Cheap Cool Mods - Page 54 - JeepForum.com
 5Likes
post #796 of 1365 Old 08-18-2011, 07:31 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Originally Posted by PsychoJeeper92 View Post
What do you guys think of the idea of putting something on the side of the hood that would resemble old ww2 war plane exhausts? I'm not sure if it would look good or just a little rediculous.
Form Follows Function, especially on a Jeep. Those WWII exhausts were functional for their purpose. Functional for your purpose is a simple hole and screen.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #797 of 1365 Old 08-19-2011, 08:02 AM
fedx95
1993 XJ Cherokee
unless he routed the exhaust through there, one pipe per cylinder!!
fedx95 is offline
post #798 of 1365 Old 08-19-2011, 08:02 AM
fedx95
1993 XJ Cherokee
that would enhance his off road capability, as his exhaust system would be not in danger of rocks
fedx95 is offline
post #799 of 1365 Old 08-19-2011, 09:17 PM
jeepinvader
i think that'd be hella cool
Free Chuck!
jeepinvader is offline
post #800 of 1365 Old 08-21-2011, 06:34 PM
shiftclick
DIY Tail Light CB Antenna Mount ($7)
I noticed the other day that my CB antenna mount was wiggling way too much for my liking, and after investigating it, I found that the screws going in to the sheet metal on the back of the jeep had come loose over time. Not wanting to put more holes in my jeep, I opted to make my own mount.
I had been admiring those tail-light mounts for quite some time, but the $30 price tag never agreed with my cheep sense. So I headed off to Lowes today and mulled around the sheet metal and steel aisles just looking for something to jump out at me. It needed to be easily modifiable as I have no welding/cutting tools with the exception of my Dremel and Mr. Blue Torch. While walking down of the aisles I came across this:
Large stainless steel gate hinge ($7)
I knew that with a little finessing, I might be able to make it work. The first thing I did was to fit the metal cutting wheel to my Dremel. I then through the hinge in to the vice and decided to cut the hinge side that had less metal at the bottom.
After that, I removed the tail light and did a quick, dry fit. I put the hinge behind the tail light and used a sharpie to mark where 2 other holes would need to be drilled. I then set to drilling them out.
Next up was another dry fit, and choosing how far I needed to bend the end to make a tab for the antenna to ride on. I had previously routed the cb antenna through the body and in to the tail light assembly and then out a hole in the side (I need to address this hole before fall sets in ). I opted to go about 2 inches from the top.
Here's the hole I was talking about:
I next put the hinge back in to the vice short side down - or the side with the tab mark on it - so I could use the bulk of the length of the hinge as a lever to help bend it. This is where Mr. Blue Torch comes in. Took about 3 minutes of heating it up - both sides - and then pushing or pulling on it to see if it was maleable yet. After that third minute BAM! It went right over. It was perfect. I carefully removed it from the vice and threw it in some water to cool it off.
Next it was time to install it on to the Jeep and test it to make sure the SWR was still good. Everything was good, so I put it all back together.
Finished product:
I might take it off and paint it black, but i'm pretty happy with the results! I do plan on loctiting the old mount and using it for my signal flag when we head out to the offroad park.
Hope that helps you guys!
Shiftclick
His: 2002 TJ 4.0L (Sold), Hers: '10 XK Hemi Ltd
I'm currently between Jeeps...
shiftclick is offline
post #801 of 1365 Old 08-21-2011, 08:56 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Someone else on here did this, and I copied it. I figured I'd share with the non XJ crowd.
It's not done, that's why there is extra hanging down.
Less than 50 feet of 550 Paracord that I gutted and wrapped. I did it yesterday and I'm really happy with the results. I've got less than $5 invested and an hour and a half of my time.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #802 of 1365 Old 08-22-2011, 03:27 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Finished product:
Nice write up !
Looking at the size of the hole I think a Grommet for a PVC valve on a valve cover may work. Check the HELP section at the local autopart stores
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #803 of 1365 Old 08-26-2011, 10:41 AM
Jamesbbh
So actually got some work on the jeep done last night:
KC daylighters from craigslist --$20
Took the bumper off, removed the rubber bumper things, and bolted these things on there I had laying around
Cut the front part off
Drilled some holes
Mounted, I'll take it back apart and bedline/reinstall everything tonight.
Build thread (sorta)
Random stuff I've made thread
Jamesbbh is offline
post #804 of 1365 Old 08-31-2011, 02:12 AM
lockedwheels
Hi lift Mod
I've been a viewer of the site for a while, but never a member until today !! Figured I would share the mods I did earlier tonight before I came into work. I have a mount on my hood for my hi lift. From it being used and abused I decided to take it apart and clean it up and repaint it. I was looking at it all dissasembled and came up with an idea. I grabbed two rubber corks ($1 a piece) for each end of my handle. It is perfect to store some extra fuel line and brake line. Also installed a quick disconnect for it instead of the codder pin that it comes with. Last and final thing I did was grabbed a shovel head and set it up to quick connect and disconnect from the handle. So It was just a jack handle.. Now its a handle a storage container and a shovel handle.
lockedwheels is offline
post #805 of 1365 Old 09-14-2011, 04:10 PM
gryphon
any pics of the handle mods?
gryphon is offline
post #806 of 1365 Old 09-15-2011, 04:14 PM
lockedwheels
Yeah let me take some pics and throw them up here... I also made some nifty zipper pulls for my windows out of 550 cord.. They work really well
post #807 of 1365 Old 09-16-2011, 11:37 PM
Smallblockmjt
Being a newbie on site, I've been reading alot of the old posts on "cheap fixes" & "technical info". Alot of the posts are old recycled info but none the less are still very informative. One of my favorite is "turning the rear view mirror 180 degrees upside down putting the tab on top". What a difference it makes giving more driving visibility. That was real brilliance on the member who originally came up with it and in his honor, the site moderator should make that suggestion a "permanent sticky". IMOP, Michael T.
"This ain't no dress rehearsal ! "
Smallblockmjt is offline
post #808 of 1365 Old 10-05-2011, 03:06 PM
lockedwheels
post #809 of 1365 Old 10-05-2011, 03:11 PM
lockedwheels
Sorry Didnt realize they were that blurry !!!
post #810 of 1365 Old 10-05-2011, 03:20 PM
lockedwheels
These are the zipper pulls that I made... 8 total.. had the 550 cord laying around and made them for free.. i cant believe the difference they make when i put my windows on and take them off.
Cheap yj mods love2crwl Cheap Tricks & Fixes 36 02-04-2017 05:22 PM
cheap 4.0 mods? redneckwithajeep Engines & Drivetrain 17 01-04-2015 02:33 PM
FIRST JEEP! need some cool easy mods that dont brake the bank nickoidl Cheap Tricks & Fixes 47 09-20-2013 11:48 AM
cheap xj mods?? hoot20 Cheap Tricks & Fixes 0 05-25-2009 02:52 PM
CJ-7 Cheap Mods GoldenEagleGa Cheap Tricks & Fixes 1 02-06-2009 11:53 PM
