Cheap Cool Mods - Page 10 - JeepForum.com
 5Likes
post #136 of 1365 Old 08-26-2005, 03:40 PM
ncjeepinyj
ncjeepinyj's Avatar
Originally Posted by racefan318
now what could we do with that 4x4 chunk???
Im guessing thats the parking brake
ncjeepinyj is offline
post #137 of 1365 Old 08-31-2005, 09:31 PM
enil01
enil01's Avatar
Another of my cheap cool mods
'93 4.0L YJ Becky
RE 4.5" XD lift | 33" TRXus M/Ts | Warn M8000 | Herculined | OBA
_|_
--X-X-(_)-X-X--
<3 EP-3Es
enil01 is offline
post #138 of 1365 Old 09-01-2005, 10:00 AM
BRad704
Nothing to see here...
BRad704's Avatar
i just figured out a cool, cheap addition to my YJ. I wouldnt call it a mod because its not really attached to teh jeep.
Using a 40 x 33" piece of 1/2" plywood, I made a cover for the "bed" for when I have the back seat out, which is pretty much always. I also used 2-2x4's as runners from front to back to keep it from sliding side to side. Now paint it black and put a hasp or some type of lock on the underside adn you have a great concealment for whatever you have in the back.
this was actually free for me, cause i used materials that were... umm... donated.... from a job site I was on.
BRad704 is offline
post #139 of 1365 Old 09-06-2005, 09:07 PM
mud n rox
mud n rox's Avatar
I use my ashtray for loose change. But when it gets somewhat full the change falls out the back side of the tray. It goes down in the dash and/or console and rattles around. So I took the center section of the dash out. You know where the radio, hvac controls, and ash tray are. Anyway I put a couple of pieces of duct tape over the opening behind the ashtray. Now when the change falls out, its just there on the tape and not rattling around behind the dash. Cost= free(unless you have to buy the tape).
2001 TJ Sport - With a little lift, some armor, four mud tires, and a few decals.
Caution: Rock and a hard place just ahead.
mud n rox is offline
post #140 of 1365 Old 09-07-2005, 09:34 PM
Grape Ape
Web Wanker
Grape Ape's Avatar
Glen m86, in regards to post on 04-06-2005 4:18pm, if you haven't moved your overhead speakers from the back up front above your head, DON"T. My 92 came with the soundbar mounted in front of the roll bar. I am 6'2" and have lost count of the times my head and soundbar have met while bouncing around on the trail, even with a seatbelt on. It takes some of the fun out of the bumps at least for a minute or 2.
In supaasianpdjr's post on 7-23-2005 7:59pm. In case anyone is wondering the clamps that are used to mount the hi lift jack are called minerallac clamps. They are a clamp used to hold electrical conduit. You can find them at any electrical supply house. They also work very well for holding any round items, drive shafts, axle shafts. just screw them down and then clamp the round items in them. They have a nut and bolt supplied to hold them together but you will have to supply the mounting hardware.
Another good item for holding a mag light is those metal spring type mop and broom holders. Wrap a little electrical tape or duct tape around the spring parts will increase the hold instead of metal to metal and slipping up and down in the clamp the mag light will stay in place.
The plywood across the back when the seat is out is an excellent idea. another item to add to that is some tie downs to the lid. If you use 3/4" plywood you can put anything you want on top of it and not have to worry about it sagging.
I also cut a piece of plywood to fit across the bars from the roll bar to the window. drilled some holes down the sides and secured the board to the bars with heavy duty plastic tie wraps. then you have another area for hauling coolers or rubbermaid packer boxes full of gear. DO NOT TIE ANYTHING TO THE PLYWOOD, tie down your items to the roll bar etc. The tie wraps are only there to hold the plywood in place. The minerallac clamps can be used to clamp the plywood down for a stronger setup. The advantage is you always have a bikini top plus your soft top fits right over the plywood so you don't have to take it off and put it on over and over. The advantage of using heavy duty tie wraps to hold the plywood down is they won't wear holes in your top, bolts sticking up through the plywood will wreak havoc on your soft top.
Grape Ape is offline
post #141 of 1365 Old 09-22-2005, 03:00 PM
GITOVRT
I just bought an '05 and live in Phx, it gets pretty damn hot, the heat didn't help at all. I got one warning sticker 1/2 way off and said screw it! I just went out looking for some 'cool' stickers and slapped the puppies right over the original warnings.
OlllllO
Go Packers!
Yellow '05 4.0 Auto
DC 4" Lift, 33X12.5 Khumo MTs on Black Cragars, Tomken Rear Bumper w/2" rcvr
GITOVRT is offline
post #142 of 1365 Old 09-24-2005, 04:12 PM
Joshua Sloat
Originally Posted by abstractjeep
flip your sun visors so you don't have to read the warnings all the time.
Well by the sounds everyone is talking about CJ body style stuff. But on my XJ I just removed the sunvisors when replacing the headliner. And as for flipping the rear veiw mirror upside down I just removed it and found a dash mount one, because Im to tall to see, so flipping the mirror didnt help me.
214,XXXmi
Specs: Renix 4.0, AW4, NP-242, Dana30/Dana35, 3.55:1 Gears
Mods: Owen's Grill Guard, Custom Dynomax S/T Exhaust, TG 235/75R15
(XJ)Chrome Bumper Club - Member No. President
Joshua Sloat is offline
post #143 of 1365 Old 10-02-2005, 03:04 PM
adamblitzer
would love to hear more CJ mods!
post them up boys.
adamblitzer is offline
post #144 of 1365 Old 10-03-2005, 07:32 AM
beyondink
Cheap mag-light holder... I took a piece of pvc pipe cut it and attached it to the lower part of the main hoop with bungy cords.. Just slide the mag-light in it and go..you can paint the pvc pipe or you can sticker it up like I did... works great!
There are NO Weapons of Mass Destruction in Irag!!, Chuck Norris lives in Oklahoma!
beyondink is offline
post #145 of 1365 Old 10-03-2005, 10:25 AM
AWILD
AWILD's Avatar
Not a bad idea
TJ
4.0L, 5spd, 2"BB, 31x10.5 Mud Terrains, Black Steelies,Hella 100W, Custom Brushguard, IPF H4 housings w/ Fatboys, Sirius 23 Hair Nation!
AWILD is offline
post #146 of 1365 Old 10-07-2005, 08:26 AM
FunkSkunk
Sold my soul to JeepForum
FunkSkunk's Avatar
SUPER EASY mod for your spark plug wires!!
-----------The pic explains it all-------------------------------------
FunkSkunk is offline
post #147 of 1365 Old 10-07-2005, 09:00 AM
erickpl
erickpl's Avatar
Fun with Zip Ties!
Nice! Keeps it all organized and apart.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #148 of 1365 Old 10-07-2005, 09:04 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Just when I thought there were no more uses for zipties. Awesome.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #149 of 1365 Old 10-11-2005, 01:54 PM
FunkSkunk
FunkSkunk's Avatar
post #150 of 1365 Old 10-11-2005, 03:25 PM
AWILD
AWILD's Avatar
Wouldnt a dremel be quicker? And that must take forever
TJ
AWILD is offline
Cheap yj mods love2crwl Cheap Tricks & Fixes 36 02-04-2017 05:22 PM
cheap 4.0 mods? redneckwithajeep Engines & Drivetrain 17 01-04-2015 02:33 PM
FIRST JEEP! need some cool easy mods that dont brake the bank nickoidl Cheap Tricks & Fixes 47 09-20-2013 11:48 AM
cheap xj mods?? hoot20 Cheap Tricks & Fixes 0 05-25-2009 02:52 PM
CJ-7 Cheap Mods GoldenEagleGa Cheap Tricks & Fixes 1 02-06-2009 11:53 PM
