Cheap Cool Mods - Page 32 - JeepForum.com
 5Likes
post #466 of 1365 Old 01-05-2010, 11:12 AM
frenchlayer
2010 JK Wrangler
For my shifter knob, I used a mini beer tap pull, the threads were exactly the same, the large ones are too big though.
frenchlayer is offline
post #467 of 1365 Old 01-07-2010, 11:26 PM
BullandTerrier
2009 JK Wrangler
I put mini shackles on my pull tabs that fold down the rear seats.
I also used two stainless conduit hangers and some insulation foam and made a maglite mount.
I'm just a girl with her dog and her ||||||
BullandTerrier is offline
post #468 of 1365 Old 01-08-2010, 12:38 AM
Comanche_
If you want 12V power outside the jeep for any reason, I found a weather proof outlet with 17ft of wire, for $6 at our local grocery store. Cheap and easy to do. I'm instaling it in the bed of my truck for camping.
Originally Posted by Z0NAJEEP View Post
With more stupid comments? Two retards don't make a right.
Comanche_ is offline
post #469 of 1365 Old 01-08-2010, 09:11 PM
jake92321
Dont know if anyone has mentioned it but i just installed a killswitch for when i am away from my jeep cost about 10 bucks
1999 Desert Sand TJ Sport
jake92321 is offline
post #470 of 1365 Old 01-08-2010, 10:52 PM
Martinsc
I was thinking about making a kill switch. How did you make yours?
My Build-
Martinsc is offline
post #471 of 1365 Old 01-09-2010, 02:23 AM
Mushrabbit
How?
10 chars
Mushrabbit is offline
post #472 of 1365 Old 01-09-2010, 12:41 PM
jake92321
well as you know you cant start a manual tj without the clutch pressed in, there is a simple circuit created when the clutch pressed in so if you look around by the clutch there is a yellow wire and a yellow wire with a red stripe simple splice a switch into those and with that switch off the jeep wont start but with it on it will work normally just hide the switch anywhere you want. my jeep is a 99 with the manual sorry i cant give much info for automatics
post #473 of 1365 Old 01-09-2010, 12:49 PM
SimonsTJ
For autos, you just need to interrupt the Neutral Safety Switch, which makes sure that the jeep is started in neutral or park
Indy is my new BFF!
SimonsTJ is offline
post #474 of 1365 Old 01-09-2010, 01:25 PM
92 Green YJ
92 Green YJ's Avatar
It shouldn't be. All standard beer faucets use a 3/8" thread.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #475 of 1365 Old 01-09-2010, 01:27 PM
92 Green YJ
or you could interupt the fuel pump. Thats what I did for one of mine. put a switch on the power wire to the fuel pump. Switch off means no fuel, so it is also a nice safety feature for a fuel kill if I should need it. The other one is actually built into my MSD. If you look in the MSD ignition module book it details how to add a kill switch quite easily on the ignition circuit
My
post #476 of 1365 Old 01-21-2010, 09:37 AM
Maxxram
Originally Posted by firemerc99 View Post
Went on ebay, got a starter disable keypad, sort of like in the movie The Transporter. Mounted it were the passenger air bag disable switch should be, (bought the TJ used, apparently the previous owner didn't want that option), installed a 30 amp bypass switch behind the glove box, just in case the keypad screws up. Works great, plus it's kinda cool punching in a code to start it, just like in the movies. As for waterproofness, it's been rained on a few times, still working great. It cost about $20 or $30 on ebay. plus the cost of the switch, which was less then $10.
Thanks for the info on this idea. I ordered a digital keypad for 17.99 shipped.
Installed it in the starter circuit and now unless you enter the code the jeep will not start. Best $18 I've spent.
Maxxram is offline
post #477 of 1365 Old 01-21-2010, 11:02 AM
Mushrabbit
Do you or Firemerc99 have a linc to where you purchased? I can't find anything that inexpensive and must not be using the correct search strings in either Ebay or Google.
post #478 of 1365 Old 01-21-2010, 11:29 AM
Maxxram
Here is the one I used. Asianwolf Smart Digital Keypad Starter Disable Kill
Very easy to install and the key pad is very easy to install. I will try and get a pic of the keypad in a little bit.
Maxxram is offline
post #479 of 1365 Old 01-21-2010, 11:32 AM
Mushrabbit
Thanks so much, the link was perfect. Ordering it.
post #480 of 1365 Old 01-21-2010, 11:39 AM
Maxxram
No problem, Glad to help out.
Maxxram is offline
Cheap yj mods love2crwl Cheap Tricks & Fixes 36 02-04-2017 05:22 PM
cheap 4.0 mods? redneckwithajeep Engines & Drivetrain 17 01-04-2015 02:33 PM
FIRST JEEP! need some cool easy mods that dont brake the bank nickoidl Cheap Tricks & Fixes 47 09-20-2013 11:48 AM
cheap xj mods?? hoot20 Cheap Tricks & Fixes 0 05-25-2009 02:52 PM
CJ-7 Cheap Mods GoldenEagleGa Cheap Tricks & Fixes 1 02-06-2009 11:53 PM
