2005, 01:47 AM   #91
92 Green YJ
take a sawzall and cut the crap out of your fenders to clear bigger tires with less lift!!
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My RigRater Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline   Reply With Quote
Unread 02-26-2005, 10:15 AM   #92
axia
Originally Posted by MrBurns
I think a better alternative to putting a small carabiner on the seat pull tabs is to go to a hardware store and get little screw pin D-rings. They usually have some that are the size of a keyring or a little bigger. Seems more Jeepish to me.
Thats a cool idea, that i would have never thought of, perhaps even those powdercoated bright orange ones would look really cool...
axia is offline   Reply With Quote
Unread 02-28-2005, 12:39 AM   #93
DusTJ
I got another TJ 3 switch bezel on ebay(cheap). I cut out my ash tray portion of my dash bezel and installed the 3 switch bezel next to my other 3 switch bezel(with a few mods) now its a 6 switch bezel. Pictures soon.
DusTJ is offline   Reply With Quote
Unread 03-12-2005, 12:22 AM   #94
mrepack
Originally Posted by Marty315
Painting the fender flares has made a huge difference on my Jeep, looks several years younger now. Also, the headlight bezels got painted while I was at it. I've taken out the rear seat and carpeting and use it to haul stuff here on the ranch. Makes the Jeep look more rugged. Also I took off the endcaps on both front and rear bumpers as well as the roll bar surrounds on the back half. It's all about personal preference in looks.
Did you paint them yourself? What kind of paint did you use?
[COLOR=SeaGreen]1995 Wrangler YJ[/COLOR]
2.5L, 5 speed manual transmission
Power Steering converted from manual, no A/C
Hella 550 fog lights
Edelbrock IAS Shocks
Skyjacker steering stabilizer
mrepack is offline   Reply With Quote
Unread 03-19-2005, 04:00 PM   #95
lord_retro
Real cheap anti theft system
i did this with my jeep because i live in a big city and leave the doors and top off a lot. buy a properly rated switch (i used a toggle switch capable of handling up 20A) - cost ~ $5 CANADIAN... all you do is this:
- splice the cable from your battery's +ve terminal and run it through the firewall and to somewhere discreet and easy for you to toggle - james bond style!
- clamp and solder the switch in, and you're DONE!
total time: 30 minutes TOPS
as long as you don't care about your clock being off, it's great!
1994 YJ, 2.5L - if it's not broken, don't fix it, break it first!!
4" skyjacker susp. lift running on 33's, 4 speaker sound w/ custom sub (2x8"), covered neoprene seats
lord_retro is offline   Reply With Quote
Unread 03-24-2005, 05:29 PM   #96
982doorxj
You do know that your battery is rated for hundreds of cranking amps, right? Switching your main battery positive cable through a cheap toggle switch is just asking for a fire one of these times you go to start your jeep. There's a reason they make battery disconnect switches just for the purpose.
[COLOR="Red"]
===============*SOLD*===================[/COLOR]
98 2-door Base model XJ 4.0 | AW4 | NP231| 31x10.5 Cooper Discoverer STT's on 15x8 Cragar Black Soft 8's
Daystar Spacer and Shackle Lift | Quadratec HD Leafs |Surco Roof Rack w/ spare mount
[COLOR="Red"]
982doorxj is offline   Reply With Quote
Unread 04-02-2005, 07:26 PM   #97
Dvs_Lance
Originally Posted by blowsox13
why would you buy an unlimited in the first place??? they are sooo ugly.... un Jeepish
The unlimited rides much better with the wheelbase being just a little longer. It also comes with all the stuff most people end up doing to a jeep already done. I work for a jeep dealership in parts and have to admit that at first I thought they looked kinda funny. After riding to lunch a few times in one, I have to say it definately grows on you. IMO they ride more like a XJ than a traditional wrangler. My 2cents
1988 red 4 door XJ 4.0, AW4 Command-Trac
3" Skyjacker Softride with AAL and Nitro Shocks
30x9.5 ProComp All-Terrains
Hella H-3 100watt bulbs in factory fogs(upgraded wire)
50x4 Pioneer Head Unit and
Pioneer 5.25" rear and Infinity Kappa 4" front
10" Infinity BassLink; Cobra CB
4' Firestik II (USA limited)
Dana 30 front, Dana 35 rear, NP231
[SIZE=1]next mods are lockright front, SYE conversion, and BB![/SIZE]
Dvs_Lance is offline   Reply With Quote
Unread 04-03-2005, 05:29 AM   #98
MWRKEF
Extend Short Shifter
My TJ has 4" lift and after installing a B&M shifter I found it uncomfortable at times to reach the shift knob. I solved this by purchasing a "coupling nut" at the local hardware store and installing between the rod and knob. The extra length really helps shifting when being tossed around on rough trails.
MWRKEF is offline   Reply With Quote
Unread 04-04-2005, 08:43 AM   #99
88eXcellentJeep
>infomercial voice< Tired of that saggin headliner??...Rip it the !@#$ out!!
[COLOR=Gray]|[/COLOR]
[COLOR=Red][SIZE=6][|||||||][/SIZE][/COLOR]
"I break stuff and then I fix it. I'm a Jeeper. It's what I do."
[URL=http://www.cardomain.com/ride/597573]This is my daily driver, if I roll it I'm screwed![/URL]
88eXcellentJeep is offline   Reply With Quote
Unread 04-06-2005, 02:18 PM   #100
GlennM86
speaker bar
Has anybody moved the original speaker bar to the front of the roll bar, over the driver's head?
if so, did you just rotate 180 degrees so there was minimum drilling or did you place it so it would be symmetric with the original layout?
just curious. you can get as anal as you want to about mods. some want to save time, others want the appearance that they care about their "beaters".
01 TJ 4.0 Auto, 33" Nitto on M/T Classic Locks with 4.10s, 4" Skyjacker Value Flex Lift, Airlift 1000 bags in the rear coils, Procomp MX6, ARB Front/Rear, Super 35 rear axles, ChroMoly Front Axles, Bulletproof bumpers/tire carrier, Custom CB and antenna mounts, Magellan GPS, and XM radio
[EMAIL=GlennM86@aol.com]Email for questions, concerns, or comments...[/EMAIL]
GlennM86 is offline   Reply With Quote
Unread 04-07-2005, 07:40 AM   #101
Mr. Joshua
Mr. Joshua's Avatar
You can remove the third light above your spare. Check you local laws though. I removed mine, and it looks better.
2001 TJ 60th Anniversary Ed.
Cragar 342 series steel wheels
31" BFG A/T's
SkyJacker Hydro's
Olympic Grill Guard
Tuffy Glovebox
POLISH JEEP OWNERS CLUB #5
Parrothead Jeepers union member #11
Mr. Joshua is offline   Reply With Quote
Unread 04-13-2005, 07:33 PM   #102
Jeep_Grrl
I did the D-rings on mine - got them 2 for a buck at the local flea market - looks great! I will post pics later
[COLOR=DarkRed][B][SIZE=3]Jeep_Grrl[/SIZE][/B][/COLOR]
[B]99 TJ[/B] [COLOR=Olive]Sahara[/COLOR]
[URL=http://www.imagedump.com/index.cgi?pick=get&tp=218803]Winter in FL[/URL]
Jeep_Grrl is offline   Reply With Quote
Unread 04-14-2005, 12:38 AM   #103
NowBetter
Well...
Get a rooftop cage for $60 on ebay and put your spare tire ont top along with a shovel and a gas canister... looks good to me!
http://viewmorepics.myspace.com/inde...20050413233833
[SIZE=3][B]BetterNow[/B][/SIZE]
Grand Cherokee Laredo 4x4
Performance:
Base Engine Type: Inline 6, 4.0 liters Horsepower: 190 hp
Max Horsepower: 4750 rpm Torque: 225 ft-lbs.
Max Torque: 4000 rpm Maximum Payload: 1150 lbs.
Maximum Towing Capacity: 5000 lbs. Drive Type: RWD
[B]209,900 miles[/B]
NowBetter is offline   Reply With Quote
Unread 04-14-2005, 08:16 AM   #104
AWILD
gas mileage byebye. But i honestly do like that look
TJ
4.0L, 5spd, 2"BB, 31x10.5 Mud Terrains, Black Steelies,Hella 100W, Custom Brushguard, IPF H4 housings w/ Fatboys, Sirius 23 Hair Nation!
AWILD is offline   Reply With Quote
Unread 04-16-2005, 11:43 PM   #105
WhtJeep
2008 WK
Try putting a bike rack up there
2008 WK Khaki Grand Cherokee Rocky Mountain
1995 XJ Lifted and driven straight into the ground - RIP
Originally Posted by cresso
Quick dana 35 test: kick one of the rear tires. If the axle breaks, it's a 35
XboxGT - The Mad Med1c
WhtJeep is offline   Reply With Quote
